Old 05-22-2014, 01:16 PM   #1 (permalink)
Question tracking down vibration/shudder - anyone had a bent head block?
Hi All. I am tracking down a noticeable vibration/shudder on my P500. It happens when spooling up/down, and also during some moves, including aileron tic tocs. One thing I hadn't considered is a bent head block (AKA main hub), but it would make sense. Question: Have you had yours bend after a crash? Thank you.
matthewcornell is offline        Reply With Quote Quick reply to this message
Old 05-22-2014, 04:15 PM   #2 (permalink)
So far my only crash was a full positive punch out 6 feet from the ground - inverted (brain was still upright). No bent head, but spindle, shaft, flybar, blades etc
How old are your head dampers?
2x MCPX I Gaui »X1« I 2x Mini Protos I Protos I DX8
dr dremel is offline        Reply With Quote Quick reply to this message
Old 05-22-2014, 07:15 PM   #3 (permalink)
Default tracking down vibration/shudder - anyone had a bent head block?
New dampers tried already, but thanks for the idea. I might bite the bullet and buy a new one just to check. It's still flyable, as yet.
Old 06-14-2014, 06:41 PM   #4 (permalink)
Head block was not the problem. FYI still figuring it out.
Old 06-15-2014, 04:02 PM   #5 (permalink)
I also have the same vibration ... i have changed the main shaft.. but I'm starting to believe in my just be the bearing s.. plan on changing them out tonight. ..
SAB Goblin 500
TSA 600E Pro
MSH PROTOS 500
MCPX V2
solex227 is offline        Reply With Quote Quick reply to this message
Old 06-15-2014, 10:34 PM   #6 (permalink)
Have you replaced the tail case/shaft bearings recently?
I had the same shudder on spool up/down. On the bench (static test) the tail case bearings seemed fine. However it turns out they were pretty well worn and one failed in flight a couple weeks later. I replaced the tail case w/bearings ($12) and the shudder is gone and the model is much smoother now.
- Eric
Compass Atom 6HV, KDE 600XF-530 motor, CC Ice2 HV 80, Torq Servos, BeastX
MSH Protos 500, Scorpion/YGE, Brain
GAUI X3 6S, Xnova 1860, HW 50A V3, MKS DS95, 8910A+, BeastX, Belted Tail.
isogloss3d is offline        Reply With Quote Quick reply to this message
Old 06-16-2014, 07:10 AM   #7 (permalink)
I'll redo the bearings, but this was one of the first things I checked. Thanks for the idea.
Old 06-16-2014, 11:50 AM   #8 (permalink)
Do you have cnc 3rd bearing mount? Had a stock mount wear and bearing became sloppy. Also reason i changed from plastic frame. Had same type of wear in plastic frame. 2 yrs since cnc mount and no problems.
Rick,
Team pilot ,
EGODRIFT, KST, Helidirect, Lynx/Oxy
crickr1 is offline        Reply With Quote Quick reply to this message
Old 06-16-2014, 04:21 PM   #9 (permalink)
Crickr I think you are on to something.....
I have cnc servo mount and 3rd bearing mount.. an the vibration appeared to show up after my last crash. I stared to pick through the head and man shaft .. but found nothing wrong or bent. Just to be sure I replaced both the main shaft and the spindle shaft. I ran up the bird on the bench (no blades) and found the same vibration on start up that would smooth out after a few seconds . So, I took the heli apart again and found the 3rd bearing on the main shaft had ever so slight been knoched... so I replaced all 3 bearings ... finishing up tonight and will tell you if this is the fix that worked for me..just might be a bad 3rd support bearing...finger crossed..
Matt did you find a solution to your vibration issue?
Solex227
SAB Goblin 500
TSA 600E Pro
MSH PROTOS 500
MCPX V2
Old 06-16-2014, 09:18 PM   #10 (permalink)
Do you mean one of these?: http://www.msh-direct.com/cnc-3rd-bearing-support/
An aside: What CNC upgrades would you recommend? I see ones like the tail pulley... The only thing I've done is the thrusted tail bearings - I was chewing through the radial ones like candy.
I replaced all three of my main shaft bearings early on, though I don't have the CNC replacement part at the bottom. I don't feel any play, but maybe it's subtle.
Solex227
Nope, but thanks for asking. I thought it might be a FBL gyro issue (I'm not happy with the Skookum on it), but I'm at a loss.
Old 06-16-2014, 11:06 PM   #11 (permalink)
Yes , that is the part. I would also suggest , the cnc tail gear, and all pullies.
Rick,
Team pilot ,
Old 06-17-2014, 07:31 AM   #12 (permalink)
Thank you. A $60 upgrade - well worth it?
Old 06-17-2014, 09:09 AM   #13 (permalink)
Most definitely, Those are the first and primary upgrades most will recommend on the Protos.
Rick,
Team pilot ,
Old 06-17-2014, 12:51 PM   #14 (permalink)
Matt
I'm going to keep my comments here ... you also mentioned that the collar slipped on the main shaft when you had your mishap in another post. Funny enough, I reported the same type of problem when I crashed a week or so ago in the (What did you do with your Protos TODAY) thread. In my case the collar failed not just slipped, the impact snapped the collar loose. needless to say my vibration problem started after that particular incident. In any case I do believe it was the third bearing for me and I found that replacing all three bearings solved the issue with the vibration for me. Last night on the bench the problem vanished... I hope you track down the issue soon and get back to flying...
Solex227
SAB Goblin 500
TSA 600E Pro
MSH PROTOS 500
MCPX V2
Old 06-19-2014, 07:27 AM   #15 (permalink)
I ordered the cnc parts and will see if they help. It's still shuddering. I'll pull the lower bearing to see if it or the holder is bad. Will update.
Old 06-26-2014, 06:09 PM   #16 (permalink)
While I'm waiting for the parts, I thought I'd give an update. I tried a major change by replacing the Skookum SK540 with an ikon. I figured that if the wobble/shudder went away then it was a gain thing with the sk. Guess what - shudder is still there, so it must be mechanical, right? I'm hoping it's that third bearing holder underneath...
Old 06-26-2014, 07:56 PM   #17 (permalink)
For what it is worth, I have bent a head in an inverted crash. It was a very hard crash ant the head was obviously bent. It also took out the swash.
aterren is offline        Reply With Quote Quick reply to this message
Old 06-26-2014, 08:33 PM   #18 (permalink)
Thanks for reminding me about the swash. I suppose that is the next thing to check. But I saw zero slop in it when eyeballing.
Old 05-27-2015, 05:20 PM   #19 (permalink)
Default main hub holes worn? (pic)
Amazingly, still debugging this. I've mostly learned to ignore it, but I wondered if your main hub holes look like. The one on the left is newer than on the right. The vertical oval is standard, correct? But I wonder if some side-to-side movement might cause the wobble. With a feathering shaft inserted without dampers, I can do a sideways see-saw - there's a little slop, in other words. Is yours like this? Thanks!
Old 05-29-2015, 08:27 PM   #20 (permalink)
You wore those out! I'm looking at one that looks perfectly round, so maybe oval could be an issue. Btw, I had to retire this one since it developed a crack in the metal below the hole in the middle that was for the flybar. Also, I've put the bolt in wrong and noticed that then the head really rocks since it isn't tight enough.
7hvu, 6hv,,Prôtos,450Pro, DT520E
some planks
Jumna is offline        Reply With Quote Quick reply to this message
