Go Back   HeliFreak > R/C Electronics Support > JLog - The JIVE logging stamp
JLog - The JIVE logging stamp JLog - The JIVE logging stamp - Official English Support Forum
Old 06-01-2014, 04:47 PM   #1 (permalink)
Default Disabling telemetry/enabling logging 2.6 GW
What is the process for disabling telemetry and enabling logging for a 2.6 GW? Just wondering if I have to do something at the time of purchase or can it be done when I receive it.
Brad G
> Logo 550SX
> Goblin 500
> mCPx BL
> JR XG8
bradg is offline        Reply With Quote Quick reply to this message
Old 06-02-2014, 09:04 AM   #2 (permalink)
Hi Brad!
You need an enabler for that: http://j-log.eu/jlog-in-funktion/jlog2-6gw-enabling
Tom (j-log.eu)
dl7uae is offline        Reply With Quote Quick reply to this message
Old 06-02-2014, 09:57 AM   #3 (permalink)
Thanks, I saw that before. I just don't know how to get a key.
Brad G
> Logo 550SX
> Goblin 500
> mCPx BL
> JR XG8
Old 06-02-2014, 11:18 AM   #4 (permalink)
Ask Danny please. http://www.demonaero.com
Tom (j-log.eu)
Old 06-02-2014, 01:06 PM   #5 (permalink)
Thanks again.
Brad G
> Logo 550SX
> Goblin 500
> mCPx BL
> JR XG8
Old 06-05-2014, 07:10 AM   #6 (permalink)
Give me the ID of your device please: http://j-log.eu/jlog-in-funktion/jlog2-6gw-enabling
Tom (j-log.eu)
Old 06-05-2014, 08:36 AM   #7 (permalink)
I just ordered a 2.6 GW from Danny yesterday. It should be here in a couple days.
Brad G
> Logo 550SX
> Goblin 500
> mCPx BL
> JR XG8
Old 06-09-2014, 11:13 AM   #8 (permalink)
26-J_E-111.22
ID 27-59-F4-66 G
The config:
9600,0,128,8,0,8,57,14,120,0,1,0,0,0,0,0,0,1,0,0,0 ,0,0,0,0,0,9,0,0,6,16,16,16,16,16,16,16,16,16,16,1 6,16,16,16,16,16,132,111,0,0,39,43,15,20,1
Let me know when the LO key is available. Thanks
Brad G
> Logo 550SX
> Goblin 500
> mCPx BL
> JR XG8
Old 06-09-2014, 12:24 PM   #9 (permalink)
Enabler key file in your PM box. (Remove the extension .pdf, it's just there to kid the forum software.)
A gift from R˛prototyping.
"LO" means "Log Only", no telemetry, that is right?
Oops.. no attachments in PM..
Attached it here.
Usage: http://j-log.eu/jlog-in-funktion/jlog2-6gw-enabling
Tom (j-log.eu)
Old 06-09-2014, 01:17 PM   #10 (permalink)
Thanks much. I'll try it tomorrow.
Brad G
> Logo 550SX
> Goblin 500
> mCPx BL
> JR XG8
Old 06-10-2014, 05:09 AM   #11 (permalink)
Don't reply yet, I found something to try :
https://www.helifreak.com/showthread...hlight=logview
I have the jlog making a file and a folder on the SD card:
Folder named d000-510
File named log00003
At the download page:http://j-log.eu/download-jlog2-5/
I get as far as LogView loaded and running but it won't open files from the SD card.
I don't know what to do at the:
Einen Device Description File .ini kopiert man auf %appdata%\logview\geraete\openformat. Wichtig ist, dass LV unter demselben Windows® Account betrieben wird, unter dem es installiert wurde! – Ein File .lov ist ein Export aus LV. Indem man einen file.lov öffnet mit LV, lernt LV das betreffende Device und macht es gleich zum aktiven. Einen .lov zu öffnen, ist einfacher, als der Umgang mit einer .ini Datei. LOV ist die Alternative zu INI!
Brad G
> Logo 550SX
> Goblin 500
> mCPx BL
> JR XG8
Old 06-10-2014, 06:12 AM   #12 (permalink)
Brad,
LV needs to know how to interpret a log record. It needs a device description.
The built-in "SM JLog2" is sufficient for your purpose.
Then: A log file is not opened than imported by LV.
Afterwards you can save everything, - 1 to many log sessions (imported logs), your setup (device type, colors, ranges etc.pp) into one file, - export so to speak, .lov. Everyone who simply have LV and nothing more can open (yes, now open) your file.lov and will see everything as you have seen and setup the view.
Details (online manual) here.
Tom (j-log.eu)
Old 06-10-2014, 07:34 AM   #13 (permalink)
Thanks. Flying now but will work on it later.
Brad G
> Logo 550SX
> Goblin 500
> mCPx BL
> JR XG8
Old 06-11-2014, 06:28 AM   #14 (permalink)
Works now, thanks. I will be making some logs in a day or so.
Brad G
> Logo 550SX
> Goblin 500
> mCPx BL
> JR XG8
Old 09-06-2014, 02:08 PM   #15 (permalink)
Default JLC blues
Just got a Jlog from Heli-Direct.
Downloaded the JLC, can't seem to get it out of German.
My PC does see the SD card but it is blank.
Where do I find the device ID? I need that to get the key, correct?
I have never put this in the model. I only intend it to replace my Eagletree for logging motor, battery and rotor speeds; so I figured I would just get it to log from the start.
Does it need to be powered up with the SD card in before the card can be read on the PC?
oldeflyer is offline        Reply With Quote Quick reply to this message
Old 09-06-2014, 03:24 PM   #16 (permalink)
Yes. JLog writes "version.txt" on the SD.
In the 2nd line of that file is the device ID to be found, and the enabling status.
(JLC only shows the enabling status if JLog at least one time ran w/ the SD and modified CONFIG.txt.)
Only logging, no telemetry?
So you need the cheap enabler "gw2lo". (gateway to log only)
Tom (j-log.eu)
Old 09-06-2014, 06:24 PM   #17 (permalink)
Thanks, Tom
I will put the card in the 'stamp' and power it up.
Yes, I would need the 'cheap' log enabler..
Does someone in the states sell that? I could not find it on the Heli-Direct site.
Old 09-06-2014, 07:45 PM   #18 (permalink)
Solid red LED on after blinking green and yell.
version.txt file has:
26-hwTEST-254.32
ID 19-D8-EC-F4 G
Is this correct?
Old 09-07-2014, 05:29 AM   #19 (permalink)
Start
You need to flash the desired firmware at 1st.
Online manual (still German only).
Everything you need is always here.
26-hwTEST-254.32
ID 19-D8-EC-F4 G
Is this correct?
26-hwTEST-254.32 is the hardware testing firmware in production.
Tom (j-log.eu)
Old 09-07-2014, 06:10 PM   #20 (permalink)
Sorry, a little slow
I went to the links provided. Must have missed the part about needing to flash the ROM for it to go the first time.
I have no telemetry to connect. I probably never will. I am just trying to get a log out of my Jive.
Which telemetry should I select? Or does it not matter since I am not going to use any?
I would hate to throw the wrong one in there and use a lot of cycles to get nothing.
