Old 07-12-2015, 10:42 AM   #1 (permalink)
Default one-way bearing issue
Got a new one-way and main gear, sleeve, housing etc etc here's the issue it's locking up during flight it is well lubed it's all brand new and I can free it up after I land but doing autos when I land no way any thoughts on this thanks
joeplumber1 is offline        Reply With Quote Quick reply to this message
Old 07-14-2015, 02:10 AM   #2 (permalink)
Just dealt/dealing with this. 3 owb's from align all locked within the first tank of gas. Tried light oil, grease, ATF, and dry -- Nothing worked. I just got the KDE OWB and put 5 tanks through it today and no lock at all on my owb.
jbaum81 is offline        Reply With Quote Quick reply to this message
Old 07-14-2015, 04:31 AM   #3 (permalink)
Thanks just what I wanted to hear
Old 07-14-2015, 12:14 PM   #4 (permalink)
+1 on the KDE unit. Installed one on my 700n. End of problems.
jiminator is offline        Reply With Quote Quick reply to this message
Old 07-17-2015, 11:52 AM   #5 (permalink)
OMG, I just went through my 5th OWB yesterday. All locked up within the first flight. Thank goodness there's a KDE part.
- Morgan Fuels Cool Power -
T-Rex 600N - YS 60SR / ProModeler servo / Futaba CGY 750
T-Rex 700N - YS 96 SRX / ProModeler servo / Futaba CGY 750
MikeG4936 is offline        Reply With Quote Quick reply to this message
Old 07-17-2015, 11:01 PM   #6 (permalink)
You wouldn't happen to have a link to the right kde bearing would you. ?
What all do I need to switch my stock trex 600n owb to the kde.?
Just the bearing .?
Thanks.
My 600n is new and only has 3 tanks run through it and no problems so far but would like to order another in advance as it seams lots of people have been having problems with the stock one. I don't like problems . Lol
krazycarl is offline        Reply With Quote Quick reply to this message
Old 07-18-2015, 05:05 AM   #7 (permalink)
I just replaced mine. Basically remove the bearing holder from the nylon gear. Pull out the sleeve that holds the trail drive gear. Put the bearing holder in a toaster oven for about 15 minutes at 350 degrees. When it's hot, use gloves to insert the sleeve in the bearing bottom (side with the writing around the edge) and twist it so it's tight and pull the bearing out. Insert the new bearing immediately. The writing on the bearing has to face the bottom of the helicopter.
meowguy is offline        Reply With Quote Quick reply to this message
Old 07-18-2015, 09:45 AM   #8 (permalink)
Thanks for explaining procedure on replacing the bearing. Sounds pretty easy .
Old 07-18-2015, 10:08 AM   #9 (permalink)
Just the bearing .?
Thanks.
http://www.amain.com/rc-helicopters/...00-owb/p196861
This is the one I'm using on my main. It doesn't say its for the main but the specs are right and it works
Old 07-18-2015, 01:46 PM   #10 (permalink)
Thanks a lot for the link.
Old 07-18-2015, 02:08 PM   #11 (permalink)
I should clarify my post as I think I misunderstood the OP's intent. I was referring to the KDE owb housing not the bearing itself. Sorry about that.
Old 07-18-2015, 02:15 PM   #12 (permalink)
Thanks didn't know they made a housing, but the bearing itself is working out nicely.
Old 08-08-2015, 08:27 AM   #13 (permalink)
by looks of it on the kde website don't look like they make a housing for the 600? only the bearing. they have one for the 700n though. not sure if that will fit the 600 size or not?
jmerritt is offline        Reply With Quote Quick reply to this message
