Old 08-09-2012, 11:48 PM   #1 (permalink)
Red face Logo 600 3D High vibration with Scorpion 4035-560 III
Well the title sort of says it. I recently had a little miss hap with my logo the other day forced auto in a really bad spot and ended up causing some damage to the canopy and lipo.
Any way im putting it back together right now. I have a scorpion 4035 560 motor. Running just the motor I am getting around 100 vibration from the v bar vibration analysis. This seems like a lot of vibration for just the motor running and not turning anything else in the drive train. I figured shaft must be bent so changed out the shaft with brand new one on the motor. Spun it up again and same vibration amount.
What do you guys think normal? Should I be thinking about buying a new motor or not worry about it?
Thanks for the advice.
Lee
leedawg is offline        Reply With Quote Quick reply to this message
Old 08-10-2012, 02:30 AM   #2 (permalink)
Interesting, I never thought of that. I had a crash a while ago and rebuilt, only to have this real bad vibration in the tail. So I assume its a tail issue. I rebuild the whole tail. New hub/ berings in the blade grips/ New tail fin, New tail rotor shaft and new flanged berings that press into the carbon fiber. Basically everything. I also switched to a carbon fiber tail boom because the temperature change here is extreme from inside to outside. I figure it would help with belt adjustment. So, I test fly it. It seems better but is still vibrating. It flys fine but I dont like it. So I change the feathering shaft as that is the last thing i didnt change. It made no difference. I used new frames/ mainshaft berings. Still there. I wonder if it could be the motor. There seems to be slight play in the can. maybe ill try swaping it out. I also have a new mainshaft on the way. I used a new one to rebuild but it seems ever so slightly tweeked. I cant tell if the head button is just off or if the shaft is actually wobbling. I thought i was down to my last resort, now I have 2 things to try.
motorcycleguyr1 is offline        Reply With Quote Quick reply to this message
Old 08-10-2012, 05:15 AM   #3 (permalink)
Is it possible the pinion can get a little "tweaked" after a crash,? I'm sure you ran the motor without the pinion?
wrongler
wrongler is offline        Reply With Quote Quick reply to this message
Old 08-10-2012, 06:38 AM   #4 (permalink)
Did you change the motor bearing out when you changed the shaft? Also, I've had vibes appear at motor frequency just from having the motor slightly tweaked when mounting it. I have no idea how it happened or how to ensure its not tweaked. All I know is I had motor vibes disappear after I re-mounted the motor bolts. LOL
Good luck!
Team Mikado USA!!!
Team Scorpion!
Logo 600SX - Scorpion 4035-560, 10s 4400 packs
Logo 690SX - Stock Scorpion motor, 12s 4500 packs
sgrim80 is offline        Reply With Quote Quick reply to this message
Old 08-10-2012, 11:13 AM   #5 (permalink)
Yeah id check out the motor. Run the motor just mounted to the block without the pinion and see what kinda vibes you are getting. I was surprised how much vibration I was getting from just the main motor.
I did run without the pinion so it ranges from about 70-160 in vibration at varying RPM
Good luck!
No did not change the motor bearings they felt really good no notciness or anything perhaps I should have changed the bearings, or still should. I suppose it will fly fine was just surprised how much vibration is present without any other parts moving. And hope that I am under 200 with the rotor and tail spinning. once my parts get here I will know. I was more curious if anybody else was this high or if I should be tracking down the cause of this. Its almost like the motor is not perfectly balanced however I have no idea how I would make it better im terrible at balancing things. Im going to try mounting it differently and running it again and seeing if that makes much of a difference.
Old 08-14-2012, 06:58 AM   #6 (permalink)
Default vibrate
i have vibrate to after crach. and i check bcouse of these..
these i made my self....
SA NOW is offline        Reply With Quote Quick reply to this message
Old 08-14-2012, 06:51 PM   #7 (permalink)
Its also possible that the out-runner motor section was bent in the crash. Easy enough to check with a dial indicator.
Wayne
Logo 480 / Logo 600sx / Logo 690 / Logo 700 / Vbar Control
Mentalic is offline        Reply With Quote Quick reply to this message
Old 08-14-2012, 10:24 PM   #8 (permalink)
Originally Posted by SA NOW View Post
Attachment 340317
good job man ,nice
BLACKOUT MINI,ZMR 250,TBS Discovery ,Zephyr 2
TARANIS X9D + ,ez-uhf jr mod
GauiX5 Gauix3
kachur779 is offline        Reply With Quote Quick reply to this message
Old 08-15-2012, 12:18 AM   #9 (permalink)
100 is low isnt it? I woouldnt be to worried about that?
600 DFC HV
Pilot Brandon J.
bj660raptor is offline        Reply With Quote Quick reply to this message
Old 08-15-2012, 07:45 PM   #10 (permalink)
It's hard to say without actually spinning everything up. I would hold any opinions until you have run with the main and tail rotor engaged.
gravydrive is offline        Reply With Quote Quick reply to this message
