Go Back   HeliFreak > R/C Helicopter Support > Electric Micro/Mini Helicopters > X400 and MX400
X400 and MX400 Ark X400 and HeliMax MX400 Helicopters Information
Old 06-20-2006, 06:53 PM   #1 (permalink)
Default MX 400 Pics
This thing is really fun. Here are a couple of pictures my wife took.
Dutch
dutch13k is offline        Reply With Quote Quick reply to this message
Old 06-27-2006, 10:23 AM   #2 (permalink)
great pics-where is your esc mounted and how did you get the canopy to fit?
i have the 2100ah lipo and the canopy hits the ball links at the top and front??
johnnyf is offline        Reply With Quote Quick reply to this message
Old 06-28-2006, 10:10 PM   #3 (permalink)
Hi Johnny,
The ESC is mounted below the main gear toward the rear. Here is a picture of my friend's MX400 that is setup the same way.
As for the canopy, I have the CCPM kit installed and did have problems with the canopy hitting the linkages. I just used a dremmel tool to cut away the canopy until it fit.
Old 06-29-2006, 07:18 AM   #4 (permalink)
nice setup-but on the mxpro you can't mount the receiver in the front because
the servo tray sits right there-also doesn't the motor interfere with the receiver?
my canopy touches in so many spots i will have to remount it somehow
where is the antenna??
thanks for the info
Old 06-29-2006, 01:41 PM   #5 (permalink)
I haven't had any problems with the motor interfering with the receiver. I know two others with the same setup and they haven't had any problems either.
Here is a shot of the antenna. I used a couple of tie rod end links from an RC car to mount the antenna tube.
Old 06-29-2006, 03:37 PM   #6 (permalink)
good idea-i am still waiting to take my mx to the hobby shop -the salesguysaid he
would help me set it up when i have it together-i have only flown a blade cx so i am a little leery on flying this baby until i am sure it is set up right-everything checks out ok though- my sons want me to go for it but all i have done is spin the blades a bit-no hovering yet. here is a picture of mine-cannot get canopy to fit yet.
Old 07-04-2006, 03:06 AM   #7 (permalink)
looks pretty sweet from my house , but the ecs hanging out makes me nervous, note the amount of crap on my heli , the little things ,carefully calculated sleeving , enhanced decals , finely trimmed canopy, I'm not bragging I'm broke and I have nothing better to do til payday
Thorimmortal is offline        Reply With Quote Quick reply to this message
Old 07-04-2006, 10:34 AM   #8 (permalink)
They both look nice, here is my baby. I'm still working on the bling.
Team Outrage
OPM - Fly it like it aint yours!
JR X9303 2.4 Baby. I have felt the difference and I like it!
Don"t make me list 'm all !
Raven_darkcloud is offline        Reply With Quote Quick reply to this message
Old 07-05-2006, 09:02 PM   #9 (permalink)
excellent pics guys-i crashed my chopper 2 times in 2 days!! this time blades-feathering shaft and tail boom are gone
i only want to get the thing up and hovering but i can't? it seems to want to go to the right so i trim and then it veers left but not because of the tail-then i overreact and she crashes-so disappointing-i need to get someone to set it up for me-then there must be a way to set the transmitter end points so it is not so responsive-i know i have the tail and collective controls tamed but the other two are too much! can't afford any more crashes-can't even follow radds school of flite untill it get's setup first.
maybe i shouldn't have gone to the mx size so soon-the blade cx was so easy
Old 07-06-2006, 06:34 PM   #10 (permalink)
edit.... double post
tsirhcdica is offline        Reply With Quote Quick reply to this message
Old 07-06-2006, 06:36 PM   #11 (permalink)
Old 07-06-2006, 08:28 PM   #12 (permalink)
Johnnyf:
Check the links in the head and make sure they arnt tight at all. Then make sure the swashplate is level. do it with 0 trim. and then you can use expo in the tx to soften the center of the stick. I just replaced all my links with align links and its much better now, but I still need to work out some subtrim. Also check your cog side to side by turning the blades so that the flybar sits in line with the tail and lift it up with one finger under the flybar on each side. The skids shuld sit level to eachother.
What tx do you use?
Team Outrage
Old 07-07-2006, 09:04 AM   #13 (permalink)
my transmitter is the futaba t6exhp-
Old 07-07-2006, 09:06 AM   #14 (permalink)
sorry my transmitter is the futaba t6exhp
Old 07-07-2006, 11:16 AM   #15 (permalink)
ok then you can easly set espo in the radio. I also found that with links set at there 90 deg that my atv was too far out. I brought my ele and alor endponts down and have much beter control. If you hit thrtl hold and turn the birdon you can see if the swash it maxing out. Use a pitch gage to se if you are geting 6 deg of cyclic movment. I now have 6deg cyclic and +10/-10 pitch with no binding. I'm running eflit s75 servos cuz they cost 13bucks and have the torq and speed of the hitsch 50/55. I'm looking into if the align blade grips will alow more cyclic. With the x400 ones the links on the flybar cage hit the bottom of the grips.
Checking to se that you are not binding on cyclic may make it fly better. If you want I can make a vid of how it should move and how it was moving. :glasses:
Team Outrage
Old 07-07-2006, 03:49 PM   #16 (permalink)
thank you for all your help-i went back to the hobby shop today and bought all the replacement parts-i asked the sales guy who can fly helis if he would set mine up-so i am dropping it off tomorrow-then i should be ok-i hope!!
Old 07-08-2006, 03:41 PM   #17 (permalink)
got my chopper back all set up-the salesguy hovered beautifully-he says i can setup my exponential settings to soften the response-anyone know how to do that??
Old 07-09-2006, 11:37 AM   #18 (permalink)
go into the menu and find expo for ele aloron and start ading 1 or 2 points at a time till it feals good to you, but becarful you can cueas it to push too much expo and go to far on the stick and crash. I run a spektrum so I'm not to sure on the futaba menu for 6exh. you can also set dual rater so that you can soften control for hover and flip a switch for full flight. d/r is great on planes but I have yet to use it on a heli. You might go into the radio treads and look for on on the 6exh.
Team Outrage
Old 07-14-2006, 11:51 PM   #19 (permalink)
on a futaba radio you have to program negative expo, start with about negative 15 on aileron and elevator and about negative 10 on rudder and go from there, just remember positive expo = more sensitive
freya1 is offline        Reply With Quote Quick reply to this message
Old 07-17-2006, 11:04 AM   #20 (permalink)
thank you
