Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Compass 7HV, 7HVU and Chronos
Compass 7HV, 7HVU and Chronos Compass Compass 7HV, 7HVU and Chronos Model Helicopter Discussion
Old 06-27-2013, 02:48 AM   #1 (permalink)
Default loving my 7HV
got around 8 flights so far and its great, did some flips, rolls and a little inverted flight for the first time today, was braking in battery packs, order some more packs today, pulse 4500mah 65c, will be flying everyday till the snow comes, thanks again rchelicanada!!
(***WARNING*** Stop Spamming Helifreak)
freedom is slavery.
Citizen 375
Fly it like you stole it
Money does bring happiness, never seen a sad person on a jet ski
redsoper is offline        Reply With Quote Quick reply to this message
Old 06-27-2013, 03:41 AM   #2 (permalink)
nice! it beastly for sure!
you should look into it...........
crf69 is offline        Reply With Quote Quick reply to this message
Old 06-27-2013, 09:56 AM   #3 (permalink)
Awesome! Glad you're loving it! I knew you would!!
Jeff_Barrett is offline        Reply With Quote Quick reply to this message
Old 06-27-2013, 10:02 AM   #4 (permalink)
OUTSTANDING!
Best 700E out there!
Old 06-28-2013, 11:13 AM   #5 (permalink)
I wanna know what settings you guys are using with the compass zs4926 motor and yge 120hv, here's my settings.
TIMING: 18
BRAKE: OFF
TYPE: LIPO
CUT OFF: 3.2
CELLS: 12
SPECIAL: BEEP SHORT
FREE WHEEL: ON
GOV: OFF FOR NOW
START UP: SLOW
PWM: 8
STARTUP POWER: 2%
freedom is slavery.
Citizen 375
Old 06-28-2013, 06:44 PM   #6 (permalink)
Pwm. 10
Don't touch special beeps at all.
Instead, to calibrate throttle end points, plug packs in with throttle at 100% wait for tones, pull stick down,more tones unplug. Done.
Oxy 3 SK540 Minijazz 20 / WARP 360 SK540 Koby 55 / Goblin 500 SK540 jive 100 / 6HV ultimate Helijive120 SK540 / 7HV SK540 Kosmik200 / Futaba18mz / Skookum support rep
heathy is offline        Reply With Quote Quick reply to this message
Old 06-28-2013, 07:43 PM   #7 (permalink)
how do to figure out the pwm?
freedom is slavery.
Citizen 375
Old 06-28-2013, 08:44 PM   #8 (permalink)
I have not touched my YGE for quite some time. Don't even remember what I set. But it works every time so I am not worried. As far as I remember though the retail box for the motor said 8Khz PWM and that is most likely what I have set. Timing always at 18 for any brushless outrunner.
But you really have to try the governor store. Works great!
belcom is offline        Reply With Quote Quick reply to this message
Old 06-28-2013, 10:24 PM   #9 (permalink)
Default Re: loving my 7HV
(Kv x volts x poles count / 20)
... pick the kHz pwm setting closest in the esc.
Timing for outrunners is 18* or higher.
Sent from my SGH-I747M using Tapatalk 2
Old 06-28-2013, 10:26 PM   #10 (permalink)
what settings you got for I-gain and p-gain default? I set-up the gov, I find around 2700 headspeed is good, I don't know how you guys are flying around with 2300 headspeed or lower? I am using magic mirror for readings
freedom is slavery.
Citizen 375
Old 06-28-2013, 10:46 PM   #11 (permalink)
I'm running 1950 / 2050 / 2150 on the SK720BE.
I'm also running the 4525-520 Ultimate
Wish I could answer your questions better but I'm using a different configuration.
Old 06-28-2013, 11:44 PM   #12 (permalink)
I don't know how to use that formula? one guy told me to set it at 10 but the motor say pwm 8?
freedom is slavery.
Citizen 375
Old 06-29-2013, 07:21 AM   #13 (permalink)
Scorpion say 8khz on the motor but I run 12khz. The YGE and Scorpion run rough at 8khz in my experience.
Poles = the # of magnetic poles
Volts = # cells x 3.7v (44.4v for 12S)
Kv = motor kv
Eg... my 4525-520
Poles = 10
Volts = 44.4v
Kv = 520kv
So ....
(10 x 44.4v x 520kv) / 20 = 11, 544
... almost 12khz
Old 06-29-2013, 08:08 AM   #14 (permalink)
2700
Must be something off with your tach readings. That would be freakin crazy on a 700 and pretty unsafe.
Must be x2 so more like 1350 which is low and would lead you to think lower would suck, which it kinda does.
GimpyGolden is offline        Reply With Quote Quick reply to this message
Old 06-29-2013, 02:53 PM   #15 (permalink)
the heli cut out right after take off about 10 feet off the ground? I checked the batterys they have 4.20, checked the esc and motor I am lost! kinda scary would hate for it to happen in forward flight, anybody got any ideas on why this happened?
freedom is slavery.
Citizen 375
Old 06-29-2013, 10:27 PM   #16 (permalink)
Make sure you're in the right starting range with the MM or you get false results. Start at 1500 and work upward on the MM.
For the cutout ... which esc are you using again?
Old 06-29-2013, 11:37 PM   #17 (permalink)
I got the magic mirror worked out I was way off. I am using yge 120hv
freedom is slavery.
Citizen 375
Old 06-30-2013, 02:39 AM   #18 (permalink)
ruled out its not my batteries I have three set sets and it cutout on all three fligh packs, also ruled out its not my rx took the one off the raptor... I think its the motor or the yge? anything else I should check guys?
freedom is slavery.
Citizen 375
Old 06-30-2013, 03:22 AM   #19 (permalink)
I'd go through the yge settings again and start from scratch. Make sure you don't touch the special beep bit at the bottom. Also leave I @ P gains for now as you won't need to touch these unless your using the gov and in most cases still not needed.
Also once you've done the prog card bit, Calibrate the throttle end points.
If its still doing it then I'm at a loss on afraid. Maybe try another motor.
Old 06-30-2013, 03:42 AM   #20 (permalink)
how is the rx getting powered
Sent from my Gaui X5 while in an inverted tail-in hurricane.
