Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mCP X Brushless Mods
mCP X Brushless Mods Blade Micro CPx Brushless Mods and Conversions
Like Tree2Likes
Old 02-10-2016, 02:34 AM   #3581 (permalink)
Sorry, I'm incapable of helping, from the lack of screenshots, log files, photos of the wiring ...
For the most recent Revision of BlHeli Setup see my blog.
4712 is offline        Reply With Quote Quick reply to this message
Old 02-10-2016, 08:07 PM   #3582 (permalink)
Ok here is what I have going on. This is just one of many escs that I can't get to arm. Now don't judge my soldering by these pictures, this is not how I normally solder. I accidently ripped one of the pads on the esc right before taking the pictures. Please let me know what you think.
ID:	634667   Click image for larger version
ID:	634668   Click image for larger version
ID:	634669   Click image for larger version
ID:	634670   Click image for larger version
ID:	634672   Click image for larger version
ID:	634673   Click image for larger version
Name:	BLHeliSuiteSetup_160210_1 esc 2.png
megasmicros is offline        Reply With Quote Quick reply to this message
Old 02-17-2016, 06:28 PM   #3583 (permalink)
is there an easy way to flash the little bee esc's,ive done plenty of the dys and afro ones but am not having any luck with the little bee's,many thanks,Marty
Align 470M,stock motor,Kontoniks 60 amp esc,Futaba 760r gyro,Theta 921 cyclic servos and Theta Sabre T1 tail servo.
MeekaMoMo is offline        Reply With Quote Quick reply to this message
Old 04-19-2016, 05:11 PM   #3584 (permalink)
Hi, guys!
I'm trying to get BLHeli flashed and running on some ESCs that I picked up for free from a friend. They're nice hardware, they just have firmware that's crappy and slow for quadcopters. These are Castle Creations Phoenix 25A ESCs, they use an SiLabs F330.
I have a good amount of experience with hardware stuff, so I've reverse engineered a basic schematic for these ESCs. I've even been able to flash one of them with a version of BLHeli that's for a different ESC. I just need help figuring out what to set in a .inc file for them.
I've attached a schematic and pictures below, having some direction on how to set up a .inc file for them would be fantastic!
Thanks!
Last edited by Creaky Cactus; 04-20-2016 at 09:29 PM.. Reason: Resized images to 640
boztalay is offline        Reply With Quote Quick reply to this message
Old 04-20-2016, 04:53 PM   #3585 (permalink)
Nevermind, I actually got it working!
Old 04-25-2016, 05:03 AM   #3586 (permalink)
I'm not sure if this is the best place to ask the questions, so please re-direct me if there is a better place.....
I have just set up BLHeli on a HobbyWing 40 Platinum using the Kforce download. I have got it working, but have a couple of quirks that I would like some help with - I tried searching but couldn't find the answers ..
I have the ESC on a Mini Protos using a Scorpion motor - I have 3 "flat curves" set for Normal, Idle 1 and Idle 2 - I have tried these at different %'s but always get the same HS for all 3 settings. I can't change HS using the flightmode switch (DX7) - this used to work fine on the CC that I was using before and works on all of my other helis so I am guessing that it is a setting that I need to tweak.....
The second quirk may be related to the first - when I spool up I get a "kick" on my tail that seems to occur halfway through spool-up (a bit like when setting up Gov store on a YGE but more pronounced).
Any suggestions gratefully received....
Cheers,
Mike.
Old 04-25-2016, 11:10 AM   #3587 (permalink)
First thought is the ESC is in GOV ARM mode instead of GOV TX.
Team Newb pilot
All my helis and quads were lost in a tragic boating accident.
NCcraig is offline        Reply With Quote Quick reply to this message
Old 04-25-2016, 01:20 PM   #3588 (permalink)
I did wonder about that - but so far as I can tell it is set to Tx - screenshot below
Old 04-26-2016, 11:51 AM   #3589 (permalink)
May be the timing? Everything else looks normal.
Team Newb pilot
Old 04-26-2016, 01:31 PM   #3590 (permalink)
THanks for looking - I'll try re-calibrating throttle to se if that helps
Old 05-16-2016, 12:25 PM   #3591 (permalink)
Question Blade Nano CPS
Hello!
Is it possible to support Blade Nano CPS?
NCPX at the PWM frequency 1kHz
NCPS have a PWM frequency of ~400Hz
Sorry for my English
AndreyI is offline        Reply With Quote Quick reply to this message
Old 05-25-2016, 01:03 AM   #3592 (permalink)
Default blheli for cars
Does anyone know if blheli is/can be adapted for rc cars?
apper001 is offline        Reply With Quote Quick reply to this message
Old 06-12-2016, 04:11 AM   #3593 (permalink)
Hello i have emax 60a simonk series esc, i need original firmware or blheli version please help me (sorry for my bad english)
excuti is offline        Reply With Quote Quick reply to this message
Old 06-13-2016, 08:29 AM   #3594 (permalink)
Please can anyone tell me how do i get the voltage cut off paramters, when i conenct to my esc i only get the parameters shown in the picture:
spinzer is offline        Reply With Quote Quick reply to this message
Old 06-13-2016, 09:51 AM   #3595 (permalink)
please can anyone help, does anyone know how i can get the low voltage cutoff parameter, i'm using an rc timer 40 am esc, please if i have to reflash to different firmware please can anyone tell m which firmware ? its going to go on a hexacopter, currently i conly get the parameters shown in the attach picture
Old 06-13-2016, 01:27 PM   #3596 (permalink)
please can anyone advise
Old 06-13-2016, 01:56 PM   #3597 (permalink)
Do you really want an LVC on each motor? It will crash when the first one gets a 1/2 throttle signal.
Shouldn't you use a timer or telemetry with voltage?
Just questions. I am familiar with BLheli Silabs for helis but sorry, can't advise on Atmel / multicopter.
Good luck and happy landings.
daveapplemotors is offline        Reply With Quote Quick reply to this message
Old 07-07-2016, 12:29 PM   #3598 (permalink)
Smile thank you for your hard works
oh, thanks for your hard works Steffen Skaug , i am just learning this blheli, and i want to made a esc by myself, i can draw some pcb, but i am got some trouble at the schematic , i want to use good mos,and f390, did there are some example, could anyone help me? i could share my pcb project, if some one could help me
moretolearn is offline        Reply With Quote Quick reply to this message
Old 07-23-2016, 06:31 PM   #3599 (permalink)
Originally Posted by AndreyI View Post
Hello!
Hello,
i have the same request, PWM at 400HZ for the nano CPS
see: https://github.com/bitdump/BLHeli/issues/170
gjeremie is offline        Reply With Quote Quick reply to this message
Old 09-21-2016, 01:20 AM   #3600 (permalink)
Default Aquastar Box as Stand alone 1 Wire to Silab ESC
Hello, im new at Blheli and done many search for tis Info.
I flashed the Aquastar Box to Blheli and checked the C2 Interface with it, here all is ok and working.
But i can chose at the Blheli Suite to flash the Aquastar to 1 wire connection to the Esc Servo Lead , here i have no Info for the wire Points on the Aquabox to set up an Silab Esc.
Is there any info on this Problem ?
greetings Alex
Alexandro is offline        Reply With Quote Quick reply to this message
