600 Class Electric Helicopters 600 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
12-24-2012, 07:27 AM | #1 (permalink) |
Align 600mx 1220kV motor
Oh my goodness, trying to find the PWM rate for this motor. I cannot find it in the specs ANYWHERE!
I see some people are using 8 and others 12. So there is no definitive answer there. Does anyone have any documentation what is the correct value? Thanks a bunch. |
12-25-2012, 08:33 AM | #2 (permalink) |
You only want to use 6s on that motor. the 12s motor is the 600MX 510kv motor. The 1220kv is for the ESP or 550E.
Blade MCP-X Brushless, 300CFX, , Trex 450 Pro v2, Trex 600 ESP 6s 3GX v.3.1 and KDE head, Rotormast V-22, Futaba 12Z controle!! |
12-25-2012, 11:19 AM | #3 (permalink) |
He's not asking number of cells. This is a castle setting.
To the op, as you've seen there is no single "correct" setting. It's a balance between performance and efficiency (read: heat). Some will try different setting to see what works best. If I get s chance, I'll take a look at my settingand post it. Merry Christmas! Sent from my SPH-L900 using Tapatalk 2 |
12-27-2012, 09:49 AM | #4 (permalink) | |
Probably doesn't really matter that much, jus choose the one you are comfortable with. If the ESC temp is staying reasonable, as seen in the logs, go for 12kHz. |
12-27-2012, 11:36 AM | #5 (permalink) |
HF Scale Support
I found a forumula that guys flying scale have used in motors where it is not listed. Setting to 8 or 12 will produce similar flying results but the heat may be higher with one than the other. If you have a thermal temp probe, that may help set the optimum rate for your installation. Here is the formula: Motor KV x Motor Pole Count x Nominal Volts Used / 20. For your particular setup, I get an answer of 13,542 which is close to 12. You will not damage the motor trying either setting out. Take care.
Don |
12-27-2012, 06:46 PM | #6 (permalink) |
I used to use all the time 12kHz with my burned CC 80 amp and the same motor you have and nothing has never happened. Now I rebuild my bird after a terrible crash and I will use my stock Align ESC.
12-27-2012, 10:17 PM | #7 (permalink) |
Thanks everyone. I will try both and check the temps with an infra-red temp gauge.
does anyone know the proper timing for this thing? Another "great unknown." I am starting with 15* |
12-28-2012, 10:08 AM | #8 (permalink) | |
What you want to look at is the ESC. I thought you had an CC ICE. If so, clear the log and enable the temperature parameter. That will tell you how hot the ESC is getting. |
12-28-2012, 07:55 PM | #9 (permalink) |
CC ICE 80HV is on my Furion6.
Using a Hobbywing 100A LV on the 550E. |
07-03-2013, 12:39 AM | #10 (permalink) | |
