Brand Specific Charger and Battery Support Brand Specific Charger and Battery Support |
11-24-2014, 09:46 PM | #1 (permalink) |
DPL 8X2 and FMA Safe parallel board???
Im trying to put some packs on this charger using the FMA Safe parallel board and every time i do i get a "bad cell count" immediately. I have tries setting the nose to FMA AND HX, used both channels and getting the same result. Im not sure what im doing wrong but im getting irritated. Can someone please assist me?????
Hobbywing US factory team pilot BK Servo Spartan RCTeam LynxTeam OXY Team Xnova I get high by getting LOW!! |
11-25-2014, 01:18 AM | #2 (permalink) |
Can you post a link to the board you are using? That will help nail down which wiring mode you will need to be in. There are two boards that fit that description. Also, do you have the balance connector and the main leads connected to the charger.
Here is some other general information about the chargers. It would address the bad cell count issue. But there are some other tidbits that may help. FAQ - Powerlab Quick Start Guide - Wiring modes, Supply Limits and 1s charging
Revolectrix Ambassador - Charger Specialist Revolectrix.com 10% discount for Batteries GCAM16 |
11-25-2014, 08:03 AM | #3 (permalink) | |
11-25-2014, 10:19 AM | #4 (permalink) |
That is the MPA and it uses the JST-XH wiring mode. This is the interconnect cable that goes from the charger to the board.
http://www.usastore.revolectrix.com/..._2/MPA-XH-PL_2
11-25-2014, 10:31 AM | #5 (permalink) | |
