Old 09-07-2011, 11:40 PM   #21 (permalink)
Originally Posted by smaze17 View Post
nice....thanks
got a link?
Here buddy,
http://www.ebay.com/itm/Align-T-Rex-...item3f0dc31368
Align T-Rex Family Owner - MicrobeastX - 7200BX
450 Dominator, 500 Dominator, 500(Airwolf) Four Blades, 550 DFC, 600N DFC OS55HZ, 700N DFC 105HZ-R, 700 DFC HK4525-520LE
Roger Palacio is offline        Reply With Quote Quick reply to this message
Old 09-08-2011, 12:54 AM   #22 (permalink)
Thanks, Roger!
AMA 373608
K2Freak is offline        Reply With Quote Quick reply to this message
Old 09-08-2011, 04:11 AM   #23 (permalink)
Originally Posted by haq0901 View Post
This is Incorrect! NEW TAIL HOLDER has 3 bearing on each grip. When they refer to 2 bearing on each grip it does not include the 1 that closest to the hub which is considered being a 3rd bearing making a total of six on the newest align part. Order of bearings on new part will be a bearing - thrust bearing - bearing - bolt
I dont understand you. What is incorrect?
The HN6103A has the same amount of bearings, same size and in same positions as my 700E v2 tail has. From tail rotor shaft and out, first two radial bearings, then one thrust bearing.
http://www.align.com.tw/shop/product...oducts_id=4022
Are we still saying that I have another tail than the 'v2 HN6103A' ? It looks very like, with same no of bearings, size and placements...
Printscreen from 700Ev2 manual @ align.
[Edit] changed size of prntscr
AAKEE is offline        Reply With Quote Quick reply to this message
Old 09-08-2011, 08:05 AM   #24 (permalink)
the tail hubs and bearings system where being used this pasted weekend at the Align Fun Fly.
Dino Spadaccini Team Capt Align Factory Team USA / Team Futaba
Dino Spadaccini is offline        Reply With Quote Quick reply to this message
Old 09-08-2011, 08:42 AM   #25 (permalink)
I guess I'm wrong because on my v2 manual I have the old style 1 bearing 1 thrust bearing setup.... Yet your picture shows clearly the 2 bearing setup....
How many versions of the v2 kit are out?
Mikado - TP - Egodrift - TORQ - RotorTech
haq0901 is offline        Reply With Quote Quick reply to this message
Old 09-08-2011, 01:42 PM   #26 (permalink)
It's possible to add a second radial bearing to the stock tail grips. You just need to use a round headed bolt otherwise the stock square headed bolt will rub on the tail blades. I've done it on my 700n and it reduces the slop quite significantly.
J-S-Q is offline        Reply With Quote Quick reply to this message
Old 09-08-2011, 01:46 PM   #27 (permalink)
I believe KDE has an upgrade for the tail that does exactly that.
Chris_M is offline        Reply With Quote Quick reply to this message
Old 09-08-2011, 01:49 PM   #28 (permalink)
Yes they do although you can also just buy the bearings and bolts yourself (and possibly an additional washer, I can't quite remember) which is cheaper. The KDE upgrade does include some additional stuff though, like CNC tail pitch links which justify the extra cost.
Old 09-08-2011, 02:34 PM   #29 (permalink)
The KDE Upgrade nor adding the bearing and bolts yourself is the same thing as the new tail design. Bearing count may be the same but that was never the core issue.
The bolts that secure the tail grips were what was breaking, even the 12.9 Bolts some people put on failed. In the case of the old design, and KDE design, the bolt is what took the side load for the outer bearing as well as the thrust bearing.
In the new design, it is more like the Quick UK Tail in that the Tail Hub extends up through the bearings and the tail hub which is larger and more robust takes the side loads. Much better design.
Synergy N5C sitting in Box...
Mystic3D is offline        Reply With Quote Quick reply to this message
Old 09-08-2011, 03:03 PM   #30 (permalink)
TT
Agreed! I'm using KDE upgrade in the plasic grips (nice...no slop) but might switch to these when a replacement hub becomes available. As you said, much better design.
TT is offline        Reply With Quote Quick reply to this message
Old 09-08-2011, 03:11 PM   #31 (permalink)
The bolts that secure the tail grips were what was breaking, even the 12.9 Bolts some people put on failed. In the case of the old design, and KDE design, the bolt is what took the side load for the outer bearing as well as the trust bearing.
Yes, I see what you mean. Interesting info.
Old 09-08-2011, 04:11 PM   #32 (permalink)
I want the new tail so I can take off the 600N Plastic Tail, which does not fail but does develop slop.
Just do not want to order from Helipross, which along with Top-RC Force seems to be the only ones who "say" they have in stock
Old 09-08-2011, 05:51 PM   #33 (permalink)
I ordered one from the eBay link above. Good price as well.
AMA 373608
Old 09-08-2011, 06:12 PM   #34 (permalink)
+1 - Ordered. At least with Ebay I have recourse..
Old 09-08-2011, 06:44 PM   #35 (permalink)
Thanks for the linkage,got one ? Where is sherie store? China or something?
600 DFC HV
Pilot Brandon J.
bj660raptor is offline        Reply With Quote Quick reply to this message
Old 09-08-2011, 06:51 PM   #36 (permalink)
Taiwan.
T-REX 700E VBAR
T-REX 450 PRO BEASTX
MajorPayne is offline        Reply With Quote Quick reply to this message
Old 09-09-2011, 04:10 PM   #37 (permalink)
I just ordered with expedited shipping (EMS) so hopefully I will get one within 3 to 5 days. I was hoping to order one from the US but who knows when the US stores will get their shipment.
I just don't trust the existing tail as is. I just bought the KDE V2 tail upgrade kit for the second bearing and metal arms that I just installed yesterday but there are a few things that concern me. The head on the KDE bolt is smaller. The extra weight of the extra bearing was not originally part of the hub design so I wonder how much more force is on the tail blades with the KDE tail V2 upgrade kit. I have still read of reports of the bolt snapping as mentioned by someone else in this thread. $41 is worth the money to get this new tail to me for peace of mind. I can see that the bolt is not supporting the radial loads with the new design because the end radial bearing is on the hub itself instead of the bolt like the KDE V2 upgrade kit.
Well... actually I will probably just be a guinea pig for the new design. Doh! <scrambling to cancel my order> . Seriously though I am looking forward to this new tail for both looks and safety.
StatiC is offline        Reply With Quote Quick reply to this message
Old 09-09-2011, 04:23 PM   #38 (permalink)
+1 Prob the best $$ we can spend on an upgrade.
EMS is quick, I did also
Old 09-10-2011, 11:06 AM   #39 (permalink)
This is what came with my 600e pro.
NO FLYBARS
504Rone is offline        Reply With Quote Quick reply to this message
Old 09-11-2011, 01:49 AM   #40 (permalink)
Why not in_to_the_mystic? I want a lot of new upgrades and they have most of the new designs. I also check on net and lotsa guys indicated they got good and bad service so ima bit cautious.
The guy from ebay is also in taiwan and guess the only country he does not ship to.... Africa, lucky me , hench me asking for helipross
Has anyone bought from the Align online shop?
T-Rex 700E (700MX (BOCA #7) / DS610 & DS650 / 3GX / CC ICE 2 HV 120 / Radix 690 SB / Rotortech 105 / Nano-Tech 4500mAh 25-50C)
dvillijs is offline        Reply With Quote Quick reply to this message
