Old 04-20-2011, 07:54 PM   #1 (permalink)
Default My charger/battery storage box.....
I've read several posts in the past few months about charging stations and battery storage so I decided it would be a good idea to make one, especially since I mentioned to my wife that lipo batteries can start fires and she got all freaked out that the house was going to burn down even though I assured her that I never charge the batteries unattended. Still it's better to be safe than sorry.
So here's what I came up with using some ideas from a couple other posts. I started with 2 HP server power supplies and set them up in series for 25.31 volts (thanks to Chris, aka TJINGuy). I then mounted them in the bottom of a steel tool box from Lowe's. Since the Hyperion EOS0615 Duo 3+ didn't fit in the tray that came with the tool box, I removed it and made another out of a piece of aluminum plate I removed from a server cabinet. (it's always a good idea to keep an eye on the dumpster at work. You'd be surprised what they throw out).
Now I can store the batteries in the bottom of the box and when it's time to charge I can just plug everything in and charge 2 batteries at a time on the tray.
ID:	223151   Click image for larger version
ID:	223152   Click image for larger version
ID:	223153   Click image for larger version
Nano S2, DX9, AMA33083, FA37NM3433
"Growing up leads to growing old and then to dying, and dying to me don't sound like all that much fun"
Hekicopter is offline        Reply With Quote Quick reply to this message
Old 04-21-2011, 12:54 AM   #2 (permalink)
I like the simple, basic, functional setup. Very nicely done and I don't say that very often.
- Chris
TJinTech heli...info...news...such
Helis: TRex 450 Pro - Protos - TRex 550e
Stuff: Spektrum DX7 - iCharger 208B - Hyperion G3
TJinGuy is offline        Reply With Quote Quick reply to this message
Old 04-21-2011, 01:06 PM   #3 (permalink)
Very nice. I'd like to do something like this myself.
Futaba 8FG AMA # 961861
Tyrannosaurus': 450 Sport : 500 ESP : 700E
MMM.PWR is offline        Reply With Quote Quick reply to this message
Old 04-23-2011, 09:13 AM   #4 (permalink)
thats a nice setup, rich. did the p/s come with those jacks on them? id love to do something like that, but my soldering skills are not very good.
thanks for all the input guys. good stuff!
rob
i have some helicopters and a box to control them with
satellites es pro tractus!
keep calm and don't panic
guitarherowanab is offline        Reply With Quote Quick reply to this message
Old 04-23-2011, 09:27 AM   #5 (permalink)
Thanks Rob,
I added those plugs to the supplies. Where you see the red tape covering the openings is where the "hot Swap" boards were. I removed them and added the plugs for the outputs.
Old 04-29-2011, 08:26 PM   #6 (permalink)
Well done Rich, I admire a good looking job/project.. I especially like the way its fire proof. I worry more than I should about burning down my place.. I get side tracked easily and sometime forget that Ive got batteries cooking... Hope you wont mind if I use your ideas towards my own build.
Cheers & Regards,
Rick
CyberPlainsDrifter is offline        Reply With Quote Quick reply to this message
Old 04-30-2011, 05:32 PM   #7 (permalink)
Cheers & Regards,
Rick
I don't mind at all. They say copying is the sincerest form of flattery..
Old 08-05-2011, 02:14 AM   #8 (permalink)
Do you guys have workshops or something to cut this stuff?
I've seen many cases with custom cut aluminum, plexiglass or wood. You need a lathe for that crap or what?
I'm really not that handy when it comes to physical construction.
What can the poor computer nerd do that has no building skills?
I need a charger case BAD.
clank72 is offline        Reply With Quote Quick reply to this message
Old 08-06-2011, 07:27 PM   #9 (permalink)
Well , Im sure some of us have tools that aid in the construction of such devices.
I personally have a CNC router table at my disposal so cutting plex, wood, aluminum and various other materials is as simple as drawing something in a cad program or even illustrator....
Maybe if you talked nice to someone here, they might even help you out...
What do you figure you need?
Old 08-07-2011, 12:49 AM   #10 (permalink)
Clank, there's a pilot (snjbird) that will build you a case. It's not going to be cheap but he'll build it to your requested (or his suggested) specifications. I've seen several that he's done for others and they are nice.
Old 01-01-2012, 08:30 PM   #11 (permalink)
Big thanks to pctomlin I basically would have not done this build without his posts, I would also like to thank DoctorJ, on his use of the lowes toolbox and top. I can say this was a pretty indepth project from getting everything I needed to finish. I did a couple things that I have not seen done... 1. I found the connectors that would be used on the back plane of the server and soldered to those instead straight to the heatsinks. I did this incase one dies I didn't want to have to solder again just take out some screws put a new one in and you are ready. 2. I didn't open the one end of the box completely up I cut 6 holes 4 of which are for the fans and 2 for the plugs. I found some 60mm covers that fit perfect minus a little plastic trimming around the 2 sides that butt to the outlets. I am going to put switches in but I did something that I think is cool for that and just don't have them yet... I will update once those are in. I am also going to do something with the plexi top just don't have that all worked out, a guy in our club has a laser cutter/ingraver all you gaui fans look out for what I do there . Over all I am very happy I have 2 sets of 24v and 2 sets of 12v outlets for my 306b & tp610c, along with anyone that is looking to give their charger some power at the field or indoor. I did go with some high end banana jacks from DigiKey rated at 30A I couldn't find anything that was near a solid as these locally and we have a Frys in town along with high end audio most of them just said they are standard and after getting these I am glad I did. here is a link to them http://search.digikey.com/scripts/Dk...ds=501-1316-ND I used 8AWG on all 24v connections along with the mains on the 12v till I split then I used 10AWG. Bought the wire from HobbyKing and EPbuddy... I would recommend using EPBuddy when you figure the final cost its so cheap and you get it within 3 days really great service by them look for their balance boards too very solid designs! While I enjoyed the build I am really happy its over cutting that tool box was some detail cutting, at times I questioned why I didn't just cut two big holes!
________________
Naked & Afraid
whippo is offline        Reply With Quote Quick reply to this message
Old 01-05-2012, 06:32 PM   #12 (permalink)
Just $11.00 my Charger Station
KS
ID:	278395   Click image for larger version
ID:	278396   Click image for larger version
ID:	278397   Click image for larger version
ID:	278398   Click image for larger version
ID:	278400   Click image for larger version
ID:	278401   Click image for larger version
ID:	278406   Click image for larger version
Some Day I'll be Back
kdsalas is offline        Reply With Quote Quick reply to this message
Old 03-07-2012, 11:37 AM   #13 (permalink)
I don't have a charging case, but I did make myself a 24V power supply last week. Maybe I'll put it in a case later.
mistercrash is offline        Reply With Quote Quick reply to this message
