Go Back   HeliFreak > R/C Helicopter Support > Minicopter Joker/Diabolo Helicopters
Minicopter Joker/Diabolo Helicopters Minicopter Joker/Diabolo Helicopters Discussions
Old 02-11-2012, 06:32 PM   #21 (permalink)
I note you didn't use a shim between the damper and the blade grip - I think you'll find when the damper holders bed down you will get a bit of endfloat and need those shims though it does depend on the precise length of the spindle - we're talking fractions of a mm here. Gerd actually describes preloading the assembly a bit so it feels just a bit notchy unloaded but as soon as it spools up the thrust bearings take the load off the radials.
I had occasion to take a blade grip off yesterday - when changing the spindle I damaged the shim that goes between the radial and thrust bearing. TO my surprise I was able to pull it off and push it back on again without heating - very snug fit though !! Just bake sure you don't bleed threadlock from the x4 grip M3 bolts onto the spacer otherwise you'll have a hell of a job removing it ! Same pricniple with set screws - keep the threadlock away from the end so it doesn't bleed onto the shaft eg on the motor pinion or tail rotor.
John
Old 02-11-2012, 09:40 PM   #22 (permalink)
Yeh i have never had to heat them either
helicraze is offline        Reply With Quote Quick reply to this message
Old 02-12-2012, 02:27 AM   #23 (permalink)
I wasnt sure about using the shims. I felt for the notchyness and it was just notchy without the shims so I decided not to use them. I will take your advise on board and check it again, maybe after 10 flights assuming I dont crash it by then I think I understand the logic behind it now, thanks. On spooling up the centrifugal force pushes the assembly lateraly and pushes on the thrust bearings and squashes the assembly a tiny bit thus giving the endfloat you describe? Hence the need for the shims. Very clever and well thought out.
I noticed that the feathering spindle does not extend fully to the end of the most lateral radial bearings on either side, Is this how it is on yours? I suppose on thinking about it, it allows tension to be applied to the bearing unit.
minicopter DIABOLO LOGO 550sx
scorpion spirit futaba IISI
smsodhi is offline        Reply With Quote Quick reply to this message
Old 02-12-2012, 08:33 AM   #24 (permalink)
how is the lipo placment done? It seems rather unhandy to insert them and them try to put the rubber orings around them. Or are they attached to some kind of tray and inserted in a rail? Can they be inserted from the back so you could leave the canopy on?
DannyvG is offline        Reply With Quote Quick reply to this message
Old 02-12-2012, 10:22 AM   #25 (permalink)
Your backlash seems a bit too much to me. But I do not own a Diabolo.
Logo 800/Jeti DS16
Laurens is offline        Reply With Quote Quick reply to this message
Old 02-12-2012, 10:36 AM   #26 (permalink)
Looks very nice.
The belt tensioner is a shock of a 1/8th truggy lol
The difference between knowing your s**t and knowing you're s**t!
Optipower - Kontronik Drives
jamin_00 is offline        Reply With Quote Quick reply to this message
Old 02-12-2012, 03:37 PM   #27 (permalink)
It's very neat and easy - the o-ring cut outs have a horizontal slot at the bottom where the o-ring can sit flat - the stick pack is then slid in over the battery frame connectors (plastic rods x2) or the individual packs can be inserted over a ruler or just fed in - when in place the oring is just lifted up carrying the pack up - works really well
Smoothing the sharp edges of the cutouts well to minimise oring trauma is worthwhile !
John
Old 02-13-2012, 07:49 AM   #28 (permalink)
Bag 10. Tail rotor. Straightforward build as per the manual. The bearing assembly has some endplay engineered into it. The bladegrips do not need to be heated. I needed to remove a bit of burr on one of them. There are chinese weights on the blade grip holders.
As with the main blade assembly. The wider ID thrustbearing retainer goes in first on the shaft
This concludes bag 10
ID:	289143   Click image for larger version
ID:	289144   Click image for larger version
ID:	289145   Click image for larger version
Old 02-13-2012, 11:34 AM   #29 (permalink)
I just saw the pp-rc.de sticker. Do you have a Pulsar 3 by any chance?
Logo 800/Jeti DS16
Old 02-13-2012, 03:11 PM   #30 (permalink)
Yup and the Pulsar Equal
John
Old 02-14-2012, 12:47 AM   #31 (permalink)
Wow, lucky you. I think I need one too;-)
Logo 800/Jeti DS16
Old 02-14-2012, 02:20 AM   #32 (permalink)
Well Thats it, just have to do the electrical install, which is covered realy well in Johns pics with the build videos, and attach the rudder servo to the tail. Happy days.
Old 02-14-2012, 02:31 AM   #33 (permalink)
Such a smart looking heli Satnam - big thank you for sharing your build - I know what a PIA it is taking pics/vids/posting when you want to just get on and build !!
John
Old 02-14-2012, 06:34 AM   #34 (permalink)
Please double check your assembly: On the picture the thrust bearing sits between the radial bearings. This is not correct: the thrust bearing has to be on the outside.
-Guido
guidom is offline        Reply With Quote Quick reply to this message
Old 02-14-2012, 10:59 AM   #35 (permalink)
Thanks John, it's been a pleasure.
Old 02-14-2012, 12:32 PM   #36 (permalink)
Excellent build thread, gorgeous heli. Thank you!
gravydrive is offline        Reply With Quote Quick reply to this message
Old 02-14-2012, 02:43 PM   #37 (permalink)
-Guido
Thank you Guido,
I double checked and you are correct. I will change it.
Well spotted!!
Thanks again
Thank you gravydrive, glad you enjoyed it.
Old 02-14-2012, 03:31 PM   #38 (permalink)
Actually the original build online manual did have a thrust bearing in the middle - like the rotor head - having the thrust bearing between radial bearings is a common approach these days and gives a bit more rigidity to the rotor grip. Gerd must have changed it when he announced the supply of hex head instead of cross-head bolts for the blade grips - not sure how much difference it makes but I am sure he had a good reason !
Anyway the new order ( and note just the one washer now below the end-bolt) is:
Name:	Original tail rotor.jpg
John
Old 02-14-2012, 04:33 PM   #39 (permalink)
feel better now, as I was using the old manual not the on line one.
Lesson. Use online manual.
Old 02-14-2012, 04:45 PM   #40 (permalink)
I cant remember the order i put the tail bearings in, it was done as per the german manual at the time.
Mine flies sweet as
Surely it would not really matter???
