Go Back   HeliFreak > R/C Electronics Support > CJY Total-G FBL System
CJY Total-G FBL System Curtis Youngblood Total-G FBL Flybarless System Software and Hardware Support
Old 05-18-2012, 07:24 AM   #1 (permalink)
Default Gov question
I have the gov setup on my gear switch however that is also my fc gain switch. How can I lower the headspeed without lowering fc gain? Also in the program menu or in the gview for gov the numbers are not headspeed but output frequency right? If not its got my ys56 trying to push a 2150 hs and that's no good. I want 1950
rotor head33 is offline        Reply With Quote Quick reply to this message
Old 05-18-2012, 07:57 AM   #2 (permalink)
I'm using a jr9303
Old 05-18-2012, 12:57 PM   #3 (permalink)
Move the FC to Aux 3 or the gear to AUX3
Tommy Wagner is offline        Reply With Quote Quick reply to this message
Old 05-18-2012, 04:59 PM   #4 (permalink)
i put the gov on the aux 4 and i think that will work just fine and used the gview2 to set the rpms to 1950
Old 05-25-2012, 03:21 PM   #5 (permalink)
Going along with this thread...cant I just use the gov option on the TX(9303)?? When I cycle through the idle up switches..the numbers are correct on the interface. What I am wondering about is shouldn't my throttle go full open and stay there while in idle up??? This of course in on the bench. Oh and mine doesn't stay wide open, it closes and opens not matter what flight mode....
Andre
Outrage Velocity 50
Outrage Fusion 50
RCA EC-145 600 size...Coming Soon
2TOFLY is offline        Reply With Quote Quick reply to this message
Old 05-25-2012, 07:59 PM   #6 (permalink)
The curves need to be at 100% for the throttle to go to full open
Tommy
Old 05-25-2012, 08:17 PM   #7 (permalink)
Andre, the Gov in your radio will just tell it what RPM to maintain. Your throttle servo will follow your throttle curve set in the radio.
Team Only Fine Helis
Rave ENV Nitro, Protos 380 Evoluzione, Protos Max v2, VBar Control
https://www.onlyfinehelis.com/
mystar60 is offline        Reply With Quote Quick reply to this message
Old 05-28-2012, 02:53 AM   #8 (permalink)
ok thanks..so it is not necessary to put my throttle curve to 100% because the GOV will tell it where to go once on...Am I understanding this correct?
Andre
(havent had the time to go and fly it yet...will this week though)
Outrage Velocity 50
Outrage Fusion 50
Old 05-28-2012, 07:19 AM   #9 (permalink)
yes andre. once it kicks in your set to go unless you put the setting on active in the gov menu in which case it will follow your throttle curves
Old 05-28-2012, 09:10 AM   #10 (permalink)
To add to what rotor head33 said, you can choose 2 types of Governor settings - Normal and Active.
Normal will run the Gov setting you tell it while Active will follow the curves AND add to the curve. If you are running a Nitro you generally set your throttle curve with out the governor first. After you are happy with the curves you can turn on the Governor and choose between the two choices.
On the Nitro if you throw a magnet or loose the sensor you will revert back to the curve. If it is correctly set you should see little effect. If it is a simple V curve you would notice the change in RPM's right away.
Old 05-28-2012, 09:30 AM   #11 (permalink)
Thanks Guys..thats what I thought.
Andre
Outrage Velocity 50
Outrage Fusion 50
