Go Back   HeliFreak > R/C Helicopter Support > Electric Micro/Mini Helicopters > X400 and MX400
X400 and MX400 Ark X400 and HeliMax MX400 Helicopters Information
Old 11-17-2007, 12:59 PM   #1 (permalink)
Default My MX400 after the latest overhaul ! can i please get your input
here is my newly rebuilt MX400 i would just like some input on if you guys see anything that you think need to be changed or anything thanks guys !
Trex 600NP
Trex500esp
whattheheli is offline        Reply With Quote Quick reply to this message
Old 11-17-2007, 01:44 PM   #2 (permalink)
Default Set up
Good looking set up. I didn't think the ring was nessary with the Dx7 ?
Scottlclem is offline        Reply With Quote Quick reply to this message
Old 11-17-2007, 04:06 PM   #3 (permalink)
Default gyro location
whattheheli;
I would strongly suggest to move the gyro. In a crash, the flybar will hit it and destroy it. A good spot would be behind your receiver.
T-REX 450 SE, GY 401, 4x HS 65MG
T-REX 450 SE, Logictec 2100, 4x HS65
MX 400 PRO CCPM, Zoom Gyro, 4x HS65
MX 400 CF + CCPM, Copter-X head, GY 401, 4x HS65
Spektrum DX7
equisol is offline        Reply With Quote Quick reply to this message
Old 11-17-2007, 04:34 PM   #4 (permalink)
Default Looking good
I like your machine. Do you know how it compares to the Align 450?
dogfart is offline        Reply With Quote Quick reply to this message
Old 11-17-2007, 06:29 PM   #5 (permalink)
whattheheli
check the Jesus bolt it appears that the lock nut is missing !
in the closeup pic
Rob
super coop is offline        Reply With Quote Quick reply to this message
Old 11-18-2007, 03:37 AM   #6 (permalink)
the align 450 is a better heli ! you would have to do much less moding to it than a mx400
Trex 600NP
Trex500esp
Old 11-18-2007, 11:18 AM   #7 (permalink)
ok so i made one more mod last night ! i put in a align 430xl i wonder if i would be ok with the cc25 esc running on this settup ! i have a 14t pinion on it thanks
Trex 600NP
Trex500esp
Old 11-18-2007, 08:41 PM   #8 (permalink)
Default cc25
I would be curious to know if your cc25 will run the 430xl myself. I was debating on buying one 430xl and went with the Just Go Fly 500th because it's full load amps was a little less then the 430xl.
I'm guessing if your like me your going to try it and see what it does . If your gona try it set the overload in the esc to it's max setting but not turned off,hover it bit land and take temp reading or feel the esc.
Old 11-20-2007, 03:17 PM   #9 (permalink)
wtf is a jesus bolt?
AMA# 906249
i'm now down to one heli (align sev2) but have an arsenal of 120+ mph jets. hmm...i think i see a pattern here lol.
istandalone is offline        Reply With Quote Quick reply to this message
Old 11-20-2007, 05:38 PM   #10 (permalink)
the bolt that holds the hub to the main shaft is called the Jesus bolt
stems from fullsize helis
if it fails your going down like a flying brick, an you may get to meet him!
Old 11-20-2007, 05:39 PM   #11 (permalink)
Default jesus bolt
I heard it was called Jesus bolt because if it ever comes out in flight you will know why the call it a Jesus bolt. It's the bolt that is under the main gear that runs through the main shaft.
Last edited by Scottlclem; 11-20-2007 at 05:46 PM.. Reason: supper coop typs faster then me posted at same time
Old 11-21-2007, 05:52 AM   #12 (permalink)
gottcha. kinda like the "oh sh!t" handles on a car. once you use them, you know why they are called that.
AMA# 906249
Old 12-16-2007, 01:00 AM   #13 (permalink)
I thought it was called the jesus bolt cause' if it failed only jesus could save you :-)
same thing but I like my version better :-)
I think I read it that way in a magazine or post.
pam-mo
pam-mo is offline        Reply With Quote Quick reply to this message
Old 12-16-2007, 12:52 PM   #14 (permalink)
aight, couple of questions for the thread starter. your battery tray, is that home-made or align? either way i like they way you've got it set up. also, the head, is that the eccpm conversion? one more thing, it looks like (in the rotorhead close-up) that there is metal shavings/filings on your swash? you really want to blow all of that grit out/off of the head before you fly her again. just think if just one of those shavings gets into your swash or main shaft bearing.
AMA# 906249
Old 12-16-2007, 01:42 PM   #15 (permalink)
the battery tray is home made just took a stiff piece of plastic and one end to fit inside the frame rails ill take some pics when i get my mx450xs i will be moveing the electronics over to it as soon as i get it then rebuilding my original mx400 and yes it is a ccpm convert kit on it and i allready cleaned the swash up ! thanks for lookin out thou !
Trex 600NP
Trex500esp
Old 12-16-2007, 04:10 PM   #16 (permalink)
no problem! i'd hate to have a fellow freak's heli fail because of a small piece of metal lol. you said your getting the mx450? check out tower's prices on the mx line. getting really cheap.
AMA# 906249
Old 12-16-2007, 04:17 PM   #17 (permalink)
yea tower is where its comeing from my fatherinlaw ordered it for me for xmas
Trex 600NP
Trex500esp
Old 12-17-2007, 04:00 PM   #18 (permalink)
sweet. are you getting the ultimate combo or just the arf and will build it to your own specs? if your getting the combo, stay away from that motor they offer with it, as it's pretty weak for as much juice as it draws. then again, maybe i've got to play with my pinions more.
AMA# 906249
