Old 03-14-2011, 02:19 AM   #1 (permalink)
Default Outta HIBERNATION ! (JONDABEAR IS BACK)
Sorry for the absence guys......new cub in the house, ......writing code all night for the new website........2-3 hrs sleep a day.......waaahhhh waaaahhhhh waaaahhhhhh!!!!!!
You get the picture. My apologies for not being around more. I wear ALOT of hats and have had to juggle em all too often. Well......that being said. Im out of HIBERNATION. Fully ready to get back to the meat and potatoes of helping out where I can.
Soooo without further ado..............QUESTIONS?.........Shoot AWAY! Because..........................IM back......... PEACE!
Btw, check out the work Ive done on my new website. Pretty cool stuff.
jonsheliwerx.com
jondabear is offline        Reply With Quote Quick reply to this message
Old 03-14-2011, 05:27 AM   #2 (permalink)
Welcome back
Spindle is offline        Reply With Quote Quick reply to this message
Old 03-14-2011, 02:29 PM   #3 (permalink)
Thanx bud....
Old 03-14-2011, 07:15 PM   #4 (permalink)
Ya welcome back, we missed you infinite wisdome All ya new build and no band aids on the 3G sensor, remember the band aids? band aids are good. LOL
bad007 is offline        Reply With Quote Quick reply to this message
Old 03-15-2011, 06:45 PM   #5 (permalink)
Good to see you back, was wondering where you were.
Asked a question a little while back and would like to hear your opinion.
My 550 3G is flying great right now, no tail wag any more, thank you all. However, even with the swash perfectly level during set up in all pitches, when I am flying I need to give it constant left and forward cyclic adjustments. Is this drift? Do I need to increase the gains?
artski is offline        Reply With Quote Quick reply to this message
Old 03-15-2011, 07:04 PM   #6 (permalink)
Double check swash initulized and the helli setup level using the cable tie method, I had a sensor set not quite level and it tilted the swash. Hows it mounted?
Also make sure the sensor is pointing perfectly straight.
Hange by main blades at 90deg. to boom and double check COG, most people just pick it up by the stopper and look for the skids to lift even.
Old 03-15-2011, 07:32 PM   #7 (permalink)
Sensor is mounted with Align or Futaba sensor tape on the bottom plate, COG is a little nose heavy but within allowed parameters.
Old 03-15-2011, 07:54 PM   #8 (permalink)
Nose heavy, how'd you do that? Checked hanging?
I had to put 1oz of sticky weights under the battery tray to get my COG close and still got some tail.
How about the swash with the helli leveled and powered up. Actually put a level on the bottom plate and accross the frame, level it and check the swash
Old 03-15-2011, 08:51 PM   #9 (permalink)
Running Hyperion 35C 5000mAh packs, even with stuffing them as far to the back as it can go it's still nose heavy. I'll have to put a level on the bottom plate and check it tomorrow.
Old 03-15-2011, 09:29 PM   #10 (permalink)
OK......bit o info from ya......... Have ya tried the 3m or loctite version of the CLEAR doublestick stuff we use? Its really good for a rigid mount yet still absorbs and dissipates vibration.
Another question........Are we talking drift? or are ya trying to get it to stay in 1 Place?
Theres a BIG difference between FBL and stabilization systems....
Last.... how about a pic? Gimme the sensor mount with surounding wiring....thatll be good enough to make some suggestions for ya. Even a small PHONE shot would work. Just gotta see what Im working with. (Ive personally helped about 2-3 dozen people using this little trick. Gives me a basis to give suggestions by. )
Old 03-16-2011, 07:34 AM   #11 (permalink)
Haven't tried any other double stick tape, is the 3M stuff the 4010? Will try to get you a pic after work tonight. Don't know if it is drift, I just have to constantly give it left and forward corrections, in hover and forward flight. Could understand if it was corrections in all directions but its always left and forward. That is what I am trying to figure out, is this normal or is it drift?
Old 03-16-2011, 11:47 AM   #12 (permalink)
Not normal........Im gna do a little vid tmrw morn about what a liftoff should look like......Got my sons here for spring break soo gotta get em to do SOMETHING......cameramen they shall be!!!!
Old 03-17-2011, 09:51 AM   #13 (permalink)
Question Wag the heli, wag boy!
JondaBear,
We have never responded but I have gotten my bachelors degree in 3G from you and others, thank you!
I have had my maiden... All went swell except a VIOLENT tail wag. So, I did two things:
(550 fbl 3G)
1) set it for a smaller heli (red led)
2) lowered the response rate via 3G panel
Results: MUCH better! BUT I still have a small wag about 1 degree in either direction at hover (no noticeable drift)...so I tried:
1) tx gain settings... No help or even any pos or neg change (?weird)
2) threw it out the window into traffic (the tail doesn't wag anymore ) that's a joke
I have my sensor mounted on the bottom Trey below the boom with Spartan thick take/ metal plate/ Spartan thin tape/ sensor. Stap tightened. I have not done any sensor mods (mainly because the ele/ail works great in hover and FF.
Thoughts/critiques are more then appreciated!!!!
Walt
Uncle Sir is offline        Reply With Quote Quick reply to this message
Old 03-17-2011, 10:25 AM   #14 (permalink)
Originally Posted by Uncle Sir View Post
JondaBear,
(550 fbl 3G)
Walt
Lower rudder lock 5 at a time.
Old 03-17-2011, 10:48 AM   #15 (permalink)
Rudder lock?
Gain...?
Old 03-17-2011, 11:50 AM   #16 (permalink)
To all: I opened my sensor (2.1 shipped) and it had silicone in it! You guys might already know this but to the guys that figured this out; align owes you a thank you for solving THEIR problems... Amazing! -1 align in my book, and it's getting thick.
Old 03-17-2011, 12:45 PM   #17 (permalink)
+1 rudder lock gain......Ill elaborate more later...
Old 03-17-2011, 02:28 PM   #18 (permalink)
Thanks gents!
Old 03-18-2011, 07:17 AM   #19 (permalink)
Can someone explain rudder lock? Is this the 3G system gyro gain?
Trex 550e 3G stre....tched to a 600 Cam Ship hauling a GoPro, Sony sn777, or Nikon D3100 all downlinked / trex250 for backyard 3D (mild+)... Fun little bird / blade mcp x... You DON'T have one yet?????
Old 03-18-2011, 12:02 PM   #20 (permalink)
NO, rudder lock is the third setting down in the 3G interface, there's aile, elev roll lock and rudder lock. Lower it
