Go Back   HeliFreak > R/C Helicopter Support > Mikado Logo Helicopters > Mikado Logo 700 Xxtreme
Mikado Logo 700 Xxtreme Mikado Logo 700 Xxtreme Helicopters Discussion
Old 02-03-2015, 06:54 PM   #1 (permalink)
Default part number
Hi folks
Can any one tell me what the part number for the tiny metal washers that get bolted to the horizontal tail fin are? they are 3*5*2 metal washers.
Kindly let me know
d
deepak kirpalani
Deepak.g.kirpalani@gmail.com
deepak is offline        Reply With Quote Quick reply to this message
Old 02-03-2015, 10:57 PM   #2 (permalink)
Hopefully you weren't inverted when the bolt either broke or backed out.
I got the same blade on my 700 twice , one bolt break and one loosened up and backed out.
Sadly I haven't found those brass spacers separate from the full tail clamp/fin setup
I used some smaller (outer diameter) washers and make a stack up.
Helps to sand a bevel on the backside of the tailboom clamp , allows extra room for the end of the strut ball end.
Personally I've given up on the stock setup.
After tightening up the 2.5mm bolts the 3mm go loose , repeat this process a few times and all 4 bolts are over torqued and ready to break. To loose and they'll back out , even with a over generous amount of locktite.
I'm now running the lynx 1 pc logo 600 tail clamp.
LX0078A - I think they've been discontinued , so it might take a bit to find a NOS one.
http://onlyfinehelis.com/helicopter-...r2ninhjfj1ivm2
One piece clamp with a single bolt to clamp down with , much like a mast collar (proven to hold) , then bolts up from the bottom (replacement struts come preglued). No provisions for a fin though.
Another thing to do is to take some Velcro strap and just in front of the strut end , do one wrap around then poke a small hole in the middle , then put a tywrap thru hole a tighten up. Take the the other end and go OVER the tail control rod and repeat for the other strut. Now when the bolt break or comes loose (oh it will) , the strap will keep the strut from going into blades if inverted. Heli will make an odd humming noise with only one strut (see I said they'd break again)
Martin
Logo XXtreme 800 8917 / 256HV VBC
Logo XXtreme 700 on 14s 8917 / 256HV VBC NEO
Logo XXtreme 770 14s 8917/9188 VBC
Logo 600 8917/ 9188 4035-500 VBC NEO
rcmarty is offline        Reply With Quote Quick reply to this message
Old 02-04-2015, 12:06 AM   #3 (permalink)
I don't remember the part number but Synergy has that exact part you need.
LOGO 200, DIABOLO 550, DIABOLO 800, SOXOS 7.1
VCONTROL*NEO*TRIBUNUS*MKS*VTX*DPL8 W/BUMP CONTROL*MEANWELL
Corvette & Copter Guy is offline        Reply With Quote Quick reply to this message
Old 02-04-2015, 01:43 PM   #4 (permalink)
Thanks Guys,
I currently use an m3 nylon nut.
Just looking for the original part.
D
deepak kirpalani
