Old 06-24-2013, 09:09 PM   #21 (permalink)
Originally Posted by Lozki View Post
Ehh its what ever...
Your respect for this forum, its rules and its members continues to degrade.
If all you want is a turn-key solution, why not bump your other thread and ask. I would have directed you to this page. Lots of plug and play options.
http://www.progressiverc.com/chargers/charger-combos
Gregor99 is offline        Reply With Quote Quick reply to this message
Old 06-24-2013, 09:12 PM   #22 (permalink)
Default Re: turnigy power supply
Charger and PS must "match".
Turnigy would severely restrict output power from 306B/PL6/PL8 (18V is very low for them). Would want Solid or Feather supplies, or the DIY version.
But Solid/Feather/DIY would blow the Hitec charger (>18V).
Can't pick one properly without knowing the other.
Any of the non-DIY can be had ready to just plug in.
Sent using Tapatalk.
Old 06-24-2013, 09:24 PM   #23 (permalink)
Default charger
so red is that a good ps for hitec rig seems to be?
k.gordon1120 is offline        Reply With Quote Quick reply to this message
Old 06-24-2013, 09:37 PM   #24 (permalink)
I just see someone asking a simple honest question, how is that degrading?
Hoghunter7mm is offline        Reply With Quote Quick reply to this message
Old 06-24-2013, 10:42 PM   #25 (permalink)
ya thanks gregor99...but your no help not at all...matter a fact your kinda lame.
Let's see.... You're asking for help. You get help but it's not the answer you're looking for so instead of just saying thanks, you call a fellow user "lame". Pot, meet kettle.
Prediction: You won't last long here with an attitude like that. Welcome to the radar....
-Kevin
Skiddz is offline        Reply With Quote Quick reply to this message
Old 06-24-2013, 11:38 PM   #26 (permalink)
Default ps
why can one use this power supply im thinking on buying one for a charger http://www.hobbyking.com/hobbyking/s...arehouse_.html
maybe some one has one give me a lil info on it how maybe they like it...any info helps thanks Lozkin noone answer the questuon brought to the forum\\\
all he is lookn for is info on this ps and he is being slammed if your not using this y chime in??? its a simple question> bty this is a rokn setup if u didnt know not the best but affordable. ya maybee a few think its NOT THE BEST but it does charge fast and is very simple THINK ABOUT IT thanks
Old 06-24-2013, 11:39 PM   #27 (permalink)
Default ps
skiddz look at the title wayyyy off trak talkn about a ps not a whole setup
Old 06-25-2013, 05:12 AM   #28 (permalink)
The 18V Turnigy looks to be a good match for the Hitec. 18V power supplies are not that common, choices are somewhat limited.
Old 06-25-2013, 07:28 AM   #29 (permalink)
Wait (skiddz) am i the pot or kettle im confused hahahai just had a Q about a ps from hobbyking, and my attitude has nothing to do with it im not as savvvy when it comes to charging yet but im working on that, slyster shoot me some charging links to read on (thanks) again slyster. Now on the other hand i can see all you guys know what your talking about when it comes to charging and your not steering me in the wrong direction...but im not looking for a supper lab here just a new charging set up and slyster pointed me in the right way with some things he told me.
MSH USA Team pilot (Lozki) Protos Maxx V2,Protos 380, jeti DS-14
Lozki is offline        Reply With Quote Quick reply to this message
Old 06-25-2013, 08:04 AM   #30 (permalink)
The Turnigy 18v supply and the Hitec x400 will work together fine. I had the x400 and did not really care for it. It is loud and doesn't balance particularly well. However, if you're looking for inexpensive and easy it will do; especially if you need (want) two ports.
Bunch of Planks, DX18, over-inflated sense of self worth!
Helis I've had: Trex 500, Compass 500, MCPX, Nano CPX
bstanley72 is offline        Reply With Quote Quick reply to this message
Old 06-25-2013, 08:07 AM   #31 (permalink)
sweet thanks bstanley72 im looking at the icharger 306 and a deep cell battery keep it KISS im trying to do
Old 06-25-2013, 08:10 AM   #32 (permalink)
Yes, he only asked about a PS, but if we know more info (like what charger he wants to run) it helps us make recommendations. If he wants to run an iCharger 306 then it is not a good option, if he wants to run the Hitec x400, then it is. Many of us (me included) spent way too much money, time and frustration trying to come up with a good charging solution. We want to help people not make the same mistakes we did.
Old 06-25-2013, 08:13 AM   #33 (permalink)
That might be a good option, however, what batteries are you wanting to charge with it?
Old 06-25-2013, 08:15 AM   #34 (permalink)
ok well it started with the hobbyking ps with the Hitec X2-400 2-Port Multicharger..http://www3.towerhobbies.com/cgi-bin...&I=LXCEYW&P=ML but it tops out at 18v so that wont work and then i was turned on to the icharger but with what ps idk
Old 06-25-2013, 08:16 AM   #35 (permalink)
(2) 3000mah 6s (4) 3300mah 6s
Old 06-25-2013, 08:44 AM   #36 (permalink)
If you don't need 2 channels, then the 306B or PL6 make a lot more sense than the Hitec, in my opinion.
Do keep in mind that you need something to recharge the deep cycle. You can use your charger do to that, but you will (wait for it....) need a power supply to run the charger at home, to recharge the deep cycle
Maybe you already have a good lead-acid charger, in which case that's less critical. Personally, I like the idea of an AC supply, so I don't have to worry about if I let it run low, etc, but there are a lot different solutions.
That's part of what makes the hobby interesting, I guess, many approaches to the same problems, each of which suits somebody.
Old 06-25-2013, 08:49 AM   #37 (permalink)
your right red i will run that battery down i have a battery charger i can hook it up to i want to be portable just grab the charger deep cell and go to the field but i also like having A/C just plug in the wall and charge
Old 06-25-2013, 09:40 AM   #38 (permalink)
If this is all you’re charging you could use the iCharger 306 or Power Lab 6 and charge them all at once in parallel.
I don't have experience with deep cycle batteries, but I don't think one will be enough to charge these six 6s batts, you may need a second deep cycle, however, I'll let one of the deep cycle experts (Slyster) chime in on that.
Old 06-25-2013, 09:41 AM   #39 (permalink)
Frankly, I don't care if the thread was titled, "Pygmy Goats From Hell"; when someone is trying to help, you don't insult them.
-Kevin
Old 06-25-2013, 10:10 AM   #40 (permalink)
Well I like the icharger 306 looks like a good charger
Plus I was looking at the thunder tiger PS from amain
