JLog - The JIVE logging stamp JLog - The JIVE logging stamp - Official English Support Forum |
12-28-2016, 08:27 PM | #1 (permalink) | ||
JLog how to video
Hi all,
I decided to make a video geared toward the J-Log noob like myself. My particular setup is with Hobbywing and Jeti but the steps are the same for other setups. Hopefully this helps someone out! Also check in the description for links to the firmware and JLC app.
- J |
12-30-2016, 12:50 PM | #3 (permalink) |
does this apply to Rē S32 "JLog 3" , got one coming my way
| Kraken 700 : Neo | Atom 6HV : Evo | Raw 580 : Neo | vbct | |
12-30-2016, 04:03 PM | #4 (permalink) |
Unfortunately I have no experience with the J-Log 3
- J |
01-06-2017, 01:18 PM | #5 (permalink) |
Thanks for the video, you save me a TON of time, searching and messing thing up LOL...
one question i see you have a MUI sensor, supposedly the HW V4, send the mAh consumption right? how do i set it up on the radio I just purchase same Jeti as you!! Do i Need to purchase any extra software for the jeti to have the telemetry?Best Regards.
Diabolo 550 / Diabolo 700BE /Triabolo 700 / Srimok 90N Goblin-700/700C/KSE/BlackNitro/380/Logo700/Trex600NSP Jeti DS-14 Edition |
01-06-2017, 01:46 PM | #6 (permalink) |
You are most welcome Grittner, glad it helped!
So you are correct, v4 does supply mAh consumption. HW v3 does not.. actually the v4 has a lot of good telemetry info! Much more than v3. Once you program the JLog to work with the HW and Jeti, the only thing you need is a Jeti Rx with an ext port and you are in business. No extra hardware or software required! You will see the new telemetry available in your TX . Just go to your "displayed telemetry" option and click on add. Then you will see the available telemetry, pick the ones you want to be displayed. You can also set alarms such as capacity, low voltage, etc. It's slick, Im so happy I switched to Jeti Have a good one!
- J |
