Old 05-23-2013, 07:33 PM   #1 (permalink)
Default Alarms what to do with them ?
Ok with the Mezon I can set alarms for a lot of things some I can see what to do with others what do you think:
Capacity
U BEC
I BEC
U Battery
I Battery
Revolution
Temp.
PWM
Capacity is easy I actually have 2 alarms. One for max mAh when I should think of landing, one for when I should land if I don't want to discharge my LIPO lower than 20%
U Battery to see if I loose LIPO cells
Temp. an obvious one too set at 150 degrees as per Danny
I BEC
U BEC
I Battery
revolution
What can i use them for as useful alarms ?
and the most unknown PWM
Old 05-23-2013, 07:39 PM   #2 (permalink)
The rest can be handy on the logs when trouble shooting and that is about it. I think U batteries is the flight pack U BEC is the BEC voltage I think.
BustedRaptor77 is offline        Reply With Quote Quick reply to this message
Old 05-23-2013, 07:44 PM   #3 (permalink)
yes U is voltage and I is amperage and yes one is the BEC the other the flight pack
Just want to make sure I am not missing some alarms that might be useful
Old 05-23-2013, 07:48 PM   #4 (permalink)
Originally Posted by Puttputt maru View Post
U BEC to see if I loose LIPO cells
Is this a typo?
Old 05-23-2013, 07:53 PM   #5 (permalink)
Is this a typo?
yes
corrected above thanks
Old 05-23-2013, 07:56 PM   #6 (permalink)
I use my U BEC this way
https://www.helifreak.com/showthread.php?t=532569
Old 05-24-2013, 01:06 PM   #7 (permalink)
One suggestion... I have a BEC amperage alarm set. After flying several flights and keeping a log of the peak BEC current recorded in the min/max log of the Mezon I set an alarm about 2A above the highest peak that the Mezon recorded.
If that high BEC amperage alarm happens to trigger in flight it could be a sign a servo is starting to have problems and drawing excessive amperage, a linkage is binding requiring additional servo force, etc. It might not work that way and may never trigger in "real life" but it's still a nice to have alarm IMO. It isn't obtrusive and might help you spot a problem before it downs the heli so why not enable it?
Minicopter Diabolo - BD Axon, Kosmik 200, Xnova XTS 4530-480, 14S 4500, BLS255HV/BLS256HV
Bergen Magnum 44 -
BD Axon, Wren MW44 turbine, BLS156HV/BLS256HV
Jeti DC-16
Kiba is offline        Reply With Quote Quick reply to this message
Old 05-24-2013, 03:31 PM   #8 (permalink)
Technically not an alarm, but a voice on event...
I put a tiny pop sfx whenever the throttle stick passes through the centre position...
Because the sound is a pop, you can actually feel it subtly in your hands.
Some people make little physical indentations on the actual gimbal rotating thingy inside the radio - I did it electronically.
Would've liked to have another tiny sfx where I have -5 degrees of pitch (great for autorotations) but I don't think that is possible...
Groucho_ is offline        Reply With Quote Quick reply to this message
Old 05-24-2013, 03:37 PM   #9 (permalink)
Great idea. The -5 degree is intriguing and needs to be solved. One thing to do tonight.
Old 05-24-2013, 03:48 PM   #10 (permalink)
Default Re: Alarms what to do with them ?
How did you do that?
Sent from my cellphone
Jotto is offline        Reply With Quote Quick reply to this message
Old 05-24-2013, 03:54 PM   #11 (permalink)
Interesting idea. I've noticed that on my TDR I haven't quite adjusted to the ergonomics where I can consistently find zero pitch on rolling tail slides. That might be just the ticket. Where did you get the .WAV file for the "pop"?
Can you set a logical switch for the left stick ">X" and "<Y"? By defining a tight range of X and Y, it seems you could set it to trigger at the stick position that you want.
Have laser, will travel.
cbdane is offline        Reply With Quote Quick reply to this message
Old 05-24-2013, 04:22 PM   #12 (permalink)
I'd like to see alarms by flight mode at some point. I think there would be some value added for doing autos. It would be obnoxious to set a repeating alarm for a high and low head speed, but if this could one day be activated when hold was on you could set a head speed range (high alarm, low alarm) to try to keep the model in.
Old 05-24-2013, 04:42 PM   #13 (permalink)
Post here if you manage... I'm too tired to try before tomorrow...
In 'sounds on event'
Add 2 events.
Assign to P4 - One with the stick up, and the other withe the stick down.
You can add the same sound or different sounds.
I'll modify the sound slightly to be just a little bit different when I travel from negative to positive, and when I travel from positive to negative.
I've got a library of SFX from my real job, but I used the system sound 'pop' from my mac...
You can find very good free sfx online. Try http://soundbible.com
Brilliant thinking.
Old 05-24-2013, 06:25 PM   #14 (permalink)
Brilliant thinking.
Thanks, but I was thinking about this some more and it dawned on me that the main rotor would be freewheeling so you would have to use a mag pick up or this
http://www.espritmodel.com/jeti-tele...o-mrpm-ex.aspx
So not as simple as my initial thought.
Old 05-25-2013, 02:33 AM   #15 (permalink)
Well, it seems i've reached the limit of the DS-16 as far as sounds on events are concerned...
You can have up to twenty of them, and I've used them up...
Old 05-25-2013, 02:39 AM   #16 (permalink)
This is a better solution than my original method.
This way, you only use one sound on event instead of two.
Just tried it and it works!
EDIT: You do have to set the range somewhat wide though... -20 to +20, and even then, sometimes a very quick stick movement would be too quick for the radio to register as having passed from off to on and back to off again.
Old 05-25-2013, 03:17 AM   #17 (permalink)
Twenty per model, per event, per transmitter?
SAB Goblin 500
SAB Goblin 700
Jeti DS-16
bobloblaw is offline        Reply With Quote Quick reply to this message
Old 05-25-2013, 03:21 AM   #18 (permalink)
I didn't know that logical switches could be set up by stick percentage, but that's pretty cool!
Old 05-25-2013, 03:28 AM   #19 (permalink)
I'm pretty sure that would be twenty per model...
Old 05-25-2013, 08:54 AM   #20 (permalink)
Yes it is, as the sound per event is a per model function and not a system wide function
