Jeti Duplex Radio Systems Jeti Duplex Radio Systems Support |
01-14-2016, 08:01 PM | #1 (permalink) |
Mini VBar and Jeti R3 UDI Diagram Needed
Being new to Jeti and after several hours of trying to locate a nice diagram of a hook up, please, could someone please provide me with a picture or a diagram of a UDI cable from a Mini VBar to the R3 receiver. Also, I have read that some folks are having a some problems with the Jeti/VBar playing well together. I am new to Jeti and am converting all my 5 helis to iKon from full size VBars. We have set up the first of 5, a G380 with iKon and R3. One G500 has a Mini on it that has always performed great so I want to try that with a R3. Any and all information is appreciated and simple pics of your cable is great as well.
S#!t Creek Survivor, up and back....No Paddle
Fireball 280/ G380/ G500/ G630/ G770/ MD500E 600 Ecureuil AS350 700/ Bell 222 800 Jeti DS-14/ Brain/ iKon- AMA 611227 |
01-14-2016, 08:23 PM | #2 (permalink) |
http://www.vstabi.info/en/node/442
I'm also running Mini-vbar, udi, and the r3. This setup worked flawlessly.
01-15-2016, 12:04 AM | #3 (permalink) |
Thank you Fauropitotto, I looked at the site and this is just what I needed. I am assuming that the UDI is still plugged into #3 port on the R3 as with the iKon.
I run a Castle Edge 100 and Castle BEC Pro on my G500. The BEC is plugged into RXB currently. Where would the BEC positive and negative wires go now as I have now run out of ports on the VBar? Would I plug the BEC and R3 into a "Y" connector coming from the RXB on the VBar?
Fireball 280/ G380/ G500/ G630/ G770/ MD500E 600 Ecureuil AS350 700/ Bell 222 800 Jeti DS-14/ Brain/ iKon- AMA 611227 Last edited by Scanman; 01-15-2016 at 10:57 AM.. |
01-15-2016, 07:31 AM | #4 (permalink) |
I would have to disassemble some bits on my model to get a full wiring for you, but I do recall it was tricky.
I managed to get all 4 servos, castle ESC, ESC aux wire, 2 power wires, and 1 backup power wire all connected to the Vbar and the R3. Every plug was used. One of the things I did was use the power lines from my 2S lipo and the signal line from my rudder servo to plug into RD on the vbar. Then I feed my rudder power from an open port on the R3.
01-15-2016, 10:30 AM | #5 (permalink) |
Please correct me if I'm wrong. This is what I have summed up out of your last post and the info on vstabi.
So, signal and power are two separate things. Per vstabi, all that is necessary is the ESC signal into the bottom pin of RXB on the Mini. This leaves the +- (middle and top) pins open for a power input for the BEC. If, using a "Y" cable, I plug the ESC signal wire into one leg of the "Y" and the +- of the BEC into the other leg (going to their respective pins on RXB) I will achieve the desired result of signal out and power in. Am I correct?
01-15-2016, 11:38 AM | #6 (permalink) | ||
As long as everything gets power and the signal gets where it needs to, everything will be okay. Quote:
So, just like on the vstabi site, you plug the signal/power cable into RXB, and the white aux cable into the top pin of RXA if you plan on using the Vbar governor. The Aux cable is not needed if you don't need the external governor. If your Castle does have a BEC, and you are using an external BEC, then you will need to remove the red wire from the Castle cable. If you Castle does NOT have a BEC, and you are using an external BEC or a lipo, I believe you can keep everything intact.You should probably refer to your Castle manual to see how to wire that up. Point is, I don't think Y cables are needed, because I was able to get all 4 servos, UDI, Castle, Castle RPM, 2 power inputs, and 1 backup all wired in without the need for Y cables or splitters.
01-15-2016, 01:56 PM | #7 (permalink) | |
•Oly Rotor Heads• Goblin 700 / 570 / 500 / 380 Gaui / X4 II / NX4 |
01-15-2016, 02:05 PM | #8 (permalink) |
No BEC.
Everything on all my helis is running entirely unregulated direct from my 2S lipo at 8.2 volts fully charged.
01-16-2016, 12:17 AM | #9 (permalink) |
The "Y" connection was the best/quickest way I could think of without redoing too much. I can read some of these manuals that come with the various components we use and get what I can out of them. But when it comes to electricity distribution and programming the high end ESCs and computers that control our aircraft......oh My God. I'm a schematic/ show me person, I guess. Your feedback as well as the vstabi site was what I needed for guidance so far. Thank you, and I will definitely stay tuned to HF for more education. No "Y" needed now.
