SR Blade Helicopters (eFlite) SR |
12-20-2014, 12:30 AM | #1 (permalink) |
Microheli blade grip instructions
here ya go therick04pp...
Blade: Nano QX, SR, 230s, 400 3D Walkera: V120D02s Align: 450L Dominator, 450 Pro DFC, 500 Pro DFC |
12-20-2014, 08:08 PM | #2 (permalink) |
Thanks bro... Only issue is it doesn't show what goes between the grip and o ring, which is what I need.. Haha. Figures.
Spek iX12 | DX7G2 | NANO CPX | NANO S2 | MCPX BL2 | 120SR | Fusion 270 | AH64 Apache (450) | D380TBR | 450X | OXY 4 "360" | Goblin 420 | 500X | 550X | AGILE 5.5 | OXY 5 | AMA# 1157132 |
12-20-2014, 11:30 PM | #3 (permalink) |
Well damn! :-(
12-21-2014, 05:22 AM | #4 (permalink) | |
Stock had in this order: One step washer at the inner grip bearing, 3 shims then the rubber damper in the center hub. All your doing is replacing plastic grips with aluminium so all that should stay the same. OK? Don't forget to use a little loc tite to fasten the grips back on. That's the only thing that keep the blades from flying off the machine and possibly hitting you or someone else.
If its fixed don't break it! |
12-21-2014, 01:03 PM | #5 (permalink) | |
There has to be someone out there using the micro grips. What are you guys using in order, on yours?
12-21-2014, 03:28 PM | #6 (permalink) | |
If its too loose you have to use more than 3 shims per side. Put it together first without loc tite to test it and get it properly shimmed. I always loc tite one side to start with. That way the one side not loc tited always comes loose when taking it back apart.
If its fixed don't break it! Last edited by Bladecpnitro; 12-23-2014 at 07:26 PM.. |
12-21-2014, 06:14 PM | #7 (permalink) |
I have the Micro grips on one of my SR's, but I'm afraid to touch it for it might upset the delicate balance there LOL I can't remember how many shims are in the thing....
12-21-2014, 09:23 PM | #8 (permalink) |
I'm pretty sure on mine I used the stock spindle shim set up without issue. There's a picture of the proper spindle/shaft/shim/O-ring set up in SR bible sticky atop the SR forum main page.
" Fly and be free! " ; Mork from Ork. |
