Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Warp 360
Warp 360 Compass Warp 360 Model Helicopter Discussion
Old 12-17-2012, 09:41 PM   #81 (permalink)
I thought as much too, but I'm becoming more and more confident with it ... it's way more stable and "in control" than the X2. You won't regret taking it to indoor sessions ..
Jeff_Barrett is offline        Reply With Quote Quick reply to this message
Old 12-17-2012, 10:01 PM   #82 (permalink)
Ahh good to know jeff. I just have to setup the govenor on the ikon fbl and i am good to go for maiden.
Team Fun / Heli Canada
**When you start to be in complete control reflexes are not a requirement.**
s0laris is offline        Reply With Quote Quick reply to this message
Old 12-18-2012, 02:39 AM   #83 (permalink)
Perfect married warp-ikon. This is my setup and will be a win setup.
zeusramon is offline        Reply With Quote Quick reply to this message
Old 12-18-2012, 04:16 PM   #84 (permalink)
How did you setup the governor on the ikon? Did you use a sensor for the motor? If so, what sensor? I have the YEP 45A that has a governer but would rather use the ikon one.
Blade 150S | Blade 230S V2 | Blade 130S | Blade mCP X | Blade mCP X BL2 | Blade Nano CPS | Blade Nano S2 | DX8
acidkindred is offline        Reply With Quote Quick reply to this message
Old 12-18-2012, 06:09 PM   #85 (permalink)
I have yep 45 too. I took spektrum satellite cable and soldered it to hobby wing rpm sensor (replaced hobby wing wire} i have pictures in my album
Old 12-20-2012, 11:42 AM   #86 (permalink)
One more warped!!
I've maiden it this afternoon and i just loved the way it flies.
At the same time i miss the agility from my lighter 450 (80 grams less) but the warp is so silky smooth through the air, tracks perfectly.
Besides having bumped up the agility, itīs not reacting as fast as it should, swash is very tight and the links will get a bit more sizing.
I cannot explore the higher rpm's without getting a lot of buzz, will try carbon tail blades.
The motor gets a bit warmer than my align 1700kv, but it's perfectly ok.
The tail section could see a bit more of improvement: the plastic support part flexes a bit, and the bolt that hold the pitch arm should be shanked, as it is the tail loses a bit of precision.
After all a very nice heli, with precision levels way up there
XL Power 520(soon to become a 480), Warp 360 , Tarot 360Sport, Logo480 LowRpm , Logo 500
T500 AP
Luigi_tuga is online now        Reply With Quote Quick reply to this message
Old 12-20-2012, 11:58 AM   #87 (permalink)
Originally Posted by Luigi_tuga View Post
One more warped!!
Congrats, happy to hear your waiting time is over!
Oxy 2X-VertWarp 360Blade 450XBlade 450X NightflyerGoblin 500 ♦ 2 X mCPX v2 ♦ night fly mQXLadyMQXnano QXnano QX FPVInductrixDX8 G1
Coco66 is offline        Reply With Quote Quick reply to this message
Old 12-20-2012, 12:54 PM   #88 (permalink)
Thanks.
Now i'll have to fly it more carefully, at least till parts come in stock.
Will stop the trainer mode but will be full on fun mode!!
T500 AP
Old 12-20-2012, 12:59 PM   #89 (permalink)
One more warped!!
Great work! And comments. I have to add, do you have any old align or clone tail grip bolts or bell crank bolts? Alot of those came with a longer non threaded shank, so they will work to keep the pitch arm (bell crank) from being as sloppy. (I have quite a few of these in my parts bins).
Old 12-20-2012, 03:13 PM   #90 (permalink)
Searched when i was building the bird and did it again now with no sucess.
this is a little detail that should be looked after by compass, it's a small detail but important.
The right bolt+aluminium support arm would enhance tail performance quite a bit.
T500 AP
Old 12-20-2012, 03:14 PM   #91 (permalink)
yes i have made mention of that too
Old 12-20-2012, 03:52 PM   #92 (permalink)
What's your headspeed and how much cyclic are you allowing for? (which FBL controller?)
Old 12-20-2012, 05:59 PM   #93 (permalink)
Will tach it tomorrow, Jeff.
On cyclics i have 8 degrees , will bump that to 10.
I'm on beast, AR 7200.
T500 AP
Old 12-20-2012, 06:07 PM   #94 (permalink)
Yah ... go +/- 12 on the pitch and +/- 10 on the cyclics... that should greatly liven things up.
I don't know how to increase rates on the BX, I won't be any help there.
Old 12-20-2012, 06:09 PM   #95 (permalink)
increase your d/r with beastx to increase your cyclic rates
XLPower Specter V2 - Rotorflight - ELRS
OMP M2 Explore - Rotorflight - ELRS
TX: Fr-Sky X9 Lite S / RM Pocket - EdgeTX - ELRS
P.I.Engineer is offline        Reply With Quote Quick reply to this message
Old 12-20-2012, 06:33 PM   #96 (permalink)
Already set-up the beast for 10š cyclics, will up the D/r also if necessary.
The next two days will be VEEEERY flyable around here.
http://www.windguru.cz/pt/index.php?sc=48963
T500 AP
Old 12-20-2012, 06:59 PM   #97 (permalink)
how did you setup for 10 deg cyclics?
Old 12-20-2012, 07:24 PM   #98 (permalink)
I went to step L on setup menu. I had it around 8 degrees, it could be limiting my agility.
T500 AP
Old 12-20-2012, 08:32 PM   #99 (permalink)
step L you should go till it binds, and you should be at blue light.
that step is just telling beastx how far it can actually travel, it's like a cyclic protection ring.
after that you set your d/r in you tx to get your flip/roll/yaw rates. and don't use expo if you're using a preset. I bumped my tail up to 110 to get a piro rate i like, around 450/sec.
Old 12-20-2012, 08:40 PM   #100 (permalink)
Member
I always went shy of binding and never bothered to put a pitch gauge to it. But Capi advises to limit the cyclic pitch during this step, 8 degrees IIRC. If you've seen any of his flight videos, he seems to know what he's talking about. I'll see if I can dig up that post.
Sent from my phone
