Old 08-31-2011, 11:45 AM   #101 (permalink)
Ordered mine the other day and getting this radio today. Can't wait to get this set up. From the sounds of all the posts, I will be enjoying this tx for along time.
SK
Align Trex: 450PRO FBL w/3GX, 500PRO FBL w/CGY-750, 600PRO FBL w/CGY-750
Futaba 8FG, Spektrum DX8
MCPx, Nano CPx, MQx
resqjock is offline        Reply With Quote Quick reply to this message
Old 08-31-2011, 10:53 PM   #102 (permalink)
Originally Posted by Mercuriell View Post
Added in video for beginners on how to setup a 120° eCCPM swash on the 8FG
Video - 8FG - Setting up the swash on a new heli - wmv 29MB
Can you shoot another gyro video but using like a spartan, align, telebee, futaba 401 a single gyro just for tail? I never gotten to setup a switch for rate mode and head holding. And I had the radio for long time. Still stuck.
Thanks.
Hi my name is Jim and I am a Heliholic. Darn Heli-Crack Addiction!! lol
The heli virus has infected me and i hope that there is NO CURE!
rcjames is offline        Reply With Quote Quick reply to this message
Old 09-02-2011, 02:43 AM   #103 (permalink)
Thanks.
'NO worries - WIP - bottom line is that there is NO easy way to setup a switch between rate and HH mode AND have different gains depending on condition - I'm playing with progmix at the moment to see if that can help !
John
Old 09-03-2011, 04:24 PM   #104 (permalink)
i have switch a setup as my gain switch. it is pretty confusing figuring it out and the instructions are no help, but once you get it figured out its pretty easy. go to the gyro then change from "cond" to "sw". then go over and assign it to sa(or whatever switch you want)
now with the switch in the position you want to be hh mode, select "gy" and "avcs".
now the tricky part. flip the switch to where you want it for normal mode. change the "#1" to "#2". now change "avcs" to "norm"
that sounds more complex than it is, but if mecuriell can get a video up im sure a picture would be worth a thousand words....lol
i have some helicopters and a box to control them with
satellites es pro tractus!
keep calm and don't panic
guitarherowanab is offline        Reply With Quote Quick reply to this message
Old 09-03-2011, 05:30 PM   #105 (permalink)
THAT's a workaround but there is a MUCH neater solution using a PROGMIX from a switch to the GYRO channel - I'll film up a vid today
John
Old 09-07-2011, 12:54 AM   #106 (permalink)
I'm just getting started with my 8fg super and would really love to see this video since I am struggling with the above problem setting up HH and Rate mode on single switch (using single axis gyro). I think I have it figured out like guitarherowanab stated in his post since it does show it switching in the servo monitor screen, but would like to see your approach as well. Thanks, really appreciate your videos on this new beast!!
Beam E4-(Scorpion HK-2221-6,11T pinion, Phoenix 60, HS65MG cyclics, GY520),120SR, Trex 250SE (stock) MH bottom plate,GY-520,Futaba R6106, MCPx,DX7se,Futaba 8FG Super, HPI Vorza on Futaba 4PL.Honda HS928K1TA
olemil is offline        Reply With Quote Quick reply to this message
Old 09-07-2011, 06:46 AM   #107 (permalink)
Here's the video of single-axis gyro gain setup on the 8FG
Below are a couple of screen shots off the 8FG ProgMix menu to show how a mix from switch SG is ported to the Gyro Gain Channel (5) to flip from -44 to +44 and flip the gyro mode from HH (AVCS) to Rate (Normal)
ID:	251909   Click image for larger version
John
Old 09-07-2011, 09:13 AM   #108 (permalink)
Thank You, your videos are very helpful and much appreciated!!
Old 09-11-2011, 02:29 PM   #109 (permalink)
Default Futaba or DX8?
I just ordered a DX8... now not sure if I should cancel and order the new Futaba.
Thoughts?
badfrog is offline        Reply With Quote Quick reply to this message
Old 09-11-2011, 03:08 PM   #110 (permalink)
Yes
ChrisH is offline        Reply With Quote Quick reply to this message
Old 09-13-2011, 11:27 PM   #111 (permalink)
Thoughts?
From what I have seen so far, the 8FG is WAY more flexible than the DX8, your call.
Old 09-13-2011, 11:38 PM   #112 (permalink)
Team Taco VP
Well in defense of the DX8, I have had one now for 2 months and I am liking it. It is not as nice a radio as the 8FG but it's also not a bad radio now that the bugs have been worked out. Just sayin.... I would go DX8 over DX7 or 6i.
Bob
Old 09-14-2011, 08:52 AM   #113 (permalink)
Got mine today......nice...test run 2x
All begins (Jun 2011).......
Next project:
MSH Mini Protos, 450 Scale Airwolf, BAH Mini Quad
cpmboy is offline        Reply With Quote Quick reply to this message
Old 09-20-2011, 06:00 AM   #114 (permalink)
Hi all 8fg owners out there,
In futaba 6ex, I set my pitch and throttle curve like this:
P/T: 1 2 3 4 5
NP 50 50 50 75 100
IP 0 25 50 75 100
NT 0 25 50 75 100
IT 95 90 80 90 95
....how to set the pi and th curve in the 8FG menu with this values. (in 8FG, it has the curve point and curve rate)......
Next project:
Old 09-20-2011, 07:27 AM   #115 (permalink)
Just adjust the left value. The right value changes the location of the points.
1 - Diabolo 1 stuffed with, well, see below
2 - Diabolo 2 stuffed with testosterone, jittery sweat, and rippling flanks
OverTemp is offline        Reply With Quote Quick reply to this message
Old 09-21-2011, 01:19 AM   #116 (permalink)
got it......
Next project:
Old 09-24-2011, 04:36 AM   #117 (permalink)
Hey guys, sold my Aurora 9 and just ordered 8FG from Century-RC, can't wait to get it, I'll write a post here when it arrives
robi1kenobi is offline        Reply With Quote Quick reply to this message
Old 09-26-2011, 07:04 AM   #118 (permalink)
hi again.....
just finish ccpm setup on my 450 pro wt the T8FG......so....a fren of mine was suggesting that another way to level the swash other by EPA is by using the swash mix menu in the T8FG(...not the AFR he says....)....how can this be achieved??......
Next project:
Old 10-01-2011, 11:55 AM   #119 (permalink)
Default Advanced swash settings
It would be nice to have a video on advanced swash functions. There is a lot that can be done with this radio, but the manual is not to thorough. A video following the steps on the 14z help page would be neat.
trevstaff is offline        Reply With Quote Quick reply to this message
Old 10-02-2011, 06:17 PM   #120 (permalink)
THere certainly are plenty of swash options - 6 pages of them ! However most of these are swash mixes and redundant when used with a FBL system that takes care of these in a better manner (mixes in rudder and gov too sometimes) I'll have a think about what could usefully be done and see about a vid
John
