Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > NX4
NX4 Discussion and support of the Gaui NX4 Nitro Helicopter
Old 07-03-2013, 02:57 PM   #1 (permalink)
Default NX4 - Clutch and bearings Broke
Hello
My NX4 broke and ate the clutch bearings support the pinion / starter with only 4 flights without 3D, only on hover.
In the fifth flight was attempting to start the engine and could not, he ran after it and just spun around and erased.
Anyone had this problem? Apparently this all normal in the assembly, the clutch bell was aligned correctly.
Pictures of my build on the link below
https://www.facebook.com/media/set/?...9685251&type=1
Diniz Hobby
Gaui Brazil Distributor
www.dinizhobby.com.br
dinizhobby is offline        Reply With Quote Quick reply to this message
Old 07-03-2013, 08:05 PM   #2 (permalink)
Can you post pics of the damage?
Fusion 180 - M2 Evo - RAW 420 - Fusion 550 - Tron 5.5 - Kraken 580 - Kraken 580n - Kraken 700 - Kraken 700n - Vcontrol Evo
vertico is offline        Reply With Quote Quick reply to this message
Old 07-05-2013, 02:33 PM   #3 (permalink)
Some pictures below:
Diniz Hobby
Old 07-06-2013, 01:05 AM   #4 (permalink)
Yes - my clutch also broke the other day..
https://www.helifreak.com/showthread.php?t=545275
The problem is - I only run 0% nitro - so not even giving it anywhere near the power it should if i was using 30% nitro
Seems there is too much gap between the clutch and liner - thus stressing out the joint of the clutch shoes.. I think we need to source a thicker liner..
So if anyone knows of a clutch liner that's a little thicker then the NX4's - please let us know.
DX7 Mode-1 | 450 pro 6s | 450 pro | Schweizer 300C Gasser Scale | T-Rex550e | Aeolus 50 | HeliX T-Rex700 fbl Gasser | HWC600 Gasser | Henseleit MPXLe | Henseleit 3DNT | Suzi-Janis 700 | Gaui NX4 | Gaui X5 | Blade 350QX
jockstrap is offline        Reply With Quote Quick reply to this message
Old 07-06-2013, 09:31 AM   #5 (permalink)
Geese I still have not flown mine yet and so far I've replaced the slider and hub and now need to replace the liner, man this copter is a pain and I have not flown it yet.
Blade3d is offline        Reply With Quote Quick reply to this message
Old 07-06-2013, 09:31 AM   #6 (permalink)
Geese I still have not flown mine yet and so far I've replaced the slider and hub and now I need to replace the liner, man this copter is a pain and I have not flown it yet.
Old 07-06-2013, 11:25 AM   #7 (permalink)
i use the lynx clutch liner, no issues here.
dodgeboy is offline        Reply With Quote Quick reply to this message
Old 07-11-2013, 03:20 PM   #8 (permalink)
Did the parts come broke? I found no need to chagne out anything. Both of mine are 100% stock and fly great. I think some of these issues cause panic and next thing you know you spend 2x the amount the heli cost! Build it, fly it and don't worry!
aviator493 is offline        Reply With Quote Quick reply to this message
Old 07-12-2013, 12:24 AM   #9 (permalink)
Build and don't worry on this kit ,, are you kidding.
Old 07-12-2013, 05:09 AM   #10 (permalink)
Yeah, it really depends on your skill level. If all you do is hover, and pitch pump then I believe your heli will last longer. However, if you can throw it around a bit, weak parts reveal themselves a lot quicker. I've had the same clutch problem. I replaced it, and have not had problems since.
BigQ951 is offline        Reply With Quote Quick reply to this message
Old 07-12-2013, 09:00 AM   #11 (permalink)
I purchased a new clutch and put a new liner in my bell the other day..
It seems i ened up with a smaller gap than before so that's good..
Was my first ever clutch liner replacement so was a bit nervous today when testing..
However, had 2 x 10min successful flights and liner seems fine -
So only time will tell now... hope i have better luck with this clutch..
going to give it some more air time tomorrow..
Old 07-12-2013, 05:01 PM   #12 (permalink)
Default Re: NX4 - Clutch and bearings Broke
Oh, I'm sorry. I forgot not all of us can fly like the BigQ. The kit in general is pretty good. But yeah, some have had some pretty big issues. What I was getting at is it seemed like a few posts were aiming at replacing parts based off other people's issues. Fly and fix, don't mess with it if it ain't broke. I did buy the 19T pinion upgrade kit and did have a small issue. JC at Empire always helped quickly. Don't worry, Q, I'll be flying circles around your ass once I'm not living in the hospital half dead!!! Lol
Sent from my DROID RAZR using Tapatalk 2
Old 07-12-2013, 05:03 PM   #13 (permalink)
Just saying don't start ripping out stuff because others had issues. That's just my opinion, if you like to play it safer I 110% respect that. Better really safe than sorry!
Old 07-12-2013, 09:17 PM   #14 (permalink)
If you quit buying helis and start actually flying them you might someday be on my level. You spend more time building then flying..LOL No joke though, my prayers are with you bro. Take the SIM to the hospital. Good luck bro.
V/r
P.S go check out my 1st flight with the 130x in the Blade forum.
Q
Old 07-12-2013, 09:37 PM   #15 (permalink)
V/r
Q
Yeah, it's no fun. Thought surgery put me in remission, but no. Got like 2 trips to field this year! No bueno.... You got a 130 to now? I'll check it out.
Old 07-16-2013, 05:44 AM   #16 (permalink)
No problem with the stock clutch here 100s of flights on 1 clutch and liner .. i think i am due to change the liner out though from my last crash
Gaza-Davies is offline        Reply With Quote Quick reply to this message
