Old 12-15-2012, 07:42 PM   #1 (permalink)
Default Align Gel Tape + Double Sided Tape
Greetings all, I'm after opinions on my thought. I'm relocating BX on my rebuild project 300,
and yes I did read the thread on this "to relocate or not to relocate"but I just want to try it out.
Anyway I've found the Align gel isn't sticky enough and though I think it'll be fine with a cable tie to
actually secure it I was thinking of sandwiching the Gel tape with some sticky double sided tape. Will this
make the platform on which the BX sits on too fat or high do you think, remembering it'll have to be
dbl side tape/aln gel tp/ dbl sided tp and then BX .
Thanks for your thoughts and guidence.
347mont is offline        Reply With Quote Quick reply to this message
Old 12-15-2012, 09:33 PM   #2 (permalink)
I'm thinking that too much thickness of tape/gel/whatever is going to let your ar7200bx "rock" around on top of it under vibration and G loading and make your heli do weird things. Of course, strapping it down is quite a different matter, but if you're going to strap it down you might as well leave it inside the frame. Quite a few folks are using one layer of 4011 Scotch/3M double sided tape to mount on the top and are having great luck with it. I'm actually using one layer of 4010 (not highly recommended) and it seems to be working pretty well, though I think I'm going to 4011 myself shortly.
For the record, I don't think relocating the ar7200bx to the top of the frame has any noticeable adverse effect.
MARTY
Team Newb pilot
Trex 500 fbl -Tarot 450 Pro fbl- 300X - 130X X3- mCPX brushless X3-Nano cPX X 2- Nano QX
65L88 is offline        Reply With Quote Quick reply to this message
Old 12-15-2012, 10:36 PM   #3 (permalink)
The Align gel tape needs to be firmly strapped down to work properly. Just tie it down firmly with a nytie, same as stock. If you do this and the rest of your heli is properly setup, you're going to be one happy chappy!
The main advantage of the gel tape it that it helps to kill most vib-related problems with this sometimes hard to get completely vib-free heli.
Cheers,
TomC
Blade nQX,mCPX-BL,450x,500x Bell 222(bd3sx),550x(bd3sx)
TT X50E, 10s, bd3sx
Now also a FPV addict; Quads and Planes (soon to try heli's!)
TomC is offline        Reply With Quote Quick reply to this message
Old 12-15-2012, 11:29 PM   #4 (permalink)
Yeah thats what I was thininking TOM. I'll go the cable tie for sure had 1 as a trial and it was solid. I'm thinking of putting
a second tie on but I'll have to file a bit of the frame where it has that radius. I'll file a flat section for
the 2nd tie then round the corner so it won't split through movement and vibration. Hope that makes sense and you can visulaize it.
Little Update.
To be honest I don't trust the gel tape if mounting the BX on top of that little ledge.ITs just not sticky enough. I'm thinking a couple
of drops of CA glue, not too much, if needs to come off I can just pull it off and sand the gel tape off the frame and BX ???
Ties will be ok but theres not enough meat for them to really hold it down tight IMO.
Yes I agree and on the thread that was discussing this mod some people reverted to stock position, Im just doing it for looks, access and to try it and see which I prefer.
Old 12-16-2012, 01:02 AM   #5 (permalink)
Don't worry about putting 2 ties on imho. Just put one on 'firmly' like the stock one, that's all you need. If you over-tie it down with 2 ties you may lose some of the vib-killing, but I'm not 100% sure since I've never tried it. My ar7200bx tilts/leans 'very' slightly forward with a single tie but this does not seem to make any diff.
Just go for it and let us know how well it all went, lol!
Cheers,
TomC
TT X50E, 10s, bd3sx
Old 12-16-2012, 02:23 AM   #6 (permalink)
OK I've went with just the gel tape in the topmount position and 2 cable ties. Seems pretty secure and
will try it out like that.I also ended up cutting frame out a bit so ties can secure the BX. That big radius
was prevent this the way I saw it. I got the Scorp 2213-14 in and IceLite50 mounted. Now I'm just waiting for my
pinons and Hitec servos to arrive. I hope it'll be before Christmas. 130 out of action too so I've only got
the 450X to fly which is a little big for the park 1 minute walk from my house but I just take it easy.
Old 12-16-2012, 02:52 AM   #7 (permalink)
The irony of the Align gel tape is, it requires (in most cases) being strapped down by a medium that has the potential to introduce vibes that the tape was intended to isolate. If the gel tape/nytie combo doesn't work to your satisfaction, try putting neoprene fuel tubing over the nytie where it contacts your ar7200bx and see if that helps isolate the vibes. Try varying degrees of firmness/looseness and see if it makes a difference. Good luck, and let us know if it works for you.
MARTY
Team Newb pilot
Old 12-16-2012, 07:07 AM   #8 (permalink)
Thank you. Always good tips and tricks here on the forums. It sounds like that would work. I'll get back with the result
but it may be after Christmas as I'm waiting for parts and its a busy time for the posty this time of the year.
Old 12-16-2012, 05:20 PM   #9 (permalink)
Mounted my 7200BX on top using Scotch 4011 tape.
It's "ON THERE" like it was welded...no ziptie needed.
CHAOS 600e,Black Widow FBL, BeastX,
CHAOS/ALIGN 450 DFC BW PRO, AR7200Bx.
DX8,PL8, Phoenix.
Drev is offline        Reply With Quote Quick reply to this message
Old 12-16-2012, 07:16 PM   #10 (permalink)
The 4011 seems to be the most generally accepted medium for mounting on the top of the frame...
MARTY
Team Newb pilot
