Like Tree1Likes
Old 04-05-2013, 03:54 AM   #321 (permalink)
Default Replacing a nano frame
I posted this in another thread. This is a quick way of replacing a nano frame.
I do not remove the head at all, nor any swash ball links.
To replace frame and motor:
- Remove canopy
- Unscrew main board
- Disconnect motor and tail from board
- Remove tail
- Unscrew each servo from frame
- Remove servos from frame, unlinking from swash pushrods (do not remove pushrods from swash ball links - this can be tricky with back servo as little manouvering room).
- Remove landing gear
- Remove main gear (should pop off - may have to scrape off some glue)
- Pull out main shaft (head assembly and swash attached - carefully remove swash AR pin from guide)
- Remove motor from frame
- Remove main bearings from shaft (gentle circular motion with screwdriver)
(now completely disassembled for frame transplant - great time to clean servos)
- Add bearings to frame (great to time to re-grease shaft bearings)
- Add motor to frame
- Insert main shaft into frame (carefully ensure swash AR pin is in guide)
- Add main gear (check mesh with motor pinion, should be good, but no friction - once happy, glue with liquid electrical tape if desired)
- Add landing gear
- Attach servos to swash pushrods and re-screw to frame
- Add tail (wind wire around canopy pin and plug into main board)
- Connect motor to main board
- Screw main board to frame
- Attach canopy.
This method keeps pushrods at same length, so no 0 pitch adjustment required.
As pushrods, not popped from swash, no stress on swash links. I find detaching an attaching ball links stressful as you have to be careful not to break these little things.
A note about gluing motors. If you do glue your motor in, you will need to remove a servo to replace a motor so you can scratch off the glue.
Be careful handling frame as canopy pins can be quite weak.
This works method works for me. Hope it helps others.
Old 04-06-2013, 02:40 AM   #322 (permalink)
Default shakes
Hi all
This is my first post so i hope its done ok.
Finally worked out my shakes on my nano after trying everything,after changing complete head,adding grommets,new blades,new main gear.
It worked out to be twitchy bloody servos,cleaned and or replaced and br mild nano flew like a dream.
Hell happy as, as its been a problem for a while.
paul.3 is offline        Reply With Quote Quick reply to this message
Old 04-08-2013, 08:29 AM   #323 (permalink)
Default Nano CP X tips
I picked up an e-flite 35c lipo over the weekend. I can't feel any difference between that and the stock 25c. Just thought I'd share.
- Dude Man Larry
Citlzen #006 • Blade 360 CFX • Goblin 500 • Blade 700X
lkagan is offline        Reply With Quote Quick reply to this message
Old 04-08-2013, 08:31 AM   #324 (permalink)
What kind of flying are you doing? Just hovering around, or smack 3D?
- Benton Jackson, Maple Grove MN
Roswell Flyer (retired), Concept EP (retired), Eco 8 (retired), WLToys V929 & V202, Nano CPx, Nano CPx mild BL, Nano QX, mCX2, 130x
GoatRider is offline        Reply With Quote Quick reply to this message
Old 04-08-2013, 06:55 PM   #325 (permalink)
Smack and (miniature) big air 3D. I focused on hard collective like tic-tics and rainbows.
- Dude Man Larry
Old 04-11-2013, 06:05 AM   #326 (permalink)
+1
My battery findings so far:
The 35C E-Flites aren't really much better than the stockers. Bit more power in the very beginning, but they loose their omph pretty fast. Very disappointing! I had hoped for MicroHeli power combined with lower weight...
Stock batteries does not seem to last very long, no biggie though. (I charge at 0.3 amps).
Now! The 200mAh 35C MicroHeli batteries! They are much more powerful than the stock or E-Flite 35C batteries! And they stay powerful during the entire flight! HIGHLY RECOMMENDED!!!
http://www.microheli.com/store/produ...roducts_id/941
Micro: OMP Hobby M1
Big: SAB Goblin 500
Radio: Spektrum DX8 Gen 1
Old 04-11-2013, 10:22 AM   #327 (permalink)
What kind of flight times are you getting with the microhelis?
Besen is offline        Reply With Quote Quick reply to this message
Old 04-11-2013, 01:12 PM   #328 (permalink)
Haven't tested, I still fly 3:30 like I do with the stockers. But you could probably go longer... (I fly Mild BL)
Anyone compared to the 200mAh Oversky batts?
One more tip: Stay away from the AEO tail motor. Weaker than stock and last shorter. Too bad as the price is good.
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 04-11-2013, 01:21 PM   #329 (permalink)
I've got both, with the label off the MH they are almost indistinguishable. I set my timer to 5 minutes.
Old 04-11-2013, 01:26 PM   #330 (permalink)
Thx! Wow! 5 sure is great, will try!
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 04-11-2013, 01:56 PM   #331 (permalink)
I set my timer to 4 for stock LiPos. YMMV.
Old 04-11-2013, 04:55 PM   #332 (permalink)
I'm at 4 for stock lipos too. They come down at around 3.78 volts which is good. I haven't paid attention to milliamps put back in which would be the right way to tell. I push the heli.
- Dude Man Larry
Old 04-11-2013, 08:57 PM   #333 (permalink)
I also use the stock lipos and set the timer for 4 minutes. I put back in from 115 to 120 mah. The heli is all stock (except for about three pounds of scotch tape on the canopy).
Old 04-12-2013, 07:15 AM   #334 (permalink)
Default Anyone tried to fit these canopies?
http://www.ebay.com/itm/Skyartec-WAS...item3ccfe4f413
http://www.ebay.com/itm/Skyartec-WAS...item51a9d66d94
http://www.ebay.com/itm/HELI-MAX-NOV...item48540f3abf
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 04-14-2013, 12:27 PM   #335 (permalink)
I got the http://www.ebay.com/itm/Skyartec-WAS...item3ccfe4f413.
Name:	Nano 2013-04-14 10.12.19.jpg
Tarot 450 Pro DFC
Blade 300x Blade 180CFX
jlk69 is offline        Reply With Quote Quick reply to this message
Old 04-14-2013, 02:56 PM   #336 (permalink)
Originally Posted by jlk69 View Post
Lookin' good there! Did the canopy holes fit too?
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 04-15-2013, 12:53 AM   #337 (permalink)
Had to punch new holes. You can see in the pictures the stock grommets (behind the other two). Will trim to eliminate them. Canopy needs reinforcing along bottom. Didn't do it and second crash cracked it. Have repaired with a thin piece of plastic glued with CA. Better to put some tape along the bottom edge and maybe it doesn't crack with easy crash.
Name:	2013-04-14 22.58.31.jpg
ID:	412639   Click image for larger version
Name:	2013-04-14 22.59.21.jpg
Tarot 450 Pro DFC
Old 04-15-2013, 03:01 AM   #338 (permalink)
I see. If they're weak I guess it's better to stick with the WLToys ones in stead
Look cool though!
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 04-16-2013, 07:05 AM   #339 (permalink)
Update: It flew like a turd yesterday, real blowout city! I had concluded the AEO tail motors are weaker than the stockers and are not usable. Then I recalled NCCraig's statement that the V2 tail is much better than the KBDD one. I never felt the same. Yes, it's a hair better when totally new. But it gets bent outta shape very easily while the KBDD just keeps going.
BUT! The V2 is lighter, so I put it on just to test if that suited the AEO motor better. Plus upgraded to MH alu grips and head... the result was a totally new heli! It never flew better! It even sounded and felt like it had more head speed and more pop! And as long as the V2 rotor is in good condition very little tail blowout!
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 04-16-2013, 12:36 PM   #340 (permalink)
Good stuff!
CousinLarry is offline        Reply With Quote Quick reply to this message
