10-15-2011, 11:04 PM | #1 (permalink) |
New Set Up Need Some Help
Hello all.
I just got a new set up and need some help. I coming from a Trex 450 and a Airtronics RDS8000. I got a 500E Pro Flybar and a 8FG Super and have a few questions. 1st How do I set up the gyro for rate / head hold. I go to the gyro screen and it is set up for 3 axis. How do I change it to use with a GP900? What switch is assigned? 2nd on the main blade holders there is a sea saw arm. During set up at center stick with the swash level, all arms parallel what position do these need to be? Or does it matter as long as everything else is set up and blades are zero. Sorry for all the questions but just everything is new again like starting over. I guess I should have got a new radio then a new heli but no I had to have both. Any help would be appreciated. I tried looking online but not much out there yet for The 500E Pro Set up. Thanks again. |
10-16-2011, 12:09 AM | #2 (permalink) |
The switching on the 8FG is fully assignable, and you have 3gyro menus to allow for the all three axis on the Futaba FBL unit.
Make sure you are in GY mode , on the first of the gyro settings, if the number is positive it's HH mode, negative it's Rate mode. Assign to any switch you like or if you select switch to COND then you switch tail gain according to flight mode.
Dave Goblin 500, Vbar, BLS153, BLS251, Kontronic Jive & Piro MutliWiiCopter Scarab Stealth Armour,Scarab Stealth Reconn V3, Scarab TriiKopta, Scarab Octa, Scarab Vampire |
