Thunder Tiger Electric Helis Mini Titan E325, Raptor E550 and E620 SE Helicopters |
02-27-2014, 01:05 PM | #21 (permalink) |
Yessir, that is our heli club field in Lehi, UT. If you are a real flight simmer you can download both the winter and summer editions of that flying field :-) They are under the photo fields.
Thanks sir, -Adam |
02-27-2014, 01:49 PM | #22 (permalink) | |
Re: Not impressed with my new Thunder Tiger e360.
Sent from my XT1028 using Tapatalk |
02-27-2014, 05:40 PM | #23 (permalink) | |
Trex 250 Plus, Trex 550 Pro DFC, Trex 500L, Trex 450L, Blade 180 CFX. |
02-28-2014, 12:12 AM | #24 (permalink) |
Awesome! lets get it sorted out for sure. Let me check my parts stash and see... I may have everything needed to fix it. If so you can use those parts and just replace them when you get yours in.
Later man, -Adam |
02-28-2014, 06:53 PM | #25 (permalink) |
Slighty off topic chaps, but do you know if the E360 canopy will fit an MT V1? I really want the green design for my V1.
I currently have the E325S V1 canopy, but its only available in red... cheers...
Nick Flying your heli the world is still out there, but at least for the time it hasn't got you by the throat. Mini Titan E325 FBL, Blade Nano Cpx |
02-28-2014, 11:41 PM | #26 (permalink) |
Nick, I really have no idea... I wish I knew and could help you on that one. But I will see if I can find out!
-Adam |
03-02-2014, 03:09 PM | #27 (permalink) |
Me and Adam spent a few minutes with the e360 at the field and we got it working now. Seems that for some reason it was really not liking the governor but once we turned it off it spooled up great. I will get some more testing in once I get the parts I am waiting on and then I will get an update posted. Thanks again Adam.
03-03-2014, 09:00 PM | #28 (permalink) |
Finally got a chance to test it out a bit. This heli flies awesome now that we turned off the governor and it has tons of power. Seems to get pretty decent flight times too but I still haven't opened it up. Gyro will need some tuning but overall I am happy with how its flying.
03-03-2014, 09:22 PM | #29 (permalink) |
Glad you got it sorted So the governor is built into the ESC?
Chase 360, Protos380x3, Goblin500, Raptor E700 x2 JETI DS-16, SKOOKUM & YGE |
03-04-2014, 02:55 AM | #30 (permalink) |
Yup. Built in and turned on by default. I recommend anyone that gets this heli just turn off the governor. Its a night and day difference. The 2 flights I got today we're great and I am so impressed with the power. Now it's time to start working on the gyro. I would like it to be more locked in but that is clearly just a matter of getting the gyro settings right. Every heli I have had needed a touch more gain than normal and I suspect it's due to elevation.
03-04-2014, 10:30 PM | #31 (permalink) |
I have been fighting the ESC wires when putting the canopy on but today I realized that the lower canopy mount is removable and the wire routing didn't really allow it to be used anyways. The canopy stays fine without it but removing the mount makes the canopy much easier to attach. I am working on getting the P values set now and the tail was already close but I just can't seem to get enough on cyclic. I am already at 105.
03-05-2014, 09:54 AM | #32 (permalink) |
Have you assigned a channel to change the overall swash gain on the GT5.1? If you don't have that setup and able to increase overall gain (default is 50 and static if you don't assign a channel) you'll chase increasing everything else too much and end up with maxed values all over the place.
-Adam |
03-05-2014, 05:27 PM | #33 (permalink) |
Yup. I didnt understand the total gain feature at first but now that I figured it out it makes perfect sense and I like knowing I can instantly drop the gain if I overdo it but I am doing my tuning with 100 total gain. I assigned it to a switch like the manual suggested. I got the tail locked in now and the swash is getting there. This heli gives impressive flight times for its size. I would be curious to know how much swash gain others are using as I am at 110 currently. I am pretty sure I have the total gain working right since I used it to dial in the tail and it worked as the manual said it should. As I understand it total gain is gain for the swash and tail.
03-07-2014, 09:13 PM | #34 (permalink) |
Glad everything worked out. I was just looking at getting the regular Thunder Tiger Mini Titan E325 V2 450 size Flybarless Helicopter and right away spending the $40 for the extension. The extension comes with the larger canopy so I would say the 360 will fit the 325.
Micah |
03-07-2014, 11:44 PM | #35 (permalink) |
Just make sure the extension is for the v2 if the canopy is included.
v1 and v2 canopy are different
03-08-2014, 12:13 PM | #36 (permalink) |
From what I can see it looks like the only one they are selling anymore is only for the V2. The other one has been discontinued.
Micah |
03-08-2014, 12:43 PM | #37 (permalink) |
You can still get an E325S from Tower. That's a v1 FBL.
Specter v2, Tron Dnamic, Nimbus 550, P380, Edge-TX |
03-08-2014, 02:28 PM | #38 (permalink) |
Sorry I was talking about the extension kit not the heli. You can also get the V2 belt FB from rc711 for $200
Micah |
05-12-2014, 09:41 PM | #39 (permalink) | |
Also, to confirm the ESC settings, should I only need to confirm that the governor is turned off? Thanks in advance!
Specter 700, Synergy 516, Goblin 500 Sport, Oxy 2, OMP M2 V2, Blade 300 CFX, Oxy 3, Blade 270 CFX, Align 470LM, Goblin 380, Devil 380 |
05-13-2014, 05:21 AM | #40 (permalink) |
We turned off the governor on mine only due to the issues we were having spooling it up but in retrospect I think this could have been resolved by messing with throttle curves more. I think that the DX7s might output throttle curves differently than other transmitters and this may have been my issue. I can't speak to the 3D flight performance as I only fly sport but in my very limited experience it took quite a bit more tuning to get it to my liking than my AR7200BX did on my 300x or my X50. I do like the GT 5.1 quite a bit though.
