Old 07-16-2012, 10:28 PM   #21 (permalink)
You don't need to upgrade or stretch, or sell the parts that come with the heli. Get bigger heli instead. IMHO when you start stretching the load on the heli is harder and the servos can take a beating. The stretch allow you to tinker.. I guess...
Mini Protos BeastX
Trex 450 Pro BeastX
Protos 500... needs a Brain
n00b3D
vicrc is offline        Reply With Quote Quick reply to this message
Old 07-19-2012, 09:35 AM   #22 (permalink)
I may have another issue or I may have made a silly build error. Seems like my swashplate will come away from the anti rotation bracket at full +ve pitch and forward elevator. Can someone please post a photo from the side showing the the anti rotation bracket and the swashplate at full +ve pitch and full forward elevator.
Oxy2 210 | Oxy3 285 | Oxy4 380 | Logo 480XX | 600SX | 650SX | 690SX | 700 | 700XX | VControl
mahbouni is offline        Reply With Quote Quick reply to this message
Old 07-19-2012, 04:44 PM   #23 (permalink)
At full forward elev and pos pitch, it comes close to coming out, but I dont think it will, fingers crossed. It seems to ride on the rear bearing mostly, the front bearing hardly gets touched.
[B]TT E820 - Kosmik 200, Scorp 5035 TT G4.1(x2) - OS 91 3D Speed, Hatori
MSH Brains + JETI DS-16
rossk is offline        Reply With Quote Quick reply to this message
Old 07-19-2012, 06:03 PM   #24 (permalink)
Thanks for posting. Mine is like that too. If I go to the extreme limits of pitch and elevator then only the cap head of the bolt is left in contact with the ant-rotation bracket. It seems that the anti-rotation bracket sits at an angle leaning backward and should really be vertical. I'm not going to take any chances so I'm going to use a longer bolt and 3 bearings.
Old 07-19-2012, 06:23 PM   #25 (permalink)
use a good hair blw dryer and heat up the antirotation bracket and tweak it till it sits perpindicular. Piece of cake! Done it to my 2 minis and all it requires
scott s is offline        Reply With Quote Quick reply to this message
Old 07-19-2012, 06:42 PM   #26 (permalink)
Excellent idea. Thanks
Old 07-20-2012, 05:01 AM   #27 (permalink)
I don't think it will get anywhere that limit when flying, you would have to be running 20deg pos pitch!
Old 07-20-2012, 05:34 AM   #28 (permalink)
I usually run +-14 on both collective and cyclic.
Old 07-20-2012, 07:41 PM   #29 (permalink)
Decided in the end to go with 4 bearings and an M2x16mm bolt
Old 09-10-2012, 11:51 AM   #30 (permalink)
Well I managed to find a store with 1 good set of frames in stock and I finished building the heli. I've been flying it regularly for the last few weeks. It took me quite a few flights to dial in my Vbar as my cyclic gain settings ended up being much much higher than expected. Now I have it all dialed in the way I like it, I have to sum it up as the most awesome 450 money can buy. So smooth and the accuracy is almost on par with the 500. 4 point tictocs are easy to keep on the spot and there are no wobbles at the collective endpoints. Piro loops just flow through with no effort. High speed hurricanes make an awesome sound and the tail just holds it with confidence.
Apart from the frame issues above my only other complaint is I had to replace the counterbearing twice over the last 2 weeks. Seems like they are a little bit on the small side for the job. Anyway they are cheap and it takes 2 mins to change it out. I bought a good supply of them.
Old 09-10-2012, 01:44 PM   #31 (permalink)
I was wondering how you were getting on with it - my M-P is my favourite heli !!
Old 09-10-2012, 02:53 PM   #32 (permalink)
Hey Mike, how are things? Are you coming to the Charmouth fun fly in Oct?
Old 09-10-2012, 03:43 PM   #33 (permalink)
I wasn't planning to, when is it?
Are you flying at Harlington this weekend?
Old 09-10-2012, 04:30 PM   #34 (permalink)
It's 5, 6 and 7 Oct. A bunch of us from Harlington have booked accomodation and are staying the entire w/e.
I will be flying this w/e, weather permitting but have to leave earlyish on Saturday evening.
Old 09-11-2012, 03:43 AM   #35 (permalink)
I'll try and get over Saturday afternoon (weather permitting) - I'll give you a call in advance - keen to see the M-P given a workout
Old 09-11-2012, 04:50 AM   #36 (permalink)
On the counterbearing, are you setting the belt tension with the motor mounts then letting the belt centre before tightening the counterbearing mount? Other than that maybe running the belt too tight, I know you can run it much looser with the mini P and Corrado has said most people were running them too tight on the motor side.
I still have my origional bearing in there running fine after several hundred flights.
//Dennis.
soXos: Strike 8.1 - Strike 7.1 Light - Strike 6.1 : Goosky: RS7 - RS4 - S2 - S1
soXos DB7 nightflyer : Jeti DS-16 & DS-12
I am www.soxosaustralia.com.au | soXos helis | 1st-RC Products | EGODRIFT motors | Goosky helis | Spinblades
Thunder Fighter is offline        Reply With Quote Quick reply to this message
Old 09-11-2012, 10:42 AM   #37 (permalink)
Great, hope to see you there
Old 09-11-2012, 10:43 AM   #38 (permalink)
//Dennis.
I'm tensioning the belt with just the motor mount first and then the counterbearing. My belt is just tight enough that it doesn't skip when I load up the head.
