Flybarless Helicopter Systems CSM Cyclock, Helitronix Multi-mixer, Spartan AP2000i, Firmtronix Digimix-3, Gyrobot, SK360and AC3X |
03-08-2014, 02:11 PM | #1 (permalink) |
Zyx will not connect to computer
I've been trying for hours to set this thing up now with no luck. I can't get it to connect to the computer or into programming mode using my dx6i. Ive gotten it to connect using my receiver and it initializes to a solid red light but other then that I get nothing.
Sent from my SM-N900V using Tapatalk |
03-08-2014, 02:34 PM | #2 (permalink) |
Should the zyx respond in anyway when I plug it in to the computer before I press connect on the software? Also I've tried installing and reinstalling the usb driver multiple different times and ways and it Is recognized by my computer and when I hit connect on the John nz software the blue led blinks but red led stays solid and zyx doesn't respond at all
03-09-2014, 12:17 PM | #3 (permalink) |
What OS are you using on your PC? Did you select the correct COM port in the ZYX app? Are you sure you have the plug securely plugged into the ZYX, and have a good connection on the other end into a USB port on your PC? Has the wire plug that connects the lead to the USB dongle come off and you've mistakenly plugged it in flipped over backwards?
The ZYX won't flash or make a sound when the app connects. The red lights above the connect button on the app will go solid green. |
