Go Back   HeliFreak > R/C Airplanes Info and Support > Airplane Related
Airplane Related R/C Airplanes Discussion
Old 01-09-2014, 12:57 PM   #21 (permalink)
Default Becomming less enamoured with the as3Xtra
The more I've flown the as3Xtra, the less I'm liking it.... It IS amazing how well it hovers & torquerolls, but it's something of a freakshow. Once you've played with a it a bit it really is something of a bore that doesn't really fly that well on the wing.
Bling: Liighting wallets of the unenlightened everywhere....
“Temptation is the feeling we get when encountered by an opportunity to do what we innately know we shouldn't.”
― Steve Maraboli
Centurian is offline        Reply With Quote Quick reply to this message
Old 01-09-2014, 01:51 PM   #22 (permalink)
Default Re: Attn Plank Fans... cool HH micro planks
Thanks for that, you just saved me $100
Dylan ~ www.AstroidDesigns.com
Dylwad is offline        Reply With Quote Quick reply to this message
Old 01-09-2014, 04:53 PM   #23 (permalink)
Originally Posted by Aphadek View Post
Oh and Terry - I did order the floats, waiting on them to come in. From videos I have seen you can use them on snow .. and given that I live in Canada... that was a big selling feature for me.
When/if the plane ends up submerged in the water... how do the electronics hold up? I imagine I'm bound to have a bad landing on water sooner or later. I obviously don't plan to fly it on water until I'm confident with it though...
Thanks!
Funny enough when mine flipped in the water it floated on the wing, so most of the electrics stayed dry, quick spray of deoxit and away it went again. But if you need to cut in to it be careful of the antenna it's a small copper wire prone to breaking off if moved to often. The floats can be used off snow and damp grass. It takes a crash surprisingly well also, I smashed into the ground flat out with it once and all that happened was the nose crumpled a little, a little boiling water and it was good as new. I must get around to getting another one of them, it was my first plank also, and it started a whole new branch of the addiction for me.
terryv83 is offline        Reply With Quote Quick reply to this message
Old 01-09-2014, 10:40 PM   #24 (permalink)
Funny you should pop in here... I've been considering 1s brushless options for the Xtra and I'm not finding much out there. I am curious if you have any thrust/amp/prop numbers on the 4kv HP03t you sell on 1s? Looks like it might be the best option. I have a xp7 laying here so would be a pretty easy conversion. Any thoughts?
― Steve Maraboli
Old 01-09-2014, 10:52 PM   #25 (permalink)
Well..
I don't have any data on that really, I know an HP02 geared spanks the ap03 direct drive on 1s, and most go with the ap05 DD to get some decent power, (the ap03 doesn't do well with larger than 4" props or so) but it adds weight, and is harder on batteries.
I was almost thinking of buying the xtra just to figure out a geared brushless setup for it, that will work with the stock batteries, and be lighter than the brushed motor setup.
Lots of info on rcgroups over the last several years about brushless setups for the 1s UM planes. General consensus is the AP05 is best for DD, HP02 and 03 are best geared, and are lighter and more efficient, but less durable, and no good commercially available gearboxes for them really (which is something I might want to change)
Old 01-09-2014, 11:30 PM   #26 (permalink)
Well..
On that note, you should get one! The stock power system is just adequate. I have some 45c bats on the way which seems to be the best current solution. I saw a RCG post on putting a brushless motor in the stock gearbox (same box, different plane if memory serves) that I haven't come across again. I think the issue was gearing. With an eccentric bushing and a different pinion I think you could have a very marketable product. Keep me posted!
Having dug around a bit on RCG, it's really amazing what has been done with variable pitch props, coaxial drives and thrust vectoring.
― Steve Maraboli
Old 01-10-2014, 12:11 AM   #27 (permalink)
For sure.
The problem with a brushless motor in the stock gearbox is the brass bushings on the prop shaft. A carbon or g10 gearbox with bearings would be best.. I'll see if I can dig up the old threads, someone did a ton of work developing, but it never caught on because you had to make the gearbox yourself. Plank guys tend to hate gearboxes for some reason, even though they have never tried it to see how much better it is to have a high kv outrunner geared vs low kv DD.
Im stupid conscious about weight, and will go to great lengths...
Old 01-10-2014, 12:36 AM   #28 (permalink)
Did some digging for you (and me)
http://www.rcgroups.com/forums/showt...820881&pp=100&
http://www.rcgroups.com/forums/showt...1549707&page=2
http://www.rcgroups.com/forums/showthread.php?t=1207845
Old 01-10-2014, 06:40 AM   #29 (permalink)
i love the as3xtra its the perfect size for a small backyard on a calm day.. well for me at least.. its not a rocket like the other UMx models but its nice for me to just charge up some batteries and get that fix without leaving the house and loading up for a few hours at the flying field.
bladeguy5 is offline        Reply With Quote Quick reply to this message
Old 01-24-2014, 01:29 AM   #30 (permalink)
Default Attn Plank Fans... cool HH micro planks
I got one of these asx3's about a month ago. I've yet to fly it tho because of the weather here blows! And I've yet to make one of the indoor flys. I am curious how much durability is sacrificed when is single digit temps out!??? Seems like that's the only time the wind isn't blow'n 30 mph or better!!
I would be interested in a BL conversion too. What I have heard tho is people taking the electronics out to use in a yak. Many of my friends have expensive yaks. Yeah, they fly great. I just did not want to spend 300 bucks or the time to build one. I still have helis that need to be built! The idea of a Bnf is pretty cool and I like the idea of using the electronics out of it after some hits ca won't fix!
I didn't care about planes anymore really...until someone brought out a habu and a mig out to the Heli field.
Someone should post a video of it fly'n outside.
Happy fly'n!!!
Cheers
Sent from my iPhone using Tapatalk - sorry for typos!!!
audacity is offline        Reply With Quote Quick reply to this message
Old 01-24-2014, 09:42 AM   #31 (permalink)
I'm loving my AS3xtra, pretty beat up now after a couple slaps but I have a replacement airframe coming in next week. Great little plane.
For a little more oomph use the old Sukoi 160mm prop PKZ3502.
I'll be giving it a go once my plane is back up. I've read on RCG it's a decent mod.
GimpyGolden is offline        Reply With Quote Quick reply to this message
Old 01-25-2014, 09:18 PM   #32 (permalink)
I too have the umx beast 3d. This is a great bird. I have done some upgrades that make it even better.
Get some .5mm carbon fiber rods and attach it to the leading edge of wing with thin foam safe glue. Then scotch tape leading edge as well.
Change the prop to a gws5030
Change out motor to the 180 3000kv motor and remember to swap any two wires to change prop direction.
Get some good 240mah batteries.
Mine flys great and has lasted forever like this. Lots of power with smooth flights. The carbon fiber and tape make the plane a lot stronger. Ill try to post pictures later.
Temptation is offline        Reply With Quote Quick reply to this message
