Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > nano CP X Brushless Mods
nano CP X Brushless Mods Blade nano CP X Brushless Mods Information and Help
Old 05-31-2014, 04:14 PM   #401 (permalink)
Default Re: Brushless Nano Cpx. Post your setup and discussion thread.
Originally Posted by MrRoboHeli View Post
How many of you guys regularly oil your outrunner Oversky motors? Is that needed with the bearings on these? Or is this one of those things where once you start oiling them, you need to keep doing so?
I use trinity royal oil in all of mine, a drop in each bearing every month or so. it stays put and doesn't harm any plastics.
Dylan ~ www.AstroidDesigns.com
Dylwad is offline        Reply With Quote Quick reply to this message
Old 05-31-2014, 06:49 PM   #402 (permalink)
Hi Guys!
Sorry for being away for a long time.
A work project took all of my ``free`` time.
For the users of the frame, can you please tell me what I should change to make it better ?
- The most common issue seems to be the fitting of the landing gear.
The frame does not allow any other LG then the MSR LG.
- The ``nipples`` for the canopy attachment can also be holes to fit in 1 or 1.5mm carbon
rods.
- The new V2 Wild and mild motors are released but I do not have one myself.
I will probably buy one if they are back on stock at Asteroids to try it.
If you want to contact me personally please use this adres from now on;
yflightservice@ - Google`s mail service - .com
Best Regards,
Yannic van Moerkerk.
Yannicflight is offline        Reply With Quote Quick reply to this message
Old 05-31-2014, 07:25 PM   #403 (permalink)
Default Frame testing
Hello Yannick,
I have tested durability to my utmost. These frames are great. I have broken only one pin in a hard parking lot slam. I have some 1.5mm CF for repairs.
I believe that the main gear survives in your frame better than in a Blade frame. My gears survive quite a while now. Maybe the motor is glued in better. It's certainly not because I am better on the TH switch.
I tear up some mainshafts but at $1 apiece from Tmkarc1hobby.com I don't fret..
Can you tell me the weight difference between your HD frame and the lighter one?
I will order a couple of light frames soon.
I use Blade FAI mCPX skids with Oversky 300mah 45C 8 gram battery. Try these batteries. They fit mcpx skids. They are fantastic on DB nanos and Black Dragon mcpxs. Mcpx FAI skid's could fit a bit better and they break very easily but they look really cool. I use FAI skids on all my mCPXs now, too. I would like it if you made the frame to fit mcpx skids.
Heck. Make some short wide FAI looking skids that don't fall apart. I will buy a lot of them.
Skids are my largest expense. I really like the width of the FAI skids because I use Nanotech 450ma 65C cells for my HP06s. I stick them under with two pieces of velcro
You did really well, Yannick. I admire you. And Thank You. I fly my nanos the most..
Dave
Good luck and happy landings.
daveapplemotors is offline        Reply With Quote Quick reply to this message
Old 05-31-2014, 07:59 PM   #404 (permalink)
Default Yannicflight
Nice frame only thing I would change would be to have it fit better with the MCPx landing gear and by maybe adding another hole to the rear it would fit both skids. Also maybe do something to stiffen the tail boom side to side. The canopy pins might be better if they were holes for 1.5mm rod and with the front canopy the rod could go all the way through to be one piece for both of the front and the rear could just be reinforced to be all the way round with cf rod halfway through. We can just drill it out after the pins break, but it is not easy. I broke a pin nipple too and fixed it by drilling and insert a paper clip because I had no 1.5mm rod. If it was predrilled, it might be better but then we would need the 1.5 mm cf rod which is not a problem, but the canopy pins might need reinforced even more to support the rod with good strength. Motor mesh is awesome on this frame.
Get high on a Chopper! Do it inverted!
JEBSi is offline        Reply With Quote Quick reply to this message
Old 06-01-2014, 10:56 AM   #405 (permalink)
Originally Posted by NCcraig View Post
Or you could go this route which includes the weight of the servo mounting screws.
Seems like a nice product as well. We need these all plastic frame options because they are lighter than metal/cf and they stay straighter by flexing back instead of bending like metal, plus they are cheaper.
I wish Blade would get in the game and make a brushless frame, plus a canopy and landing gear to go with it. They should upgrade the models yearly like a 9th generation car. Versions 1 & 2 are not as impressive as versions 3 & 4.
Old 06-01-2014, 02:12 PM   #406 (permalink)
Thanks Dave and JEBSi,
I will make a version of the frame with extra side support for the tailboom.
This can be done using very thin 1mm CF rod or by creating 2 extra triangles on the left and right of the tail boom mounting pod.
Changing the nipples for the canopy mounting to holes for small CF pins will surely increase the strength.
The weight will remain the same.
Can anybody tell me the exact dimension/distance of the M-CPX LG mounting pins?
I will make another version of the frame since weight is so important on the Nano that adding another mounting tube will add more unnecessary weight.
@Dave, The light frame will be back on shapeways soon but I have to change the canopy pins a little bit first.
The canopy pins where to small and volatile, they often broke of already during shipping.
Best Regards,
Old 06-04-2014, 04:52 PM   #407 (permalink)
I measure 30.1 mm (maybe 30.15?) for mcpx
I measure 28.1 same method for nano
As near as I can get with my old eyes and cheap measurer..
Old 06-05-2014, 07:31 AM   #408 (permalink)
My mcpx landing gear is all bent so I did not measure it.
Old 07-01-2014, 07:02 PM   #409 (permalink)
hey Dylan, when will you release the wild v2 brushless upgrade? ive seen the v2 in action but haven't seen the wild v2 yet.
"Home grown rc helis, always perform the best"
Jad C.
battlemachine2 is offline        Reply With Quote Quick reply to this message
Old 07-01-2014, 07:19 PM   #410 (permalink)
Parts are on order for the Wild V2 kits, should be a few weeks. I might have to start taking pre-orders to be able to fill the needs....
Old 06-04-2015, 01:10 PM   #411 (permalink)
Default I finally broke a skid post
I fly and crash a lot. Ask my friends. This is unsolicited from the vendors.
Yannickflight Frames need no adapters for servos or motor.
Airtime skids--I haven't broken any skids and my nanos weigh nearly 40 grams*.
DFC grips with larger feathering shaft: Tkmarc1hobbies https://tmkarc1hobby.com/alu-blade-g...x-nacpx02.html
Those mods for a brushless nano make for a durable machine.
*double brushless, 300mah battery, metal grips,etc.
Old 06-04-2015, 03:12 PM   #412 (permalink)
Wow that's some heavy nano do you have a link to the Yannickflight Frames? I got some sample frames from jim think he calls them gizmo frames they are light and very solid.My db bruslless weighs in at 30g flies like a wasp on red bull lol only using 180 hyps as well 240 at max else it just flies too heavy.
p.s the airtime skids are the best and virtually indestructible best skids ever!
Oxy 2 FE, 180cfx spartan lynx pro tail,130x stock, Goosky S1 x 2 , mcpx stock x2, mcpx bl mod, nano cpx dbl bl, nano cpx wild bl, nano cps, DX8. For fpv Phantom 3 pro.
Bhujang is offline        Reply With Quote Quick reply to this message
Old 06-04-2015, 04:17 PM   #413 (permalink)
Yannick frame.
http://www.shapeways.com/product/RVY...ouble-ar-guide
Yup I just weighed a nano at 39.4 grams with an 8.6 g lipo.. Metal DFC grips, metal swash, Yannick frame adds 0.7, long blades, CF tail support, 52mm tail rotor, long solid boom, plugs for changing parameters on both ESCs. , longer heavier power wires, etc All heavier but they fly really well. The nanos can't do everything but I can load up an mcpx / HP06 to 80% throttle and if I need rocket-like power.
Old 06-05-2015, 02:45 AM   #414 (permalink)
Yannick frame.
Yes its the 300 battery that does it! rest is fine. Its the dilemma of power and weight balance...
and sweet on the mcpx I had loads of trouble trying to mod mine. Still a work in progress...
Old 06-05-2015, 06:43 AM   #415 (permalink)
Default porky nano is still fun
Even though they are near 40 grams my nanos are tons of fun. Out of 9 helis I usually start with a nano to warm up. Besides a nano is the most forgiving in a crash.
re mcpx build:
I cheated. Dylan Stewart--Astroid Designs-- built copters for me.
My mcpx/HP06 monsters came back from AZ ready to fly. And he built my other 2 mcpxs with BD-14 motors. And my nanos...
Old 06-05-2015, 06:49 AM   #416 (permalink)
That's weird as his nano conversions are really light. In fact the mild is equal if not lighter than stock and the wild is only heavier due to the larger battery needed to power it.
Old 06-07-2015, 06:27 PM   #417 (permalink)
anyone ever thought of using a standard 10a esc with 5v bec ?
id figure the settup would go ...2S battery to power esc and then use 5v black and red BEC out to power 3 in 1 and white as signal from 3 in 1".. ? would 5v kill the stock 3 in 1 board?
brokenheli666 is offline        Reply With Quote Quick reply to this message
Old 06-11-2015, 06:20 AM   #418 (permalink)
Default My Ncpx
Heli Setup:
PJACQ Mild BL Main Motor and ESC (Gov Arm at 69%)
125mm Solid Boom, 7mm HKRC Tail Motor
Airtime Low Profile Skids
Xtreme Canopy trimmed to clear servos
Red Silicone O-Rings
Extreme Tail Blade
NPFG
Oversky 35C 200mah Bats
Norm
Pitch Curve 0-25-50-75-100
Throttle Curve: Gov Arm 0-30-69-69-69
DR : Aileron and Elevator 50
Expo: Aileron and Elevator 15
Travel Adjust: Pitch (+-)85%
Idle Up 1
Throttle Curve 100-63-25-63-100
Timer 3 Mins
Idle Up 2
DR : Aileron and Elevator 75
Timer 3 Mins
Nick
Flying your heli the world is still out there, but at least for the time it hasn't got you by the throat.
Mini Titan E325 FBL, Blade Nano Cpx
nickyd is offline        Reply With Quote Quick reply to this message
Old 06-11-2015, 06:42 AM   #419 (permalink)
Originally Posted by nickyd View Post
Heli Setup:
Extreme Tail Blade
NPFG
Sounds great. I also have a pjacq set up its great. Do you have any videos of flying yours?
Old 06-11-2015, 06:45 AM   #420 (permalink)
I don't yet but I will try to if I can persuade my daughter to film for me
Nick
