Old 04-28-2016, 06:52 PM   #1 (permalink)
Default Solid Pinion for 500
I saw in a post somewhere that someone had a solid machined pinion for the 500. LYNX makes them for the Mini but not the 500. I think it might have been DoubleCH.
Keith - FrSky | OMP | KST | KC3D
Protos 800X Evo | OMP: M7, M4 MAX | M4*2 | M2 EVO*2 | M1 EVO | So Many Airplanes
KC3D LLC - Charge Cases, Starter Adapters, Heli Upgrades, and More
Number is online now        Reply With Quote Quick reply to this message
Old 04-28-2016, 07:05 PM   #2 (permalink)
https://www.helifreak.com/showthread.php?t=638975
DCH modded a 550sx pinion I believe
Sent from my SAMSUNG-SM-G920A using Tapatalk
Old 04-28-2016, 07:51 PM   #3 (permalink)
My v1 solid steel pinion was based on Lynx mod 1 pinion for 550x. My v2 is now based on mod 0.8 stainless steel pinion for Outrage Fusion 50.
https://www.helifreak.com/showthread...61#post6247661
Old 04-28-2016, 08:01 PM   #4 (permalink)
Interesting. What bit do you use for your dremel?
Old 05-03-2016, 04:50 PM   #5 (permalink)
I have a stock 550X pinion... probably brass or whatever. Would that work?
Old 05-04-2016, 01:18 AM   #6 (permalink)
I understand stock 550x pinion is 0.8mod which is good but I also understand that they are 16T which is too much. The 550x pinion I used was made by Lynx and was 1.0mod which means fewer teeth (13T). Although number of teeth was good 1.0mod was way too much pitch that's why it took me tremendous amount of effort to cut it down to 0.8 mod. The Outrage Fusion 0.8mod 13T pinion I used with my v2 pinion is much closer in pitch. Dremel bits won't work. If you have to ask, I highly recommend not do it. If not done properly you'll ruin the belt in no time and may result in crash and damage.
Old 05-04-2016, 07:06 AM   #7 (permalink)
Stock is 15T. I bought the 16T for it as soon as I built it because 15T was too small.
Old 05-04-2016, 11:36 AM   #8 (permalink)
Would you be able to do it for me sometime? Not now obviously since I don't have a 500 yet but I figured I'd save this for when I do get one.
Old 06-05-2016, 03:28 PM   #9 (permalink)
Bi Guys, my first Protos is in the mail. Reading this thread I am wondering, why would you want a solid pinion? I gueas it takes away the ability to auto it down, or not? Is it to get mor tooth count options or are there real advantages to have a solid pinion?
Thanks Hobee
Sent from my KIW-L21 using Tapatalk
__________________________
Compass 6HV-Ultimate / Protos 500 / T-Rex 500 / Oxy 4 / Oxy2 FE
Citizen 750
Hobee is offline        Reply With Quote Quick reply to this message
Old 06-06-2016, 06:49 PM   #10 (permalink)
Some users have had problems with the stock pinion, I think mostly that it's aluminium and under hard loads can wear quickly. I've flown my Protos moderately hard and not had a problem with the stock pinion, but only with 430 blades. Give the stock one a try.
The Protos doesn't auto tremendously well anyway, though if you get the belt tension and lubrication right it's still better than most 360s (using 430 blades).
Compass 6HVU, XLPower 520, Chase 380
cycled is offline        Reply With Quote Quick reply to this message
