BeastX FBL System BeastX FBL Flybarless System Software and Hardware Support |
09-22-2011, 08:43 AM | #41 (permalink) |
i think im just surprised how much ive had to carm mine down in comparison to what everyone else seems to be running on there 450 pros to get it the same as the "sport" preset im used to.
makes me feel like a big girl |
09-24-2011, 03:14 AM | #42 (permalink) |
Gaui X5 FES stock motor 15t
Yge-100 gov store , 80% throttle @2350rpm Cyclic torq 9080 hv @8.4 volts direct Tail - torq 9188 hv @ 8.4v driect 520mm rjx fbl mains, 85mm cf Dsmx sat with Beastx adaptor 1 layer clear 3m vhb tape, lower/rear tray/horiizontal Power to beastx is 8.4v, servo power redirected from beast x, signal out only Spektrum DX8 Gyro gain hh 56, rate 67 ,remmber dx8 has diffrent gain values. Because it Uses +125- -125 for gyro gains, so I'm guessing I'm really at hh82? R98? Parameter menus A no change, used swash leveler B control behavior - pro (red) C pitching up behavior - low(red flashing) D headlock gain - medium (red) E stick deadband - 2 (red flashing) F torque precomp - on(normal -low) G cyclic response - very high(blue) H pitch boost - high (blue flashing) POT1 11 oclock POT2 10 oclock POT3 9 oclock Tail servo ball at 12mm.limits set way before hitting max travels Blue light at 6 degrees , 13 deg collective, 12 cyclic |
10-06-2011, 03:49 PM | #44 (permalink) |
Trex 550fbl
Align DS 610's on cyclic ds620 on the tail Castle ICE 75 align 600m Align FBL head Spektrum AR7600 receiver Transmitter mode 20% expo on aileron and elevator 10% expo for the tail 105% ATV for aileron and elevator 105% ATV for the tail 60% transmitter gyro gain Parameter menus B control behavior - transmitter C pitching up behavior - very low (purple) D headlock gain - low (red flashing) E stick deadband - 1 (purple) F torque precomp (off)
TREX 550FBL beastX ,align ds servos ,CCv2 ice 75 , CC bec Turnigy nano tec 5000 mah 6s 65c , blade450 3d and couple more toys to play with |
10-07-2011, 06:18 PM | #45 (permalink) |
On the POT settings, 9 o'clock is the default setting? Just want to make sure I get it right.
Protos 380 NEO x2 Oxy 2 Goblin Fireball |
10-12-2011, 02:08 PM | #46 (permalink) |
Anybody with the Trex 600EFL Pro ??
Trex 600E PRO Trex 700LE |
10-12-2011, 05:08 PM | #47 (permalink) |
Here you go
Trex 600EFL PRO Align DS 610's on cyclic DS650 on the tail Castle ICE2 HV120 Align 600m Align FBL head Spektrum AR8000 RX Spektrum DX8 TX Transmitter mode 20% expo on aileron and elevator 10% expo for the tail 100% ATV for aileron and elevator 100% ATV for the tail 40% transmitter gyro gain Parameter menus B Control behavior - Transmitter (Blue) C Pitching up behavior - Medium (Red) D Headlock gain - Low (Red Flashing) E Stick deadband - 2 (Red Flashing) F Torque Precomp - Off (Purple) G Cyclic Response - Normal (Purple) H Pitch Boost - Off (Purple) |
10-12-2011, 06:56 PM | #48 (permalink) | |
We used to live in San Diego, is Miramar still open to you guys ?
10-23-2011, 07:12 PM | #49 (permalink) |
Tarot 450 Pro
MKS DS92 on cyclic MKS 8910 on tail CC Ice Lite 50 (burned it yesterday, will put HobbyWing Platinum 40A + CC BEC 10A when it arrives) Tarot 450M 3800kV Tarot FBL head + many Align parts Futaba R6208SB Rx Futaba 8FG Super Tx Parameter menus B Control behavior - Pro (Red) C Pitching up compensation - Medium (Red) D Headlock gain - Medium (Red) E Stick deadband - 2 (Red Flashing) - might try 1 (purple) F Torque Precomp - Off (Purple) G Cyclic Response - Normal (Purple) H Pitch Boost - Red (Medium) I'm pretty satisfied with this setup, this is my first heli and I've flown it for just a half of dozen packs. Might try Extreme Control behavior later and then maybe transmitter, but I really like it this way. I tried flybar helis and would never buy one after trying BeastX |
10-30-2011, 07:29 PM | #50 (permalink) |
Trex 700E FBL
Firmware ver 3.0.8 cyclic - DS610 tail - DS650, 16mm hole distance 700MX 510KV motor w 12T pinion/slant gear CC 120HV V2, Governed, 2100HS, gain 7, Stock Align blades spectrum AR6200 / DX7 Transmitter Mode: D/R 0 (normal & Hold) 40% expo aileron 40% expo elevator 25% expo rudder 80% atv on aileron and elevator 100% atv on rudder 72 transmitter gyro gain (gear=gyro) D/R 1 (Idle 1 @ 2) 30% expo aileron 30% expo elevator 25% expo rudder 100% atv on aileron and elevator 100% atv on rudder 75 transmitter gyro gain (gear=gyro) parameters menu B control behavior - transmitter (blue) C pitching behavior - high (blue flashing) D headlock gain - high (blue flashing) E stick deadband - 2 (red flashing) F tail precomp - On, High reversed (Blue) G Cyclic Boost - Medium (Red) H Pitch Boost - High (blue flashing) pot 1 - neutral +1 pot 2 - neutral pot 3 - neutral +1 12 degrees collective 10.5 degrees max cyclic (no binding) Blue light transition @ 5.5 degrees using stock Align 3G horns and levers I'm liking my 700 again. I never could get rid of the porpoising in FFF with my 3G. I also feel much more connected to the heli now
-Michael Last edited by michael503; 11-01-2011 at 08:20 AM.. |
10-31-2011, 05:31 PM | #51 (permalink) |
Trex 600N FBL
Firmware ver 3.0.8 cyclic - Futaba 9452 with Align FBL servo wheels, 12.5 mm arm hole used tail - MKS DS760 tail, 13.5 mm arm hole used / Stock Align carbons / QuickUK grip assy TT53/OS50 carb / governed 2000 rpm / ATG governor / active mode / Rotor tech 603 3D Blades Head / swash / links ----- Outage 50 FBL head assy / Quick UK swash / blue light at 6.3 degrees using stock swash balls and outer hole in Outage grip arm. Cyclic limit at max spectrum AR7000 / DX7 Mounting ----- Front location above forward cyclic servos on 2 layers of 3M 410 tape Transmitter Mode: D/R 0 (normal & Hold) 35% expo aileron 35% expo elevator 25% expo rudder 80% atv on aileron and elevator 100% atv on rudder 77 transmitter gyro gain (gear=gyro) D/R 1 (Idle 1 @ 2) 27% expo aileron 27% expo elevator 25% expo rudder 105% atv on aileron and elevator 100% atv on rudder 77 transmitter gyro gain (gear=gyro) parameters menu B control behavior - transmitter (blue) C pitching behavior - medium (red) D headlock gain - medium (red) E stick deadband - 2 (red flashing) F tail precomp - On, low - nor (red flashing) G Cyclic Boost - High (blue flashing) H Pitch Boost - Very High (Blue) pot 1 - neutral +1 pot 2 - neutral +1 pot 3 - neutral +2 12 degrees collective max cyclic (no binding) This is the same heli as the second post in this thread, just with a new tail servo, and new firmware. Cyclic and pitch boost is da Bomb!
-Michael Last edited by michael503; 11-02-2011 at 04:59 PM.. |
11-02-2011, 03:49 PM | #52 (permalink) |
Can someone post some V3 settings for a Trex 450 Pro in Transmitter mode? Thanks!
Trex 800e, Trex 600n Futaba 14SG / AMA# 959345 / IRCHA #3954 |
11-13-2011, 03:10 PM | #53 (permalink) |
Trex 500e Pro - converted to fbl with align fbl head
500mx motor 12T DS510m on cyclic DS520 on tail Spektrum DX6I with AR6210 rx (std rx connection) RCE-BL70G esc w/ bec @ 6V 425D stock align blades(came with flybarred kit) Zippy 2800mah 6s 30C x3 Blue light @ 6 degrees transition around 5.8 (had to move balls to inner holes on stock Align D6FF metal servo horns to get blue @ 6, was red @ 6 in outer hole on servo horn) Rest of head is stock align per manual. Beastx mounted on lower gyro tray with 1 layer of 3M 4011 tape(looks an awful lot like The mounting pad that came with my gp900 gyro) Tail servo ball on outer hole per align manual 11 deg max collective pitch(far as my gauge goes so set there) Parameter menu all default A: no adj needed used swash leveler on step G in setup B: sport C: medium D: medium E: 2 F: off G: normal H: off All pots at default factory setting Gyro sense in tx @ 69 Just set this up today may need some tweaking, but I gotta say this flew AWESOME! Got to fly 3 packs after setup and the difference compared to the flybar is simply amazing! Might play around with some of the parameters but seeing as I just sport fly and it flies so great as is Idk if I need to change anything. We'll see if after some more flying if its needed. That is if I get the chance to weather here in NW PA sucks! I need to move south for the winter!
All with spektrum Rx's and dx6i: Blade mSR Mcpx Trex 500e Pro: ds510m, ds520, converted to fbl w/ beastx Last edited by bryman021; 11-13-2011 at 06:17 PM.. Reason: add more settings |
11-15-2011, 03:08 PM | #54 (permalink) |
After several flights I noticed some slight cyclic wobble and minor tail wagging.
I moved the ball on the tail servo to the inner hole as others on here have suggested. That really improved tail performance and was able to raise my gain back to 69 after lowering it to 59 with the ball in the outer hole. I turned pot 1 (cyclic gain) down 1 hash mark from the factory position. This took care of the wobble which was very slight and I really had to watch for it to see it. I turned pot 2 (direct cyclic feed forward) up 1 hash mark from factory position. This may get tweaked some more as I continue to fly. Lastly pot 3 (tail dynamic) was increased 1 hash mark also has the tail wasn't stopping quite right. I also switched from sport to pro on parameter B, and I think I am going to go to transmitter mode soon and fine tune the controls. I am really enjoying the beast and look forward to putting it on my 450 sport soon!
All with spektrum Rx's and dx6i: Blade mSR Mcpx Trex 500e Pro: ds510m, ds520, converted to fbl w/ beastx |
11-20-2011, 11:43 AM | #55 (permalink) |
Trex 450 sport w/ DX6I
Converted to fbl with align fbl hub, grips, swash driver, and links. DS410m on cyclic, DS520 on tail Stock motor and esc from super combo Tail gyro gain @ 67 in hh mode Blue light @ 6 degress, transition from red to blue around 5.75 degrees All parameter menus at stock setting except B control behavior set to pro Dial 1 - cyclic gain at 7 o'clock Dial 2 - direct feed at 9 o'clock (stock) Dial 3 - tail dynamic at 8 o'clock. Flies on rails!
11-22-2011, 01:18 AM | #56 (permalink) |
Srimoke FAIFA 90E Cyber Head kit 2010
BeastX v3 HKIII-4035 530KV Phenonix ICE2 HV 120A CC BEC Pro Change Capa to 1000 savox 1258TGx3 savox SB-2272SGx1 ruder RJX 690 FBL Radix 105mm batt Helicox-5500 6s * 2 pack |
01-19-2012, 09:18 PM | #57 (permalink) |
any settings for a trex 250
im going to be setting up my 250 this weekend and this will be the very fist time ever setting one up... i have a dx8 with the stock 410m servos for it |
02-05-2012, 12:38 PM | #58 (permalink) |
Does any have settings for Trex 500 EFL Pro with Dx8 settings?
Thanks |
02-05-2012, 01:19 PM | #59 (permalink) |
should be similar to the regular 500 and a DX7. There is at least 1 in this thread
-Michael |
