Old 02-22-2013, 06:31 PM   #21 (permalink)
Your collective range is too small.
You will need to increase it.
JR9303 / JR9503 / Futaba10CHP
nightflyr is offline        Quick reply to this message
Old 02-23-2013, 06:08 AM   #22 (permalink)
HI,
my T-REX 500 ESP has a pitch curve from -3° to +12° in normal.
The quick setup require to set pitch to 0° and 8° with the gauge. If I set 0° and 6° the display warning: "YAW/COL. SETUP IS OUT OF RANGE" will occour if 8° no!
So if I try to soft emergency recovery with +6° also with the warning present, is the system full functionally?
various mini WK home flying | MCX|TREX 450: AGUSTA109, ECUREIL 350|450 PRO|TREX 250 |TREX 500 DFC/MD500/Ecureil 350 |T-REX 600E A109+DFC|VARIO JET RANGER III DJI WKH| MINITITAN MD500! GOBLIN 700 KSE BD3SX | TX: 2801 | T14SG
I-FELN is offline        Quick reply to this message
Old 02-23-2013, 08:23 AM   #23 (permalink)
Never tried to fly while it had the warning displayed..
Suggest you go back and correct the pitch range to eliminate the error message before you fly.
Old 02-23-2013, 08:53 AM   #24 (permalink)
Originally Posted by I-FELN View Post
HI,
Hi I-FELN,
I am saying this just to make sure we are on the same page. Leave you pitch curve set to -3 to +12 degrees in normal and I am guessing you have +or- 12 degrees in idle up. If that is the case then the 0 to +6 or 0 to +8 degrees setting during quick setup should work without getting an error. At least that is the way it has works on my Trex 500 equipped with an Align 3G FBL system. Other wise I don't know what would cause the error message.
Like Nightflyr said, be cautious about flying with the error message present. It may not be a problem but then again it may be. Most likely not worth taking the chance. If message persists, give Howard a call at FMA for additional assistance.
Jack
Jack Doherty
FMA Beta Tester
CoPilot II HD
PowerLab 8
jdd1 is offline        Quick reply to this message
Old 02-23-2013, 10:34 AM   #25 (permalink)
Thank Jack,
I had set the pitch in quick setup to +8° to avoid the warning message.
B.Regards
Claudio
Old 12-31-2014, 03:36 AM   #26 (permalink)
Default Hard Deck
Hi guys im having some trouble trying to get my copilot 2 hard deck to work right ive got v2.43 firmware installed and have completed all the quick set up and preferences but in pre flight there are no errors and says good to fly but the green light on the hard deck sensor only lights up for a few seconds on power up then go out,what have I done wrong ?
Pity 71 is offline        Quick reply to this message
Old 01-01-2015, 06:01 AM   #27 (permalink)
A little information required...
1) Do you have your flight mode switch set up?
2) What modes did you assign to it?
3) If you have an FBL set up, are you powering up the CPII with it switched off and with auto trim set to 0 ?
If you have the CPII / HD set up as listed in item 3, the HD LED will come on for a few seconds at power up then turn off (SOP)
The HD LED is on once you switch on the CPII in HD mode to show you it is on and operational.
