Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 550
Hurricane 550 Discussion and support of the Gaui Hurricane 550
Old 12-30-2011, 01:47 AM   #61 (permalink)
Originally Posted by MrHeliNewbie View Post
What size main shaft are you using ???????? 8MM or 10MM
What to see if I can use this head on my Tarot 9s 550 8mm shaft
It's an 8mm shaft - where did you buy the Tarot 550, I've never seen the kit for sale ...
Old 12-30-2011, 06:58 AM   #62 (permalink)
It was not a kit. Its a scrap build 500/550 main frame with a 4mm rear drive belt. I have the pulleys to setup for 6mm rear belt once I install the new 550 tarot boom. RC-Tec i2 is making a custom boom block for it once he frees up some time. ( hopefully ) This low profile head well give me more room to re-cut the step in the main shaft for the lower bearing block. This head well also save me from making blades grips as on this post they said the X5 blade grip are 12mm root. So the X4 main head block with the X5 grips would work nicely for me.
Tarot makes the same line as Align its just finding sources for the kits and parts. Please read my Sig....... I'm not an Align fan as I see a lot of helis out there are better. I love the TDR drive line..... Would love to do a custom TDR drive line heli. Just using the drive line with a Direct to swash servo set up.
Align parts are just easier for me to get at the LHS. My next heli well be a Gaui 550 or there new x5.... I wish I could see both the 550 and x5 side by side every veiw of the heli. I thought about the one for sell in the forums.....but the price is about the same as I can order a new combo kit. I just need the basic kit as I have everything esle i would need . Maybe this coming summer I can start one.
I know the power I'm getting out of this Tarot custom is nuts........Scorpion 4020-910 with 3-3s 3000mah battery's, Ice2 HV 80 ESC. I pull 37amps on a hard drive pull.... Thats the highest amp pull I have read from the ESC. Head speed was 3100 start with a 2800 finish. I have lowered the speed to 2800 starting. I have the power of an 600 class with the weight of a heavy 500.
Tarot 500/550 9s / Tarot 450ProV2 4s / 600E V1 8s
Academy Of Model Aeronautics 98418
If Align put their name on a pile of dog crap stuck 2 blades in it and packaged it in a super combo, people would get in line to pre order. I just dont get it
MrHeliNewbie is offline        Reply With Quote Quick reply to this message
Old 12-30-2011, 07:04 AM   #63 (permalink)
I know the power I'm getting out of this Tarot custom is nuts.........I have the power of an 600 class with the weight of a heavy 500.
Thanks - I only asked as I have a Tarot 450 Pro and a number of clones that are gradually changing into Tarot's, they have a good balance of value and quality Just like Gaui
Old 12-30-2011, 12:13 PM   #64 (permalink)
Ya the new Tarot 450Pro v3 FBL super combo from them 239.00 WOW what a price for a great smaller heli.
Witch of the Gaui heli's do you like.... 550H or the X5 lite ???? I like the rear belt drive makes it easier to do a strech platfrom.
Old 12-30-2011, 12:46 PM   #65 (permalink)
I have 2 x 550 - one with 550mm blades, the other with 500mm blades (and a shorter boom), the 550 is the most flexible and versatile heli I know of - 3 boom lengths, 4 blades sizes, almost infinite gearing options etc.. However it is now 4 years old and if I were coming to it afresh I would get the X5 - I will at some stage, probably when I run out of Hurricane spares.
Old 01-06-2012, 10:42 PM   #66 (permalink)
Thats easy......Don't crash....
Blade 500x , dx8
Two retired Gaui 550 hurricanes (Sold)
mjdee14 is offline        Reply With Quote Quick reply to this message
Old 01-12-2012, 08:21 AM   #67 (permalink)
Anyone know where I can get the parts for this head mod X4 main block X5 grips......
I have been every where.... I can't find everything I need from one place .
Old 01-13-2012, 12:59 AM   #68 (permalink)
www.flying-hobby.com appear to have enough parts in stock
the x4 head is available as a set of parts -
http://www.flying-hobby.com/shop/fes...st-p-7888.html
and the x5 grips are in stock too.
TRex 450 SEv2, Hurricane 550, Gaui 330 quad, all controlled with a JR dsx9.
hack happy
japester is offline        Reply With Quote Quick reply to this message
Old 02-25-2012, 02:03 PM   #69 (permalink)
In getting ready for the flying season, I did something I meant to do last year. The nylock nut on the jesus bolt for the X5 head stuck out too far. I ground it down as far as I dared for testing and it worked good. Well today, I replaced the nut with one from my plastic frames. Works great, no binding anywhere. It's a shame it's 29F and snowing or else I'd test it out.
Scott
KBDD Team Pilot ):>
Old 02-26-2012, 09:02 AM   #70 (permalink)
Vas,
What would you say are the main differences in flying behavior between your Low Rider Hurricane and your X5? If I purchased an X-5 would I be able to move my X4 FBL head over as long as I changed the grips? Also, is the main shaft 8mm?
Thanks!
Gaui X5, Blade 180 cfx & Blade Nano cpx, Private Pilot (Instr.)
TunaBlue is offline        Reply With Quote Quick reply to this message
Old 02-27-2012, 11:22 PM   #71 (permalink)
I just ordered the X5 full head assembly and AR7200X. Hopefully my build goes off smoothly.
stang9779 is offline        Reply With Quote Quick reply to this message
Old 11-08-2014, 05:31 PM   #72 (permalink)
I was going to start a new thread . . . . . but I always come back to this thread and I have for some time. A well overdue project after this original thread started but here goes. . . . I have recently converted my TRex450s to FBL and built an HK450V2 5bladed Head FBL. Now I have just converted my 550 Hurricane to LOWRIDER FBL, all helis running ZYXS/3.5/3D Soft stock settings.
LONG LIVE THE HURRICANE!!
Installed:
- X4 Head block
- X4 Main Shaft
- X4 Washout Assembly
- X4 CNC Stop Button
- X5 CNC Main Blade Grips 208343
- X5 Washer pack 208781
- Main Blade Grip Extensions
- TRex450 1.8x34mm Titanium Turnbuckles
- Long balls on the upper swash for the links to blade grip extensions
- Red 95 grade Dampers
- Plus a stack off spare bearings, dampers, shafts, spindles. . . . . .enough parts to build 5 heads.
Thanks to Torana74 for starting this thread, providing such great information, making this build a dropin plug and play head conversion. . . . . .the Hurricane always lives on. Flight tests went without a hitch straight off the bench. My next project is to FBL my SDX50 over the xmas break.
ID:	548137   Click image for larger version
ID:	548138   Click image for larger version
ID:	548139   Click image for larger version
What componants you install and your flying skills is what make a good flying heli.
masjo is offline        Reply With Quote Quick reply to this message
Old 11-08-2014, 09:55 PM   #73 (permalink)
HF MR Support
VIVA LA HURRICANE !!!!
...Need a 3000mah 6s and a new canopy....
Gaui 550(Need GOT ONE!) / KK2.1.5 steveis pro/ZMR250 / Alien 450 camera ship / HJ 450 all W/KK2.1.5 Steveis pro Estes Nano/ Hubsan X4 / Syma X1
AMA 953414 CONTRIBUTOR, TEAM LAVAQUAD
PTcaflyer is offline        Reply With Quote Quick reply to this message
Old 11-08-2014, 10:02 PM   #74 (permalink)
Default some more pics
had 2 more test flights this morning and all is very well
ID:	548179   Click image for larger version
ID:	548180   Click image for larger version
Old 11-08-2014, 10:23 PM   #75 (permalink)
HF MR Support
Very Nice!
I have a X5 tail boom on mine(Black Anodized) and that yellow canopy would look SUPER!
PT
Old 11-09-2014, 05:04 AM   #76 (permalink)
Is that the entire x4 head assembly or just the center with x5 grips
weav01 is offline        Reply With Quote Quick reply to this message
Old 11-09-2014, 04:55 PM   #77 (permalink)
Thanks PT. Also a black tail boom would look nice with a Gaui 550 CNC tail box. . . . . . .hmmmmm!
weav01: all X4 - head block, main shaft and washout assembly with X5 grips.
Old 11-15-2014, 10:21 PM   #78 (permalink)
Default Teaser Vid. . . . . .
Hi guys . . . . . just a quick teaser vid hovering on the drive.
EP550 Hurricane FBL ZYX-S (2 min 31 sec)
Old 11-15-2014, 11:49 PM   #79 (permalink)
HF MR Support
....AWWWW ! Sweet music in the key of "Gaui" LOL!!!
Old 09-24-2015, 10:27 PM   #80 (permalink)
Default Has anyone tried the Gaui X4 stock head and grips?
Just wondering if anyone has converted their Gaui 425 or 550 FB Gaui to FBL using the stock Gaui X4 II FBL Rotor head Assy (8mm shaft) with the standard stock Gaui swash, using BeastX? I know the X4 grips would not support the 550 blades, but should work with 500 size blades, if so, were you able to get the Blue light with this setup using BeastX? Thanks for any thoughts, Dave
Last edited by BoaterDave; 09-24-2015 at 10:36 PM.. Reason: Punctuation change only...
BoaterDave is offline        Reply With Quote Quick reply to this message
