Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Warp 360
Warp 360 Compass Warp 360 Model Helicopter Discussion
Old 09-12-2013, 05:39 PM   #1 (permalink)
Default Is this Futaba Sbus the ticket for the warpy.....
http://www.experiencerc.com/store/fu...66-p-8905.html
Sent from my Compass7HV while in an inverted tail-in hurricane.
you should look into it...........
crf69 is offline        Reply With Quote Quick reply to this message
Old 09-12-2013, 07:27 PM   #2 (permalink)
It's a 3ch+s-bus Rx.
If you use a FBL unit that support s-bus, yes, you can use that Rx.
You can also use a full Rx + sbus like:
http://www.hobbyking.com/hobbyking/s..._Receiver.html
http://www.hobbyking.com/hobbyking/s...ompatible.html
pinguin is offline        Reply With Quote Quick reply to this message
Old 09-12-2013, 07:31 PM   #3 (permalink)
Default Re: Is this Futaba Sbus the ticket for the warpy.....
the one i posted says for indoor use.
thats why i was wondering.......
the warp is certainly gonna be going out farther away from me than most indoor places.
maybe i should just get the r6202sb and be done with it.
Old 09-13-2013, 01:07 AM   #4 (permalink)
If you are in doubt, better get a full Rx. From the manual, it says: for parkflight or indoor use airplane and small size electric helicopter up to 1000mm of main rotor diameter.
I use R6106HF on my 450 and never have problem. Also says for park flyer or indoor. I think the maximum distance is the same with R6004FF, 300ft (91.4m).
Old 09-13-2013, 01:13 AM   #5 (permalink)
if there is a chance it loses connection then i will just get 6202sbw
Old 09-13-2013, 08:28 AM   #6 (permalink)
Don't get the E version, get the W or just SB version. E version has only 1 antenna and for park flying. W or SB version come with diversity antenna (2) which give you longer range.
Nano CPx, Hirobo Quark
250 SE, Pro Upper Frame, Talon25, KDE, KST215, DS95i, Mini Vbar
450 Pro (6s), KDE, Lynx, Tarot, RJX, YEP40, KST215 & 515, SK540
465 (6s), Align DFC, HW50AV3, KST315 & 8910A+, SK720BE
lcc014 is offline        Reply With Quote Quick reply to this message
Old 09-13-2013, 08:31 AM   #7 (permalink)
Get the 202sb, their cheaper too. A lot of people do use the 203sb, that use to be the only one. But like I said 6202 is newer and the cheapest of the small sbus rxs, I think.
Lincoln
#HIGHONHELIS ):>
Pull Hard
RCHO Flying Field, Knightdale NC
lazor 22 is offline        Reply With Quote Quick reply to this message
Old 09-13-2013, 02:56 PM   #8 (permalink)
awesome thanks LE.
6303 it is..........
also got swash tool
pretty stoked!!
Old 09-21-2013, 03:04 AM   #9 (permalink)
I use this on my Trex 500 and fly it into orbit with no glitches,just put one on my new warp also.Its so small you can put it anywhere!
http://www.hobbyking.com/hobbyking/s...dProduct=27176
Synergy E7,V bar,Phoenix ice 160hv,Gryphon bec
Trex 500,mini V bar,Phoenix ice 75,cc bec
Compass 6HV Ultimate,V bar,yep 120hv
Compass warp 360,Mini V bar,yep 45,
25teapot is offline        Reply With Quote Quick reply to this message
Old 09-21-2013, 03:40 AM   #10 (permalink)
I use the standard 6203SB on both my TRex500ESP and my BEAM 600 Avantgarde
with my full-size VBar's. I wouldn't dare use anything less. Always two antennas!
I have taped the antennas to the landing skids, so they're sort-of 90 deg. to each other.
And the signal is not blanked by anything.
Since I use the S-Bus, why would I buy a Rx with more channels? I don't plan on reusing
the Rx in a plane - I plan on having at least two helis as long as my body will let me.
Cheers
Erik
PS: I use Futaba Rx and good name brand servos on everything. I want to have a reputable
company behind the product. I buy batteries only from China, as I can't afford anything else.
Beam600, 6203SB, 4025-630, ICE2HV80, Black VBar, Ino-Lab750, Savöx 1290MG
Goblin 500, Quantum motor, BK mini servos, HobbyWing 100A v3, Fut. 6203SB, Vortex Vx1e.
oy2503 is offline        Reply With Quote Quick reply to this message
Old 09-21-2013, 05:30 PM   #11 (permalink)
I use this in my 250 Pro, smaller than Futaba 6203 and light too
Old 09-22-2013, 12:25 AM   #12 (permalink)
You guys made my day.
I was looking for a smaller s-bus receiver for both my 250´s and Warp´s. and my other helis for that matter
AlvaSpeed is offline        Reply With Quote Quick reply to this message
Old 09-24-2013, 08:17 PM   #13 (permalink)
Formerly BarnStormer
6303 for sure
Scorpion Power Systems
Jason O'Connell is offline        Reply With Quote Quick reply to this message
Old 09-24-2013, 10:45 PM   #14 (permalink)
Just looked at prices of the rx's and looks like they went up on the 6202, from $45 to $80. WOW! Can't believe that. I guess the 6303 is the cheapest now at $75.
Lincoln
#HIGHONHELIS ):>
Pull Hard
Old 09-24-2013, 10:52 PM   #15 (permalink)
6303's on all my machines.
Sent using Tapatalk 2
Danny Dugger is offline        Reply With Quote Quick reply to this message
Old 09-25-2013, 01:05 AM   #16 (permalink)
Serious question, a bit OT: is "ticket" the definition for something cheap? Or better, what on computers would be called "entry level"?
And, what exactly is "the best bang for the buck"? Something which has a good quality/price ratio?
You guys are impossible! I thought I had a good english knowledge but sometimes I don't understand anything
Oxy 2X-VertWarp 360Blade 450XBlade 450X NightflyerGoblin 500 ♦ 2 X mCPX v2 ♦ night fly mQXLadyMQXnano QXnano QX FPVInductrixDX8 G1
Coco66 is offline        Reply With Quote Quick reply to this message
Old 09-25-2013, 04:46 AM   #17 (permalink)
what i meant was which futaba rx is the hot ticket as in best suited for......
r6303 is what i went with.,.....
Old 09-25-2013, 11:03 AM   #18 (permalink)
Coco:
The ticket is "the thing to use or the thing to go with" for whatever reason, with no specific qualifiers for why.
You nailed bang for the buck.
Sent from my SCH-I535 using Tapatalk 4
NX4|Tri-Chronos|Chronos|7NT|Specter700
Saje Marvin - Citizen 125
Raz0rSh4rp is offline        Reply With Quote Quick reply to this message
Old 09-25-2013, 08:04 PM   #19 (permalink)
Member
Originally Posted by Jason O'Connell View Post
6303 for sure
ProStar has this receiver $10 cheaper than Tower......couldn't pass up the deal and opportunity to have both my helis running on the 14SG.
Old 09-29-2013, 01:44 PM   #20 (permalink)
Member
