Old 03-26-2010, 09:27 AM   #1 (permalink)
Default New CPll owner ;)
Hi guys,
I'm new to helis and after doing some reading here I decided that the CPll was going to be of great help to shorten my - long - learning curve. I'm a good hovering "pilot" but as soon as I try something different I head for disaster...
Thing is that I drove 45 minutes to FMA in Frederick MD; got my kit, and what's more important I got to talk with Howard Matos and the other guys. A really helpful and friendly bunch. Howard gave me a briefing on how to setup the computer and it really is more simple than I thought.
Back at home I installed the hardware on my Furion 450 which is now a big ball of wires with blades. As soon as I can test and see that all is good I'll tidy up the wiring as good as I can.
I have one question for now: I connected the gyro servo on channel 4 (RCV4) . Is this necessary? After the setup I passed my hand close to the main sensor and the swash started doing all kinds of things so I believe the connections are good. I set on/off on the Aux 2 switch.
Thanks for all the info here that made everything easy to install. As soon as I have the opportunity to test (rain rain here...) I'm sure I'll come back with more que4stions
Bests
tribe3 is offline        Reply With Quote Quick reply to this message
Old 03-26-2010, 09:49 AM   #2 (permalink)
Installing the gyro in RCV4 is if you do not have any extra channels on your Rx , this will allow you to use the On / Off function
If the main sensor is reactive to you passing your hand by it, it working
JR9303 / JR9503 / Futaba10CHP
nightflyr is online now        Reply With Quote Quick reply to this message
Old 03-26-2010, 11:31 AM   #3 (permalink)
Nightflyr, I have the gyro Gain wire into the rx gear channel and I plugged the rudder/gyro servo into RCV4... Does it hurt this way or do I just put it back into the receiver's Rudder channel?
I have a 7 channel RX (AR7600) so I guess I have enough channels.
One more question: In your experience are the default trimmings good to go on a normal/mild day? Or does it take some tweaking to get the heli to hover decently with CPll ON?
Old 03-26-2010, 11:56 AM   #4 (permalink)
Sorry no cupie doll, you need in put the gain lead from the gyro into the RCV4 port of the CPII Avionic computer and the tail servo into the Rx, in doing a quick setup the programmer will ask if you have the gyro plugged into RVC4, then ask for a gain value in % ...start with 28 and add or subtract as you need.
One more question: In your experience are the default trimmings good to go on a normal/mild day? Or does it take some tweaking to get the heli to hover decently with CPll ON?.
The default settings work well,
The only trick to get a good hover is to pop the bird up and see if it drifts.
If it does you can do one of two things...
1) tweak the main sensor (tilt it) to correct for the drift.
2) set flight angles to correct for the drift.
Basically both the same, I just tweak the sensor myself..its faster for me
Old 03-26-2010, 04:53 PM   #5 (permalink)
Ok now; I did my first flight (2 batteries) and I'm VERY pleased!!!
It was in a confined place in my backyard; just had stopped raining so it's overcast and the grass very wet. I couldn't do very much but enough to feel how it recovers when you let go the cyclic. It flies almost as easy as my blade msr I'm amazed of how relatively easy it is to install and setup!!
About drifting: It drifts to the rear and to the left. I fixed the left drift by tweaking the main sensor like you suggested and a little bit of trim on the TX . Now about the backwards drift... just trim the TX or go into the IRNet programmer?
Thank you Nightflyr for your support!!
Old 03-26-2010, 04:56 PM   #6 (permalink)
You can set flight angles or if it is rearing back at you, it means either it is see some heat source or the main sensor it leaning forward , you can try to get it to lean back and that may stop the backwards drift.
