Old 04-08-2012, 09:44 PM   #1 (permalink)
Default T-Rex 500 Vibration Help
So converted my HK500CMT/Align mutant hybrid to FBL so I can use the self leveling as a bailout switch for learning. I'm getting some bad vibration at ~200 Hz / 12000 RPM on the Fore/Aft acceleration. I think it's coming from the tail but nothing I'm trying seems to be making a difference. It is a belt drive not a tt. If anyone could at least confirm that I'm looking in the right place that would be helpful. Log file attached.
grimbeaver is offline        Reply With Quote Quick reply to this message
Old 04-09-2012, 01:22 AM   #2 (permalink)
Do you have the SK720 on the tail gear box? if so move it down onto the bottom tray. The vibes from the box are too high on the Align 500
SimStream is offline        Reply With Quote Quick reply to this message
Old 04-09-2012, 03:12 AM   #3 (permalink)
I was told that my tail blades are off balance and my log looks like yours. On the left is your log and on the right is my. But let some vibe guru comment on this to be sure
Align Trex 450 Sport, GP750 gyro, HS-65MG, DS420, CC Ice 50 Lite, Align 325D CF Blades
Align Trex 450 Pro, GP750 gyro, DS410M, DS520, RCE-BL35X 35A, Align 325D CF Blades
Spectrum DX7
Robban is offline        Reply With Quote Quick reply to this message
Old 04-09-2012, 03:45 AM   #4 (permalink)
=] yes you are in the right area, from here the belt looks too tight?
Old 04-09-2012, 07:40 AM   #5 (permalink)
I should have stated that the SK720 is on the bottom tray and using the full vibration mounting kit.
I swapped tail blades from Align plastic to KBDD plastic and it made no difference. I was thinking about loosing the belt as it seems tight but that will require shaving a little off the boom. I think the HK tail might be a bit long or something. I'll get a fresh belt and loosen it up and see if that makes any difference.
Old 04-09-2012, 11:15 AM   #6 (permalink)
=] I should have mentioned to check the belt pulleys also, the vibe does pulse so this can be an eccentric pulley running the belt tight/loose/tight as it rotates,
was in a rush this morning!
Old 04-09-2012, 09:28 PM   #7 (permalink)
LHS didn't have a belt and the other LHS that has it is 30 min from work and an hour from home. But the closer LHS wanted to get rid of their TT upgrade kit so got a good deal on it. Got new plastic grips to replace the questionable HK metal ones too. So all new tail now. We'll see how it does tomorrow if weather permits. Been wickedly windy here lately though.
Old 04-12-2012, 08:14 AM   #8 (permalink)
Well my upgrades have eliminated the vibration problems. The largest vibration is now from the motor and that rarely spikes, probably happens when I switch from normal to idle up.
Old 04-12-2012, 01:37 PM   #9 (permalink)
=] thanks for posting this!
