Old 10-01-2013, 10:49 AM   #41 (permalink)
Well, the fuse proved useful in my last crash this weekend. Connector still melted so something shorted. The Kosmik is practically destroyed so no way of testing if it burnt or the fuse helped it survive the short. It didn't survive the beating though... Motor ended 30 feet away from the heli.
Marcos
Banshee #27, 2x TDR, Diabolo, Logo 690SX, Raptor E700, JR Sylphide E12 EX Super Gracy, Voodoo 600, Voodoo 400, Logo 550SE, Logo 400SE, JR Forza 450. Mikado Vcontrol.
marcosp is offline        Reply With Quote Quick reply to this message
Old 10-01-2013, 11:21 AM   #42 (permalink)
Default Re: Kosmik Fuse's
Ouch, must have been a nasty crash.
Primal is offline        Reply With Quote Quick reply to this message
Old 10-01-2013, 11:58 AM   #43 (permalink)
the concern about soldering heavy lugs
Solder, where is solder? You mean the lugs are soldered to the PCB?
No Sir, bolted, and btw no contact grease to displace the oxygen.
It's worse, colleague.
Some more crappy details.. spacers made ​​of too soft thermoplastic (Greetings from the hardware store), too short threads (rattling in KOSMIK), only thermal compound between DirectFETs and aluminum plate (unsafe insulation). ...senseless second aluminum plate, because the center part is made of plastic...
Marcos, I'm very sorry for your heli.
Let me guess: Speed flight and full speed into the ground.
It cannot. That's not the job of the fuse.
Tom (j-log.eu)
dl7uae is offline        Reply With Quote Quick reply to this message
Old 10-01-2013, 01:33 PM   #44 (permalink)
Yup, Banshee speed flight without remembering to change ratio in Jlog after changing pinion, so what I read as 2300 was 2560......... original thrust bearing gone kabooom!
https://www.helifreak.com/showthread...64#post5337564
Steep and harsh learning curve!!!
Marcos
Old 10-01-2013, 01:34 PM   #45 (permalink)
BTW, the HV2BEC lost a.... pot? capacitor? One of the two big grey "cans" at the back. Have a friend knowledgeable in electronics who will try to solder it back, otherwise I might send it your way.
Marcos
Old 10-01-2013, 03:00 PM   #46 (permalink)
Post a photo, Linus will tell you what that is.
Tom (j-log.eu)
Old 10-01-2013, 04:48 PM   #47 (permalink)
Hi
if the only HVČ damage are the alu cans on the back, if can be repaired. You need hot air to solder it, but any electronic geek should be able to help you . I can send you two caps to get those replaced. The monitor can be repared as well, just send it over to me.
The Kosmik fuse is there, to safe you and your battery and everything else in case of a catastrophic failure inside of the Kosmik. This happened in your case. Without fuse your heli could have easily caught on fire!
Sorry for your loss!
Linus
linus is offline        Reply With Quote Quick reply to this message
Old 10-01-2013, 05:01 PM   #48 (permalink)
Hi
all who sent me PM, I will reply tomorrow or thursday since I am very busy right now...
I will let you know as soon as the fuse holders are back in stock!
Linus
Old 10-01-2013, 06:02 PM   #49 (permalink)
Originally Posted by linus View Post
Hi
Linus
Thanks. I have the broken cap, only that the two connectors are cut at the base. I'll see if I can get one here, otherwise I'll contact you.
The monitor seems to only be unglued. The connecting strip seems to be intact. I'll now as soon as I can power the BEC again. The power cables were damaged too so they need to be changed as well.
Marcos
Old 10-01-2013, 10:50 PM   #50 (permalink)
Hi
those are organic polymer capacitors, no standard parts at all.
Linus
Old 10-01-2013, 11:28 PM   #51 (permalink)
Did the fuse even blow? It would be worthy to check and see if it did...
Blade 130X- My cul-del-sac flyer.
Blade 450X w/MSH Brain - My Ferrari
T-Rex 600 EFL Pro w/SK-720 BE, KDE600XF & SK-GPS - My BMW
T-Rex 700 HV DFC w/VBar, Kosmik 200 & KDE700XF - My muscle heli
HFMan is offline        Reply With Quote Quick reply to this message
Old 10-02-2013, 11:05 AM   #52 (permalink)
It is very beaten and the first thing I looked was to see if it blew or just broke. I'd say it blew and then broke. The Kosmik negative connector is melted but in the caos of the crash it's impossible to know what hit what and in what sequence.
Marcos
Old 10-03-2013, 01:46 AM   #53 (permalink)
Mine has arrived!! Linus, great quality, will post pics once installed. Thanks again!!
William Blake Team Kontronik
TDR1, Banshee 850 # 22
Diabolo 700
wblombard is offline        Reply With Quote Quick reply to this message
Old 10-03-2013, 02:23 AM   #54 (permalink)
Mine showed up as well. Looks fantastic. Pics up once installed
Old 10-03-2013, 07:35 PM   #55 (permalink)
I will grab a few of these when they are available, haven't used the fuse on any of my birds, as I saw it as a liability rather than protection, this makes it viable.
[B]TT E820 - Kosmik 200, Scorp 5035 TT G4.1(x2) - OS 91 3D Speed, Hatori
MSH Brains + JETI DS-16
rossk is offline        Reply With Quote Quick reply to this message
Old 10-03-2013, 08:57 PM   #56 (permalink)
I installed mine today .
Sent from my SPH-L720 using Tapatalk 2
Magneto is offline        Reply With Quote Quick reply to this message
Old 10-05-2013, 02:07 AM   #57 (permalink)
Hey Joe, your fuse is wearing a bikini...
minicopter DIABOLO LOGO 550sx
scorpion spirit futaba IISI
smsodhi is offline        Reply With Quote Quick reply to this message
Old 10-05-2013, 11:03 AM   #58 (permalink)
Satnam you crack me up! What a set of bolts on her! lol
Old 10-05-2013, 10:45 PM   #59 (permalink)
[QUOTE=dl7uae;5337370]Solder, where is solder? You mean the lugs are soldered to the PCB?
No Sir, bolted, and btw no contact "
Ok thats a relief was under impression soldered to pcb, maybe time to open one up to see whats cooking inside
Tdr quantum 4530 1.4 yy h/ jive120 beastx, Vibe e 8 12s mx 700 1.32yy vbargov fusionhawk, Banshee nr 36 kosmik 200 pyro 800 1.4yy 455kv 14s beastx, xtreme 700 pyro 850 1.5yy 14s kosmik 200
Stolla is offline        Reply With Quote Quick reply to this message
Old 10-16-2013, 08:23 AM   #60 (permalink)
My fuse finally arrived from Europe via rowboat, thank you Linus.
Very nice piece of kit, but the manner in which I had to mount it means you don't really see the board.
thefrog is offline        Reply With Quote Quick reply to this message
