Old 03-20-2013, 07:58 PM   #821 (permalink)
I hope they will offer an exchange service (old tail blades for new) (and not just for the USA)
Did you just quote that with a straight face?
Bonkievan is offline        Reply With Quote Quick reply to this message
Old 03-20-2013, 10:45 PM   #822 (permalink)
Haha! Yeah, I have to admit it was hard. But in this case it's not an upgrade, it's a part that just doesn't work on a lot of the stock helis, and Align has said not to use them if they cause the problem.
Gaui X2 FES ZYX, Gaui X3 MB, Gaui X4 II VBar, Gaui X5 FES MB
250 DFC ZYX, 450 DFC Sport MB, ALZRC 450L Pro VBar, Devil 450 FAST VCTRC FBL
500E DFC Pro VBar, 500E SDC ZYX-S
KDS 550 VBar, 550E DHPS VBar, 550E DFC Pro VBar, 700E DFC HV iKon
beenflying is offline        Reply With Quote Quick reply to this message
Old 03-20-2013, 11:41 PM   #823 (permalink)
Yeah, I totally agree but I'm not holding my breath.
In saying that, Align are doing similar with motors but that's only because another manufacture 'annoyed(them)', so to speak.
Old 03-22-2013, 08:12 AM   #824 (permalink)
i know this is 700 forum but its on topic.
after crash i got my fusion 50 back together first flight hit idle up
and loud tail hum.
i was checking out this thread and thought it must be the torque tube.
went ahead and put a third bearing in no change.
then i found this video of logo 500 belt drive with the exact same humming sound.
[ame]http://youtu.be/-aUrasDcHQk[/ame]
so it doesnt seem torque tube related.
ive changed out my gears and tail shaft didnt help,i guess ill try different blades
drewdcsi is offline        Reply With Quote Quick reply to this message
Old 03-22-2013, 09:59 PM   #825 (permalink)
I love the Align comment.
Very much on topic.
Feeback is offline        Reply With Quote Quick reply to this message
Old 03-22-2013, 11:15 PM   #826 (permalink)
For those running three bearings on the tt what spacing are you running? Does it really matter as long as the four sections are all a different length?
shein95 is offline        Reply With Quote Quick reply to this message
Old 03-23-2013, 09:50 AM   #827 (permalink)
and loud tail hum.
I had the exact same problem with my Logo 500 SE, Def had nothing to do with the TT.
Align Trex 700 V3 DFC HV - Vcontol Touch ¦ Mikado Logo 200 ¦ SAB Kraken 580 ¦ Align Trex 500X ¦ Sab RAW 500
Raydee is offline        Reply With Quote Quick reply to this message
Old 03-27-2013, 07:27 PM   #828 (permalink)
I installed the 500 mainshaft bearings in my TT-bearingholders, and its solid. No hum here at any headspeed, even with carbon-boom.
700E DFC - Ikon
700N FBL - Ikon
latte is offline        Reply With Quote Quick reply to this message
Old 03-28-2013, 12:36 AM   #829 (permalink)
I did the same- with four torque tube bearings each with an Align 500 mainshaft bearing. Definitely tighter fit in the boom. I didn't have my original Align tail blades, but the Rail blades were fine up to 2150 rpm. For grins, I tried the KBDD blades that caused massive vibrations before. No change... these heavy blades just don't work at all. The one thing I find very odd is that after spooling down, you can see one of the KBDD blades is leading more than the other- yet they are balanced perfectly according to my Kohl balancer.
Blade 130X- My cul-del-sac flyer.
Blade 450X w/MSH Brain - My Ferrari
T-Rex 600 EFL Pro w/SK-720 BE, KDE600XF & SK-GPS - My BMW
T-Rex 700 HV DFC w/VBar, Kosmik 200 & KDE700XF - My muscle heli
HFMan is offline        Reply With Quote Quick reply to this message
Old 03-28-2013, 09:02 AM   #830 (permalink)
according to my digital scale (down to 1/100th of an ounce) my original align blades were EXACTLY the same weight as my Edge 105's.. Not sure if mine are oddballs, or if the align blade weight issue is just a rumor..
TRex 700DFC CC 120HV/VBar
TRex 500 ESP/FBL CC Ice100, MiniVBar
TRex 600LE/ OS50/ Full Size VBar/ Arizona Regulator , FrankenBlade 400/Sonic head and tail/CF Frame, Blade MSR, Bunch o' planks.. DX7/Futaba 9C
Geardaddy is offline        Reply With Quote Quick reply to this message
Old 03-28-2013, 09:51 AM   #831 (permalink)
I have no problems at all with align blades running any hs. I did get the vibs after my carbon boom got a slight crack in it. Changed it out and vib was gone. It actually cracked under the boom support mount. Its never been crashed so I guess it was from flying.
NO FLYBARS
504Rone is offline        Reply With Quote Quick reply to this message
Old 03-28-2013, 10:11 AM   #832 (permalink)
the new tails have a airfoil like rotor tech tails the one now are more on the flat side so far testing well
Dino Spadaccini Team Capt Align Factory Team USA / Team Futaba
Dino Spadaccini is offline        Reply With Quote Quick reply to this message
Old 03-28-2013, 03:04 PM   #833 (permalink)
Dino, do you know when the new blades will be available? Or are you still at testing stage?
Revolectrix Ambassador
Revolectrix.com 10% Discount All Products Code
LEESS17
Lee2782 is offline        Reply With Quote Quick reply to this message
Old 03-28-2013, 03:48 PM   #834 (permalink)
i will look into this and see
Old 03-28-2013, 06:23 PM   #835 (permalink)
Can someone tell me if the dfc trex 700 tail shaft length is bigger than the old trex 700? If greater I think this is the problem. Excuse me my google translator english.
sergiobh is offline        Reply With Quote Quick reply to this message
Old 03-29-2013, 09:38 AM   #836 (permalink)
ok let me keep things clear
the new shaft is longer by a 1/8 that is not the cause of the tail hum
tail blades that are to heavy are the problem the new Align tail blades are 5 grms per tail blade no hum when you have a heavy tail blade one will lag when you load the tail causing it to go out of track and hum starts and thats when things go bad
The new tail shaft was and upgrade that we felt should be done with the new tail ratio on the E and N we also increased the strength of the tail case and with the new v2 tail grips added more to the spinning mass which in turn you need to keep the tails blades light its all part of what we do at Align there is no other Company that evolves its products like we do and make sure that all the newest stuff goes in that box.
Old 03-29-2013, 04:42 PM   #837 (permalink)
Thanks Dino for ruining it for me
I was waiting for someone to try 6 or more torque tube bearings
I tried explaining what you said but i pretty much was put in the corner in time out for stating what you have said and said before. It's been kinda comical seeing some of these ideas and wasted money. You have explained it very well Dino! I'll shut up now since I'm not being helpful.
AMA #1039539
ddj74 is offline        Reply With Quote Quick reply to this message
Old 03-29-2013, 04:56 PM   #838 (permalink)
Replace the paddle tail looks a lot like putting bearing in tail boom because both act on the symptoms and not the cause. The blades were not bad suddenly, there was a change in the design of the heli. I understand that it is difficult to Align assume an error that harmed many people. Dino, thank you for your patience, as I follow your comments on this topic for a long time and I am witness to their education, congratulations and thank you.
Old 03-29-2013, 05:23 PM   #839 (permalink)
Thanks for the post, Dino, but what you say doesn't explain why I can now fly the old Align tail blades at any RPM without hum. All I did was fit stiffer TT bearing holders and move the rear bearing forward 30mm.
I'd rather have a fix that allows me to run any tail blades, rather than be limited to having to use the few 5g tail blades that are around.
Last edited by beenflying; 03-29-2013 at 05:39 PM.. Reason: Forgot to mention moving the rear bearing
Old 03-29-2013, 05:33 PM   #840 (permalink)
Originally Posted by beenflying View Post
Thanks for the post, Dino, but what you say doesn't explain why I can now fly the old Align tail blades at any RPM without hum. All I did was fit stiffer TT bearing holders.
I second that because I have some sweet lime green KBDD blades that are useless right now.
Spartan Vortex, Scorpion Motors, ExperienceRC Batteries, OMG Servos
FrSky Taranis
DaveHolland is offline        Reply With Quote Quick reply to this message
