Old 01-31-2012, 02:26 PM   #1 (permalink)
Default oiling your motor bearings
how many of you do this? and do you take off the motor shaft extender every time?
DX8i, 8FGS, Phoenix, icharger
Trex 450 pro V2, µBeast, HS-5065's, Ice Lite 50, GensAce, Exi FG 325's 450MX
Prôtos 500 6s 16T µBeast, 9650s H6080, Ice Lite 75, WR 5A BEC, SAB
nick779 is offline        Reply With Quote Quick reply to this message
Old 01-31-2012, 03:16 PM   #2 (permalink)
Personally I'm not going to anymore. Now that I have an arbor press, it's a piece of cake to change the bearings. And oiling bearings usually shortens the life of the grease that's already in the bearing. Next time, I might just spend the extra cash and get fully sealed bearings so none of the grease will leak out.
MSH Protos 500, SAB 630
alexf1852 is offline        Reply With Quote Quick reply to this message
Old 01-31-2012, 04:15 PM   #3 (permalink)
i take it you need a press to change the bearings?
anyone else oil their motor bearings on the protos 500?
Old 01-31-2012, 05:24 PM   #4 (permalink)
AFAIK the Protos motor is a Scorpion, if so they say you need to oil the bearings (with the oil they sell). So until you replace the the bearings you should add a drop of oil on a regular basis (before each days flight is a good plan IMO).
-DX8
desertstalker is offline        Reply With Quote Quick reply to this message
Old 01-31-2012, 06:06 PM   #5 (permalink)
id oil it if i had direct access to it, i installed the pinion shaft 1mm from the mount...
Old 01-31-2012, 08:49 PM   #6 (permalink)
I've got got about 25-30 flights on mine and I haven't oiled yet. I've planned on doing it this week.
William
Synergy N5C, 130x, Mini Protos 6s
wbefield is offline        Reply With Quote Quick reply to this message
Old 01-31-2012, 08:56 PM   #7 (permalink)
the oil is runny enough if you put a couple drops as close as you can get to the bearing the oil will find its way throught the crack and into the bearing. if you have an oil bottle with a little straw that will help to get the lube in the right spots.
mattmezz is offline        Reply With Quote Quick reply to this message
Old 01-31-2012, 09:34 PM   #8 (permalink)
The scorpion oil comes with 2 needle aplicators both of different sizes, as it was mentioned a few drops right near the shaft adaptor will seep its way onto the upper bearing, as for the lower bearing its very easey to get a drop or two of oil on it by just holding the heli upside down and using the longe needle between the vents on the shaft.
Mr dan is offline        Reply With Quote Quick reply to this message
Old 02-01-2012, 09:13 AM   #9 (permalink)
Is there something special about the scorpion oil? I have tri-flow lube that I have used on my blade 400's motor and I wonder if I can use that on my Protos
MSH Protos CF - DS3517MG Cyclic, S9257 Tail, Spartan DS760
Blade 400 - DS285MG Cyclic, DS290 tail, Align GP750, HobbyWing UBEC, aluminum upgrades.
Honeybee CP2 with SuperSkids (RIP)
Blade MSR
Atomsk is offline        Reply With Quote Quick reply to this message
Old 02-01-2012, 09:15 AM   #10 (permalink)
Its what I use on all my helis. Best stuff out there IMO.
Ecaf is offline        Reply With Quote Quick reply to this message
Old 02-01-2012, 09:31 AM   #11 (permalink)
I use tri-flow on everything Heli and haven't had any problems.
William
