Go Back   HeliFreak > R/C Airplanes Info and Support > Airplane Related
Airplane Related R/C Airplanes Discussion
Old 09-26-2006, 07:55 PM   #1 (permalink)
Default Unwanted Mixing
I flew my Tribute today, after hovering several flight and flying, on my last flight I noticed when advancing throttle my ailerons-elevator moves when advancing throttle. Just thinking what to check first. :?
Crystal issue
Radio-JR 6102
ESC-CC 25
Rx
Icenum is offline        Reply With Quote Quick reply to this message
Old 09-26-2006, 08:03 PM   #2 (permalink)
Check the servo monitor first to see if the interaction is coming from the TX or RX.
Most likely it is from the TX, you need to go thru all of the P-Mix's to find the culprit.
It could be a built in mix that is active but should not be.
Make sure it is not some mechanical interference in the airframe or a loose servo tray or something along that lines.
There is no easy way to find these things.
Jeff Borowski
flyinfool is offline        Reply With Quote Quick reply to this message
Old 09-30-2006, 08:39 PM   #3 (permalink)
Turned out to be Rx going bad, only acted up when temp. dropped. Tried another Rx problems solved.
Old 10-01-2006, 04:28 PM   #4 (permalink)
That's a new one.
I learn somthing new every day.
Glad you found it.
Jeff Borowski
Old 10-03-2006, 07:01 PM   #5 (permalink)
Me too, once I had one year back, hard rudder deflection with throttle. I replaced ESC, but it turned out to be a defective servo pot. Servo worked normally mechanical wise.
