Old 02-27-2012, 03:40 PM   #21 (permalink)
Default 800 motor
There also is a KDE 395 kv motor which is being advertised on their website as "coming soon".
which should fit easily if its the same size as the 495 kv and be very powerful. But somwhat heavy.
Alden is offline        Reply With Quote Quick reply to this message
Old 02-27-2012, 04:22 PM   #22 (permalink)
i ended up going with a 4035 400 so i can go up a pinion,better gear contact with the bigger pinion.no flights yet but am hoping it works out well
Trex 500 12s vbar I2 bling
Furion 600 12s vbar I2 bling
trex 700edl vbar 12s I2 bling
Tdrex 800e 12s vbar I2 bling
Bank account EMPTY
growmaster4 is offline        Reply With Quote Quick reply to this message
Old 02-27-2012, 04:56 PM   #23 (permalink)
Originally Posted by Alden View Post
Scopion has a 4035 Hk111 450 kv motor that I use for my 800. Just changing motor alone from 700 Align 510 kv with 11 pinion the bogging with collective resoved. But the power seems much the same and the temps are 135 degrees. There is a $400 5035 450 kv scorpion that I believe Nightflyer has shown fits barely (his was actually 5020) and I wonder how his one would do.
Alden
Issue with the Scorpion 50 Series you may not be able to get an 11 T pinion to fully engage the main gear.... the motor hits the elevator servo.
I reconfigured to the stock 164T CNC main gear and a 10T pinion with a 4035-500 Scorpion.
But I'm also turning 880mm mains.
The 50series 450 is working on my other helicopter with an 11T pinion, that one will be fitted with 980 main rotor blades, but the cyclic configuration is completely different from the 700E.
DTS.. also swapping out the cyclic servos for a HV set
JR9303 / JR9503 / Futaba10CHP
Old 02-27-2012, 06:53 PM   #24 (permalink)
Originally Posted by John_Co View Post
Akamullen, Thank you for the information!!
First question is what motor do you recommend? And is this the correct pinion for the V2 I need from your website ? ALIGN Mod 1.0 Motor Pinion Helical / Slant Gear 11T/ M1 H55071 T-REX 550E/ 600E PRO/ 700E
Thanks,
The motor I am running is the HKIII 4035-450kv with the 11t (55071). works very well. If your not going to be doing med-hard 3d you may want to go down to a 330-400ish kv. this will be even easier on the power system, and ALIGN has 3 pinion sizes, 11T(H55071), 12(stock) and 13T(H60225). so you do have a few options. As far as motor heat, the scorpions are rated all the way to about 400 degrees F. so if your scorp is below 200 its fine and well below threshold. the ALIGN motors can not take nearly as much heat/abuse as the scorps in my experience.
Hope this helps..
AnythingHeli.com OWNER/ TEAM PILOT
GAUI X5 / X7 *
GOBLIN G380/R420/G500-x2/R580/G650/R700/G770 (and many others)* Swinging Rotortech Blades * OMP M1 & M2 * MSH Brain * * iX12*
akamullen is offline        Reply With Quote Quick reply to this message
Old 02-27-2012, 09:08 PM   #25 (permalink)
Dave, how do you think the Align 470kv motor will hold up with the 11th pinion. Should I be planning on a new motor?
Citizen 242
NC_2_VA is offline        Reply With Quote Quick reply to this message
Old 02-27-2012, 09:24 PM   #26 (permalink)
Is the 400kv motor not as powerfull as the 450?
Bank account EMPTY
Old 02-27-2012, 09:43 PM   #27 (permalink)
KV is only RPM per volt, it does not dictate power, only RPM. To find out the power of a motor you will have to look at the specs, this will show the wattage/power. But remember not all motors are created equal, some have higher efficiency than others. this can make finding out what motor has more power harder than just a wattage number. From what I have flown and seen, the HKIII motors are performing better than the align motors. HKIII 4035's come in 330, 450, 500, 530, and 560 KV's.
I would say if your not looking for high headspeed, or tic tocs and piroflips, and you want nice long 7-10 minute flights, grab the 330 and try the 13T, that should be good around 1400-1600. Those numbers are just my guesses, but they should be close. You may want to calculate for yourself.
GAUI X5 / X7 *
Old 02-27-2012, 10:50 PM   #28 (permalink)
4035-400 and 450 seem to have the same specs,hopefully the power out of the 400 is good,I like to tic tok.I guess ill find out soon enough,waiting for my frames and blades to show up
Bank account EMPTY
Old 02-27-2012, 11:19 PM   #29 (permalink)
I did not think that scorpion made a 4035-400kv. The new HKIII jumps from 330 to 450. Also the newer HKIII's do have better efficiency and power than the older HKII's
GAUI X5 / X7 *
Old 02-27-2012, 11:43 PM   #30 (permalink)
I guess its the older one.its actually a hyperion.rebranded Scorpio from what I read.
http://www.hyperion-eu.com/products/...HP-HS4035-0400
Bank account EMPTY
Old 02-28-2012, 12:19 AM   #31 (permalink)
A friend of mine moved the elevator servo to the back, instead of the ESC tray, it works great for him, that could be a solution for a bigger motor.
Henseleit TDR!
Trex 800E F3C; Trex 550FB
I have no life anymore - only heli's in my head..
wonderd is offline        Reply With Quote Quick reply to this message
Old 02-28-2012, 02:43 AM   #32 (permalink)
Default 800 motor
AkaMullen, that was a very nice video in the "why a 800?" thread (hint). Maybe since you have a new motor, I believe you were flying the Align at the time, you could share another one. Also any advice on setup would be great. The Align seems like a beast of a motor other than it bogged easily with the big 800 blades and got hot easily. I'm not quite as good a flier as you and haven't flown my 800 a lot but wondering how happy you are with the Scorpion power.
Thanks for all the advice, Alden
Old 02-28-2012, 02:58 AM   #33 (permalink)
Thanks, but I was really quite taken on that first maiden with the 800mm blades. I was watching more than flying..lol..
was flying a HKIII 500kv in that video with an 11T @ 1700, the 450kv with the 11t runs WAY better as now its geared close to where it should be.
GAUI X5 / X7 *
Old 03-01-2012, 12:17 PM   #34 (permalink)
akamullen,
How does the Scorpion HKIII 4035 motor compare to the 700MX, power wise? Is it a noticeable upgrade?
Edit:
Never mind. I see that Dave already answered this question on a previous page.
NRPY is offline        Reply With Quote Quick reply to this message
Old 08-16-2012, 09:29 PM   #35 (permalink)
Default Trex 800 DFC
Well here it is......... the Trex 800 DFC. And to think I just bought the 700 DFC...
http://www.facebook.com/media/set/?s...3419543&type=3
Trex 450 Sport, Trex 450 Pro 3GX, Trex 600, Raptor 50
avin89 is offline        Reply With Quote Quick reply to this message
Old 08-17-2012, 08:22 AM   #36 (permalink)
I been waiting for a trex 800. They have a picture online of it beside a logo xxtreme 800 and their's not that much diffrence in size
Street Brothers motoclub
R1Ryder is offline        Reply With Quote Quick reply to this message
Old 08-17-2012, 09:17 AM   #37 (permalink)
Do you have a link?
Sent from my mobile phone - I apologize for any spelling errors
Jotto is offline        Reply With Quote Quick reply to this message
Old 08-17-2012, 09:42 AM   #38 (permalink)
Me too going to pick up my 700 dfc in a little while.. no biggie its sweet ..if i ever go 800 i would go EXTREMEbaby!! badass
Always thanks for the help much appreciated makes the hobby alot easier and enjoyablesince i began flying in dec.2011
Indydrt is offline        Reply With Quote Quick reply to this message
Old 08-17-2012, 03:51 PM   #39 (permalink)
Originally Posted by Jotto View Post
Do you have a link?
Go to bottom of page
http://www.rcmania.hk/article-968-1.html#.UC67G4GwWA1
TODDC is offline        Reply With Quote Quick reply to this message
Old 08-17-2012, 04:15 PM   #40 (permalink)
see adjustable link rods from crank bell horn to swash... like thoose rods
SA1000E . MiniVolt-500.CncEfects: K7-1000E K6-800E. K700E.K550-600
Align:2x Trex 450 Dominator 6s. 2x Trex 550E 4× BeastX- 3× Vbar- 3× Spartan VX1n- 1× Sk720
runesb is offline        Reply With Quote Quick reply to this message
