Old 06-02-2012, 05:33 PM   #1 (permalink)
Default mini protos 6s stretch weight
what us the weight iof your stretch 6s mini mine weighs in at 960 grams kinda seems heavy to me just trying to see what every one elses stretched 6s weighs
RCHN Citizen 790
-Protos maxv2 evo,xnova,Hw160, xpert, brain-Logo 600sxv2, hw130, mks scorpion,optipower,brainProtos -380 evo,Mks,xnova,HW,pulse,brain2. Jeti ds16
keither1984 is offline        Reply With Quote Quick reply to this message
Old 06-04-2012, 07:10 AM   #2 (permalink)
860 grams RTF with Gens Ace 6S 1200's and custom G-10 battery mount for CG with the lighter packs.
SAB 350's
DS95/95i
Mini Vbar, 2 sats
Stock YGE 60
HW phase sensor.
Aluminum pulleys and low FBL head.
3:20 flights at 3200 RPM to 80%
Dylan
Dylwad is offline        Reply With Quote Quick reply to this message
Old 06-04-2012, 08:34 AM   #3 (permalink)
892g
Unstretched 325mm SAB
Thunder Power 6S 1300mah
YGE 60
vBar mini
MKS DS95's
2x DSMX sats
rossk is offline        Reply With Quote Quick reply to this message
Old 06-04-2012, 06:38 PM   #4 (permalink)
ok what the heck why is mine so heavy where did I go wrong could it be my scale I wonder
RCHN Citizen 790
Old 06-04-2012, 07:03 PM   #5 (permalink)
Biggest differences would the battery, my 1300's are 210g, which gives me perfect CG unstretched, but I will struggle when I stretch, so I have some heavier packs on the way 1400mah, 258g, that should help out when stretched, but will put the weight close to 950g
Old 06-04-2012, 07:51 PM   #6 (permalink)
Exactly, my batteries are only 175 grams, I love the way it flies at 3200 RPM at that weight, but wish I had more flight time.
Plus I had to make an extended and raised battery tray to get the CG good, and swap the 9257 on the tail for a DS95i.
A smaller tail pulley for running 2500-2700 RPM on the stretch would be nice too, I can hear the tail struggle at the lower RPM's on my setup.
Dylan
Old 03-15-2014, 06:11 AM   #7 (permalink)
Okay I know this post is old but I figured I'd add the weight of mine as well.
I'm running the 2520-1360 motor that is 20g heavier than stock.
It's 965g AUW with a 250g 5S 1800 lipo, so 715g without lipo.
I guess it's pretty heavy , I'm running 360's though so I think the disk loading shouldn't be too bad.
"Beater" Mini Prôtos stretch 6S : Scorpion 2520-1360kv, Edge 353SE
"Princess" Goblin 570 stretch 12S : Xnova 4025-560kv, Cyclone 615
FrSky Taranis - Heli-X 5 - MKS, YGE, SK540 - Yamaha XJ6F
Aryemis is offline        Reply With Quote Quick reply to this message
Old 03-28-2014, 04:45 AM   #8 (permalink)
My 6S stretch is 909g rtf with stock motor/esc, DS92a+, DS95i, iKON, one sat, and light nanotech 45-90 batts.
Oxy 3 - MSH Mini Protos - MSH Protos Max 700 - Taranis
Thanks to Oxy Heli and MSH-Direct.com
Former Username: Code3Medic
Russell Harding is offline        Reply With Quote Quick reply to this message
Old 05-20-2015, 10:59 AM   #9 (permalink)
Let's revive the weight thread! Mine is piggy, but it has a lot of aluminum. Does anyone know what the aluminum servo frames weigh compared to plastic? I have a feeling I added a good amount of weight there. And the 20g boat anchor KST servos I run
Old 05-20-2015, 11:11 AM   #10 (permalink)
I think mine is about 890g last time I checked but need to re weigh with the new blades I will be getting.
Alex
Fleet: Miniprotos
Flock: cockatiel and congo african grey
dedados is offline        Reply With Quote Quick reply to this message
Old 05-22-2015, 07:16 AM   #11 (permalink)
Similar here: 900g rtf.
Old 05-22-2015, 05:18 PM   #12 (permalink)
Mine is 670 with no lipo.
Team MSH USA - Cyclone Blades
MSH Prôtos 380 Brain 2
MSH Prôtos Max V2 Brain
vtown nick is offline        Reply With Quote Quick reply to this message
Old 05-22-2015, 05:24 PM   #13 (permalink)
Measure it with a lipo Nick. Consistency!
Old 05-22-2015, 05:30 PM   #14 (permalink)
If the battery weights on helidirect are right...I'm at 992g auw! PIG!!
That's 730grams dry, and 262grams for the Pulse 1250mah 45c
Old 05-22-2015, 06:59 PM   #15 (permalink)
Helidirect (and Pulse web site) are wrong on the weight of the 1250 6s. It's around 220g. The Pulse 1350 is the one around 260g.
Protos Max Leggero 700, Logo 600SE, Blade 230s
DX9
flint723 is offline        Reply With Quote Quick reply to this message
Old 05-22-2015, 08:52 PM   #16 (permalink)
898g with a gens ace 1200 40c
My x3 weighs 1059
Old 05-23-2015, 01:19 PM   #17 (permalink)
I guess mine is one of the heaviest around.
6s stretch with a scorpion 2520-1360kv, 20g servos all around and a full size receiver, oh and fairly heavy Edge 353SE
964g AUW, with a 219g Dinogy 6S 1300 65C (so 745g without lipo).
No clue how it gained 30g compared to last year, only thing I added was the X8R I believe. Blades at the time were RJX Vector 360 which are very similar in weight to the Edge 353 (around 35g each).
Old 05-23-2015, 08:20 PM   #18 (permalink)
You're right, 220g for the battery. 952Auw
Old 06-02-2015, 09:43 AM   #19 (permalink)
So...I crashed doing a "demo" at the last fun fly.
Decided to persue a little weight loss in order to gain a little more "power" and maybe a touch of flight time. But I don't want to sacrifice strength so I won't be doing anything crazy
In the end I'll probably end up with an xnova motor and 1400mah packs. But for now I want to test this.
First up, metal bearing blocks. 12.5g heavier than plastics. I blew out my bearings anyways.
Main shaft. I've been running solid, it's bullet proof, but heavy. 11g cut by going to stock.
I run the Lynx DFX head and tail. I thought I would go back to stock, but I really like the fuctionality of the tail, how smooth it is and easy to work on. So I'll keep it, but I could lose 8g going back to plastic. I was ready to swap the head back to stock, weighed it all up...Lynx DFC head is .5 gram lighter...so it can stay too.
Deleted the horizontal fin. Nets me about 3.5g loss there.
Already running a talon 35, and I don't really think there's a lighter esc worth running for me.
Last thing on my list is the servos. The ds95i is here to stay. It may be a boat anchor but it's a fantastic servo. The KST on cyclic are great. I don't want to lose the performance, but I do want to shed some weight. So what to use? Well let's ignore anything with plastic gears. And we want to keep nearly the performance at 5.5v:
KST: 3.1kg/0.06s at 20.5g each
DS92A+: 2.95kg/0.058s at 17.5g each
H3050: 2.6kg/0.053s at 13g each
The spektrums are a great balance of specs, price and weight. And will get me another 20grams of weight loss. Also, they seem to be working great on the 360cfx.
Total so far: ~47 grams
The last thing in on list is to grab a set of 350mm blades. Should take some load off the motor, both disk area and rotating mass. That should be another 10 grams off the AUW.
End goal is a modest 900g flying weight.
Old 06-02-2015, 10:12 AM   #20 (permalink)
Looks like you got a plan
Alex
Fleet: Miniprotos
