Gasser Helicopters Gasser Specific Discussion |
08-23-2013, 03:53 PM | #21 (permalink) |
Mechanical:
Airframe and conversion kit (if used): Rex 700N/HWC conversion w/DFC Head Engine: TRM VX290TT Carburetor: Stock Walbro Clutch and clutch liner: Stock Century (causing problems, will elaborate later) Pipe and muffler: Century Torpedo V2 Main Blades: Align 3G (690) Tail Blades: Align 105 Main gear and pinion: 103/15 (6.86 ratio) Electrical and Electronic: Receiver: AR7200BX FBL controller: AB7200BX Governor: TBD (thinking Throttle Jockey Pro) Governor sensor: TBD Head speed settings: shooting for 1800/1900/2000 Cyclic servos: Align DS-615 Tail servo: Align DS-655 Throttle servo: Align DS-615 RX&Servo power (battery and regulator and generator if used): LIFE Source 1800 mAh w/ Jewel Generator Battery Monitor: Spektrum Telemetry Power switch: Perfect Regulators Safe Switch 2 TX used: DX8 w/ Telemetry Fuel and field equipment: Fuel, oil, and ratio: White Gas (Coleman Fuel) w/ Klotz Technoplate @ 32:1 Fueling system: old nitro jug w/ DuBro Hand pump Starting Method (if electric, post both stater and battery): Sullivan Dynatron w/ Sullivan wand. 4S 2400 Gens Ace LiPo (so far one charge this season) Dry weight: 12.15 lbs (no rx batt) Flying weight: 12.82 lbs Last edited by bshinn; 08-25-2013 at 02:46 PM.. Reason: Updated info. |
09-16-2013, 04:07 PM | #22 (permalink) |
My Whiplash
I am please to announce the maiden flight of my Whiplash Gasser on 9/14/2013. I'd like to thank everyone here who helped answer questions along the the way. Special thanks to Raja and Carey. Here is my configuration.
Mechanical: Airframe and conversion kit (if used): MA Whiplash Gasser Engine: Hanson 290 3D Max Carburetor: Walbro 990 Clutch and clutch liner: Stock Zenoah clutch and stock Whiplash bell Pipe and muffler: Century V2 Main Blades: Radix 710 V2 Tail Blades: Radix 105 Main gear and pinion: 124T, 18T Electrical and Electronic: Receiver: AR9020 FBL controller: BD-3SX Governor: Futaba GV-1 Governor sensor: Stator Gator Head speed settings: 1750, 1850, 1950 Cyclic servos: MKS BLS 950 Tail servo: MKS BLS990 Throttle servo: MKS BLS 950 RX&Servo power (battery and regulator and generator if used): LIFE Source 2100 mAh, no regulator Battery Monitor: none Power switch: none, using EC3 connectors on the battery line TX used: DX18 Fuel and field equipment: Fuel, oil, and ratio: 87 Octane gas, Penzoil Marine full synthetic 32:1 Fueling system: Jersey Modeler 2.5 gallon Starting Method (if electric, post both stater and battery): Dynatron Dry weight: TBD Flying weight: TBD Other setup details of interest:
This is your brain on helicopters! Trex 700L, Trex 700N DFC HB gasser,Trex 700N V2 HB gasser, Trex 550X. Spirit or BD3SX |
09-24-2013, 02:38 PM | #23 (permalink) |
Strange thing I can't edit my post in this thread.
Suat Trex 700 Gasser FBL | HeliBug HB7-RC 17T | Silverline V-Bar| TRM VX290TT | SG | RJX Gas muffler (modded) Trex 600 Gasser FBL | HeliXHeli conv. | OS GT15HZ | iKon | Homemade onboard generator |
09-24-2013, 05:30 PM | #24 (permalink) |
Still building but should be ready to start the engine by the weekend.
Mechanical: Airframe and conversion kit (if used): Trex 700N/HB7-RC conversion Engine: TRM VX240TT Carburetor: Stock Walbro 990 Clutch and clutch liner: Lynx gas clutch Align blue liner Pipe and muffler: RJX Main Blades: Align 3G (690) Tail Blades: Align 105 Main gear and pinion: 115/17 (6.76 ratio) Electrical and Electronic: Receiver: AR8000 FBL controller: BeastX V3 Governor: TBD Governor sensor: TBD Head speed settings: shooting for 1800/1900/2000 Cyclic servos: Align DS-610 Tail servo: Align DS-650 Throttle servo: Align DS-610 RX&Servo power (battery and regulator and generator if used): LIFE EP Buddy 2300 mAh w/ Powerbug Battery Monitor: Spektrum Telemetry Power switch: JR TX used: DX8 w/ Telemetry Fuel and field equipment: Fuel, oil, and ratio: White Gas (Coleman Fuel) w/ Stihl HP for breakin then HP pro @ 32:1 Fueling system: Prolux Fast Fueller Hand pump Coleman can. Starting Method (if electric, post both stater and battery): Align Super starter. Dry weight: TBD Flying weight: TBD |
09-27-2013, 12:43 AM | #25 (permalink) |
Mechanical:
Airframe and conversion kit (if used): Trex 700N/HB7-RC conversion Engine: TRM VX270TT Carburetor: Walbro 990 Clutch and clutch liner: Lynx gas clutch and liner Pipe and muffler: RJX Main Blades: NHP (710) Tail Blades: Align 105 Main gear and pinion: 115/17 (6.76 ratio) Electrical and Electronic: Receiver: FR-SKY VFR8 FBL controller: BeastX V2 Governor: Futaba GV-1 Governor sensor: Stator Gator Head speed settings: 1750-1950 Cyclic servos: Align DS-610 Tail servo: Align DS-650 Throttle servo: Futaba 9202 RX&Servo power (battery and regulator and generator if used): LIFE 2500 mAh straight Battery Monitor: - Power switch: - TX used: Futaba 9C Fuel and field equipment: Fuel, oil, and ratio: Regular Gas (95 Oct) w/ Amsoil Saber @ 40:1 - 50:1 Fueling system: Prolux Fast Fueller Hand pump. Starting Method (if electric, post both stater and battery): pull start Dry weight: - Flying weight: - |
09-28-2013, 02:51 AM | #26 (permalink) |
Mechanical:
Airframe : Trex 700nDFC Engine: OS GT15HZ Pipe and muffler: powerboost OS gt15hz Carburetor: Stock Walbro Clutch and clutch liner: Lynx gas clutch Align blue liner Main Blades: Align 3G (690) Tail Blades: Align 105 Main gear and pinion: 112/14 Electrical and Electronic: TX: Futaba 14sg Receiver: 7008 telemetry FBL controller: Futaba 750GY Governor: futaba Governor sensor: futaba Head speed settings: shooting for 1500/1700/2000 Cyclic servos: Align DS-615 Tail servo: Align DS-655 Throttle servo: Align DS-610 RX&Servo power and ignition : 1battery 2s LiPo 3300mah/ servo BEC 6v. Battery Monitor: Futaba Telemetry, and build Led indicator for BEC. Power switch: Futaba Fuel and field equipment: Fuel, oil, and ratio: 95 octane fuel , 1/25 - oil Castrol 2t activ Starting Method (if electric, post both stater and battery): Align Super starter. Flying weight: 4.7 kg |
10-02-2013, 03:04 PM | #27 (permalink) |
Engine: TRM VX295TT Pipe and muffler: RJX Main Blades: Cyclone Tail Blades: edge 105mm Main gear and pinion: stock Electrical and Electronic: Receiver: AR7200BX FBL controller: AB7200BX Governor: TJ Pro Governor sensor: TJ Head speed settings: @1920 Cyclic servos: Savox 1268SG Tail servo: Savox 1267SG Throttle servo: futaba 9241 RX&Servo power (battery and regulator and generator if used): TH 5200 2S2P Battery Monitor: None Power switch: none TX used: JR 8103 Fuel: Fuel, oil, and ratio: Coleman Camper fuel, amsoil 40:1 full synthetic Fueling system: |
10-04-2013, 06:46 PM | #28 (permalink) | |
If this was directed at me.............I couldn't be happier. I run them on all my heli's. $249, super simple setup (compared to the 3GX anyway), clean wiring & fly's better than I do. It was VERY unhappy with my new engine, but once I have about 2 gal of fuel through it & dialed the needles it locked in and is vibe/twitch free.Half the price of the BD, (I know that's less than the price of a crash), but I'll just have to pay closer attention. As I progress, and funds allow I might try the BD, but for now I just couldn't justify it. |
10-19-2013, 08:21 AM | #29 (permalink) |
Need to edit my post to add some info, but the button's gone, what's up?
10-19-2013, 10:40 AM | #30 (permalink) |
After some time that button gone hidden.
10-19-2013, 03:28 PM | #31 (permalink) |
Engine: RC 270 Pipe and muffler: Century speed torpedo Main Blades: Revolution 710 Tail Blades: Revolution 105mm Main gear and pinion: stock Electrical and Electronic: Receiver: AR7200BX FBL controller: Icon Governor Stator: Gator Governor sensor: Stator Gator Head speed settings: Cyclic servos: Futaba bls 272 hv Tail servo: Futaba bls 256 hv Throttle servo: futaba s3070 hv RX&Servo power: (battery and regulator and generator if used): Reedy 5000 2S Battery Monitor: Telemetry Power switch: none TX used: Spectrum DX8 Fuel: oil, and ratio: Shell, amsoil 40:1 full synthetic Fueling system: fuel dubro hand pump |
11-07-2013, 11:37 AM | #32 (permalink) |
Airframe and conversion kit (if used): Trex600n HWC Conversion
Engine: BH Hanson 231PUH Pro Plus Pipe and muffler: Century speed torpedo V2 Main Blades: Revolution 600 Tail Blades: Align 95mm Main gear and pinion: Main Gear 103T Pinion Gear 16T Electrical and Electronic: Receiver: AR9020 FBL controller: HC3SX Governor: GV-1 Governor sensor: Stator Gator Head speed settings: 1,750, 1,850, 1,950 Cyclic servos: Align DS610 Tail servo: Outrage Torqe 9188 Throttle servo: Outrage Torqe 9188 RX&Servo power: 2 Cell Lipo Battery Monitor: Telemetry/Scrpion Backup Guard Power switch: yes (dont know brand) TX used: Spectrum DX9 Fuel: 87 Octane With Penzoil Fulll Synthetic @ 40:1 Fueling system: Dubro Fueling Station with hand pump |
11-12-2013, 03:24 AM | #34 (permalink) |
Yeah. Contact the forum administrator.
11-12-2013, 10:51 AM | #35 (permalink) |
please just post setups here. If you want to discuss aspects of the setups, PM the specific person or start a tread in the main gasser section. Issues about HF site operation should go in the site help forum area. OK? Thanks.
12-06-2013, 02:53 AM | #36 (permalink) |
HWC T600 stretched to 690mm
Project: Maximum Power - Minimum Weight
Mechanical: Airframe and conversion kit (if used): Century HWC T600 Conversion stretched to 690mm blades and RJX 600 FBL Head Engine: HWC/Zenoah G29RCE 3D Extreme (modified - with cut of Fan) Carburetor: Walbro WT-990H Clutch and clutch liner: Stock HWC Pipe and muffler: Century Torpedo Slim V2 Main Blades: RJX 690 Tail Blades: ALZRC 100mm plastic Main gear and pinion: 103T, 16T, 1:6,44 gear ratio. Electrical and Electronic: Receiver: 2x DSMX satellites FBL controller: MSH Brain Governor: MSH Brain Governor sensor: HWC Sensor for CDI Head speed settings: 1700,1950, 2150 Cyclic servos: MKS DS670 Tail servo: SAVOX SH-1290MG Throttle servo: Futaba S9254 RX&Servo power: Direct LiFe 2000mAh (to small will replace with 3000mAh) Battery Monitor: Engine choking Power switch: No TX used: Hitec Aurora 9 with DSMX module (DX18 in plans) Fuel, oil, and ratio: 95 Octane pump gas, Fuchs Silkolene pro2 (Ester based) 1:35 Fueling system: 5L can, tube and gravity Starting Method: TY1 Hobby Squadron electric starter and 3s 6s LiPo Dry weight: 4753g Fly weight: ~5100g Build thread here: https://www.helifreak.com/showthread.php?t=575699
Kenobi36 - RCmaniak.pl Blade mCPX BL, Protos Mini Stretch 4S, Goblin 500 550mm blades, Goblin 700, HWC TRex 600 gasser 690mm blades. Last edited by kenobi36; 12-06-2013 at 04:33 AM.. |
12-06-2013, 07:46 AM | #37 (permalink) |
Mechanical:
Airframe and conversion kit (if used): Rex 700N/HWC conversion with KDE SX Head Engine: HWC G29 3D EXTREME PRO Carburetor: Stock Walbro 990 Clutch and clutch liner: Century Pipe and muffler: Hatori SB-15 front head Main Blades: Align 3G (690) Tail Blades: Align 105 Main gear and pinion: 103/15 (6.86 ratio) Electrical and Electronic: Receiver: Graupner GR 24 HOTT FBL controller: V-Bar Governor: V-Bar Governor sensor: HWC el. ignition sensor Head speed settings: 1700/1850/2000 Cyclic servos: Savöx HV Tail servo: Futaba BLS HV Throttle servo: Savöx HV RX&Servo power (battery and regulator and generator if used): Lipo 1800 mAh running the system with 2s. Battery Monitor: Graupner Telemetrie HOTT Power switch: Deans TX used: Graupner MX 20 HOTT Fuel and field equipment: Fuel, oil, and ratio: changing to Motul 800, 1:40 Fueling system: century system modified with fueling valve Starting Method (if electric, post both stater and battery): top starting with hobby king starter and 4s Lipo batterie Dry weight: 5450g (12.02lbs) Flying weight: 5800g (12.79lbs)
SAB Kraken 580, Pyro 600, HOBBYWING Platinum Pro 100A, Brain2 Miniature Aircraft Interceptor 600, OS MAX GT15HZ 2, Brain2, Lynx OXY2, Micro Brain2 Bell 222 with T-Rex 600E chassis, V-Bar |
12-16-2013, 10:05 AM | #38 (permalink) |
Whiplash Gas
Yet another whip. Maidened 12/21/13 !
Mechanical: Airframe: Miniature Aircraft Whiplash Gas Engine: BH Hanson G270 3D Max Carburetor: Walbro WT990, MA high flow air filter Pipe and muffler: Century V2 pipe Main Blades: Radix 710 V2 FBL Blades Tail Blades: Radix 105 Main gear and pinion: stock 124T/18T (6.89:1) Electrical and Electronic: Receiver: Futaba R7008SB FBL controller: Bavarian Demon BD3SX Governor: Futaba GV-1 Governor sensor: Stator Gator Head speed settings: 1700 / 1800 / 1900 Cyclic servos: Futaba BLS451 Tail servo: Futaba BLS256HV Throttle servo: Futaba S3072HV RX&Servo power: RadicalRC A123 2300mAh 2S Battery Monitor: Futaba Telemetry Power switch: no switch, EC3 into dual 20ga servo leads to FBL and RX TX used: Futaba 14SG Fuel and field equipment: Fuel, oil, and ratio: 87 Octane gas, Penzoil Air-Cooled 32:1 Fueling system: Jersey Modeler 2.5 gallon Starting Method: stock pull starter/removable Dry weight: 12 lb 8 oz (sans pull-start) Flying weight: est. 13 lb 4 oz Other setup details or interest: Futaba telemetry for onboard battery voltage and for headspeed via Y-harness off SG. Maiden day showed an average usage of 500mAh per flight. Going generator soon
MA Whiplash Gas v2 | HelixHeli T700 Gas conversion | G500 Raw | Trex 450 Sport FBL | OMP M1 Futaba, Bavarian Demon, Hanson Engines| DIY Lithium field battery Last edited by jharkin; 12-27-2013 at 07:53 AM.. |
12-16-2013, 01:20 PM | #39 (permalink) |
Mechanical:
Airframe: Century Radikal G20LT Engine: stock Zenoah G20 Carburetor: stock Zenoah G20 carb Pipe and muffler: Century V2 pipe EI unit: RC Excel Main Blades: Rotor Tech 640 Tail Blades: Rotor Tech 95 Main gear and pinion: stock 6.43 gearing Electrical and Electronic: Receiver: Futaba R6014FS on CH22 Governor: Futaba GY-701 Governor sensor: Stator Gator Head speed settings: 1600 / 1750 / 1950 Cyclic servos: Futaba S9255 Tail servo: Futaba S-9251 Throttle servo: Futaba S9202 RX/Servo/EI power:3S/2000 through an SG Reactor Power switch: came with SG Reactor TX used: Futaba 14MZH Fuel and field equipment: Fuel, oil, and ratio:Aviation 100LL and Coleman, Amsoil Super @65:1 Starting Method: top hex start with Tower HD starter on 4S/3700 lipo Flying weight: 10 lb 10 oz
Phil |
12-25-2013, 08:25 PM | #40 (permalink) |
Whiplash Gasser
Mechanical: Airframe: Miniature Aircraft Whiplash Gasser Engine: G290RC, lightened piston with boost ports, raised exhaust timing and eyebrows on transfers. Carburetor: Walbro WT990, short stack uni filter Pipe and muffler: HK / RJX Main Blades: DH 691 fbl Tail Blades: Rotor tech 105 Main gear and pinion: Standard Electrical and Electronic: Receiver: Sk540 with spektrum dsmx sats FBL controller: Skookum sk540 Governor: Skookum sk540 Governor sensor: Stator Gator Head speed settings: 1750 and 1900rpm Cyclic servos: Align ds615 Tail servo: Align ds655 Throttle servo: Align ds615 RX&Servo power: Zippy 4200 life with skookum power bus Battery Monitor: Power switch: EC3 connector into power bus TX used: Spektrum dx7s Fuel and field equipment: Fuel, oil, and ratio: 91 or 98 Octane unleaded (whatever I have on hand), Motul 800, mixed at 32:1 Fueling system: Dubro manual fuel pump Starting Method: Milwaukee 18v drill or pull starter Dry weight: Don't know Flying weight: Don't know Other setup details or interest: HiLantronics rceks kill switch (Australian made) |
