Go Back   HeliFreak > R/C Helicopter Support > Miniature Aircraft Helicopters > MA Gas
MA Gas Miniature Aircraft Gas Helicopter Support Forum
Old 05-09-2013, 10:13 AM   #1 (permalink)
Default Flip your clutch
If you have a whiplash gasser I've found that running the clutch with the arrows pointing DOWN instead of up is the better way to go. This makes it bit nose in instead of tail in and the same way as my Spectra and 1005 gassers.
The zenoah clutch was designed to be used on rc cars and I expect that they put arrows on it to run tail in to make it bite less aggressively for car tires. Helicopter blades have alot more mass and will work better with the nose in setup.
Flipping the clutch will eliminate tail chatter when the engine in unloaded at rpms.
You may also want to change the location of the wave washers to make sure everything runs true. I've done a couple of videos on this in the gasser forum here.
Best regards,
-=>Raja.
MA 1005, Hanson 270, 4717 flts, Spectra-g, Hanson 270, 3672 flts
Whiplash-g V1-2, Hanson 300, 2235 flts, Whiplash-g V2, Hanson 300, 1552 flts
Whiplash Turbine, TS 45i WSE, 296 flts
Jewel on-board Generators, Miniature Aircraft Team Manager
rbort is online now        Reply With Quote Quick reply to this message
Old 05-11-2013, 07:54 PM   #2 (permalink)
Best regards,
-=>Raja.
I have been fighting tail chatter or wawa's when the coming back through zero degrees. Could this be part of the problem?
I though it was a tuning problem
We had a great country once. You know what made it great? “I can.” Then the weak came along, “the I cant’s” and destroyed it.
Rudy is offline        Reply With Quote Quick reply to this message
Old 05-11-2013, 11:57 PM   #3 (permalink)
Default Yes this helped me
And also don't oil the sprag, too much oil can make the one way skip and slip plus seep into the bell area.
-=>Raja.
Old 05-12-2013, 06:28 AM   #4 (permalink)
Ok I will be dropping the engine today to check it out.
Just in case who stocks clutches for these, and are there different types/speeds?
One other thing on my 2nd tank (ever) I hot started the engine. The clutch bell got nice and hot melting the glue holding in the clutch liner and it slipped down so it was touching the side frames. I sent the clutch bell back to MA and they fixed that up. I did look at the clutch it self and it "looked" fine. Could I have toasted it then?
Old 05-12-2013, 04:21 PM   #5 (permalink)
The clutch shoes are pretty robust, usually a degrease with solvent and a light scuff with some sandpaper and you are good to go.
I have started pinning the liners so it can never slip again.
Occasional wag and a bit of carb/ gov hunting when quickly unloading to 0 pitch is not uncommon on a gasser, the key is knowing what is normal and what is excessive.
Tom
TRM Power
CAUTION - my posts are based on my experiences, yours may be different.
fastflyer20 is offline        Reply With Quote Quick reply to this message
Old 06-03-2013, 09:17 PM   #6 (permalink)
Well I pulled the engine tonight and found some oil/grease inside the clutch bell. I cleaned the inside of the clutch bell and wiped down the clutch bell.
Old 06-03-2013, 09:58 PM   #7 (permalink)
There are spacers in the bottom of the shoes, press them out, clean and install in the other side of the shoe when you flip the shoes over
Tom
TRM Power
Old 06-03-2013, 10:07 PM   #8 (permalink)
Default I'm not a big fan of those
Flange washers bolt shank "extenders"...Would be best if you replaced them with a shouldered bolt of the right size like this:
http://www.grainger.com/Grainger/Sho...U30?Pid=search
-=>Raja.
Old 06-03-2013, 10:10 PM   #9 (permalink)
Well thank you for pointing that out.
I need to look better
Old 06-03-2013, 10:17 PM   #10 (permalink)
-=>Raja.
There is a grainger store right down the street from my hotel and they have these in stock.
Old 06-04-2013, 10:30 AM   #11 (permalink)
Default If you get a packet of 5
Save me one if you can, I have an orphan here I could pair it with and thanks! You could leave it with Larry and I'll pay you for it.
-=>Raja.
Old 06-04-2013, 12:36 PM   #12 (permalink)
-=>Raja.
Yep I picked up a 5 pack and will leave the odd man out with Larry next time I see him.
Old 06-05-2013, 05:33 AM   #13 (permalink)
Good idea Raja, I will order some in.
Just an FYI, Grainger is convenient, but in the last few years their prices have gone through the roof. McMaster sells these individually, in qty of 5 or greater for $1.18 each. In the past I used Grainger for home and work all the time, but not anymore.
Tom
TRM Power
Old 06-05-2013, 09:36 AM   #14 (permalink)
Default Yeah they are expensive for sure
But I was able to drive there about 45 minutes from my house and pick them up.
-=>Raja.
Old 06-05-2013, 10:09 AM   #15 (permalink)
One more quick question. If we remove the Flange washers, do you put some other washer under there?
If so do you know the size?
Old 06-05-2013, 09:52 PM   #16 (permalink)
Default yup
Would be the washers that came with the engine clutch originally. Hanson USED to include them but I think he stopped thinking that are not necessary. You could call him for a set I'm sure to be put in an envelope for you.
-=>Raja.
Old 06-05-2013, 10:06 PM   #17 (permalink)
I found mine and every thing is back together. The clutch is a little tight when I spend the head. But will fire it up in the next day or so.
Old 06-06-2013, 08:50 PM   #18 (permalink)
Default Make sure
That you put the original washers first, then the one way adapter, then the wave washers, and then the screws. So wave washers on top of the adapter not below, ok?
This way the clutch should be able to spin without dragging the bell around when you pull the chord.
-=>Raja.
Old 06-07-2013, 05:55 AM   #19 (permalink)
I installed every thing like it said in the instructions, except I used the two washers instead of the flanger washers and I flipped the clutch over. I also used the new bolts.
So I put the wave washers between the clutch and the adaptor, They need to be on top?
Old 06-07-2013, 09:33 AM   #20 (permalink)
Default Yes
So I put the wave washers between the clutch and the adapter, They need to be on top?
I put them on top because it will lower everything down so that the adapter won't touch the ceiling of the clutch bell. Washers on the bottom are higher than the flange washers that were there before. By putting the wave washers on top you end up with the same net end result in height.
-=>Raja.
