Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 200
Hurricane 200 Discussion and support of the Gaui Hurricane 200
Old 03-19-2012, 12:33 AM   #621 (permalink)
Default Gaui 200 V2 Mini Vbar
This is my gaui 200 with new head and Mini Vbar........ Flys like it's on rails.
ID:	300126   Click image for larger version
ID:	300127   Click image for larger version
jdsmith1008 is offline        Reply With Quote Quick reply to this message
Old 03-20-2012, 12:36 AM   #622 (permalink)
Where did you find the white landing gear? Looks nice!
Chief
RC Chief Hobbies
MSH Protos 500 Flybar, Gaui 200 V2 Flybar,V120D01, V120D02S,MCPx (retired)
Boating Fleet: Toysport Syncron and Triton Monos, 1/10 scale 1967 Miss Bardahl Shovelnose Hydro, Executone semiscale Hydro, OPC Tunnel, Miss Geico Cat
BHChieftain is offline        Reply With Quote Quick reply to this message
Old 03-22-2012, 02:20 AM   #623 (permalink)
Chief
Its the old white landing gear from my V1 Gaui
Old 04-17-2012, 11:34 AM   #624 (permalink)
Default Some previous and my current V2.
Fantastic little heli's,the V2 is my most recent.
Yoshi
ID:	308905   Click image for larger version
ID:	308906   Click image for larger version
ID:	308907   Click image for larger version
TT Raptor 30/46,Gaui H200v2,Gaui H255,Turnigy 9Xv2,Turnigy 9XR,Dji F450/Naza,Nine Eagles SP 125,Hubsan X4
Carbon love oil and plain old luck.
yoshimoto is offline        Reply With Quote Quick reply to this message
Old 04-28-2012, 08:42 AM   #625 (permalink)
Nice case too!
DMala is offline        Reply With Quote Quick reply to this message
Old 04-28-2012, 08:52 AM   #626 (permalink)
Yoshi
Yoshi - where did you get that canopy? I really like it!
Walkera 4#3B, 4G6
Align 250SE, Gaui 200
Tarot 450PRO
Align 550L Dominator
Steve Joblin is offline        Reply With Quote Quick reply to this message
Old 05-01-2012, 04:54 PM   #627 (permalink)
I believe that is a V1 canopy.
My Dawgz Got Madd Skillzz!
Heli #1:Gaui 200V?/FBL/BeastX V2.05/Gaui 5600/CC25/5065 MG's/DS09 GMD/Spektrum Sat.
Heli #2:Gaui 200V?/FBL/Gaui 5600/CC 25 ESC/65 MG's/BeastX V3.08/DS09 GMD/Spektrum Sat.
dynodude is offline        Reply With Quote Quick reply to this message
Old 01-25-2013, 02:53 PM   #628 (permalink)
I see a lot of guys are using the Hyperion DS09's on cyclic. How do they compare to the HS45hb's?? I've always used the 45's but they only seem to last very few flights before they burn out & begin twitching in flight. I get 3 45's for only a little more than just 1 hyperion so they're pretty expensive. Do they have HS65 longevity as they just last forever. Oh mines a V1 so limited options.
Heli Addicts Anonymous member
paddy is offline        Reply With Quote Quick reply to this message
Old 01-29-2013, 09:19 PM   #629 (permalink)
Here's my Gaui 200 V1. Bought it about 3 years ago used and have been adding to it since.
The guy before me had all stock setup with Hobby King HK401B gyro, JR DS285's tail servo, 12A Gaui esc with 3800KVA motor and I believe a 10 or 11 tooth pinion. He was running 3s batteries
Since then I've added the Bobby Watts integrated tail assembly, Z-Power 5150kva motor with 15 tooth pinion, 18A esc, 2s batteries, spartan quark gyro, TREX 205mm carbon fiber blades, Canomod canopy, carbon fiber skids and boom and tail supports, carbon fiber tail servo rod with JR DS290G tail servo. I kept the HS-45HB servos for cyclic, added the V2 main gear assembly, different flybar paddles ad tail blades. Next to do is change out the connectors with the 3 pin micro deans and hyperion 1.8mm bullet connectors at the esc/motor connection.
Getting very close to getting this bird in the air and been putting it together as I find the time and do the read ups on the goods. Maybe on the to do list after I test fly this bird is changing out the HS-45's to HS-65's, Castle Creations 25Amp esc and the Align 205mm main blades.
Name:	Gaui 200 1.jpg
ID:	389283   Click image for larger version
Name:	Gaui 200 2.jpg
ID:	389284   Click image for larger version
Name:	Gaui 200 3.jpg
ID:	389285   Click image for larger version
Name:	Gaui 200 4.jpg
craigr17 is offline        Reply With Quote Quick reply to this message
Old 02-01-2013, 08:49 AM   #630 (permalink)
Nice build! I've used that JR servo for the tail before-- works great. Where are you hiding that Quark?
Chief
RC Chief Hobbies
Old 02-01-2013, 10:33 AM   #631 (permalink)
Thanks,
The gyro is about an inch behind my walkera pro Rx. Trying to set up the head last night for correct and equal high and low pitch but something is out of wack. I adjusted my servo arm links about 1.42mm longer than indicated in the manual in order for the swash not to make contact with the hub in cyclic then adjusted my other arms in equal lengths accordingly in order to get parallel. My pitch at 50% throttle is couple degrees off zero and is about 11.5 on the high and 7 degrees or so on the low. I guess I'll try going back to the manual indicated lengths and see if that helps. Any tips or tricks? I've already watched all the videos or atleast I think I have. I may end up going with the longer flybar as well since I've heard this bird can be pretty tricky to hover.
Old 02-01-2013, 02:18 PM   #632 (permalink)
You wont get HS65's in a V1 frame. I've tried & they are too big as are HXT900's. The HS65 case is too fat so although you can get one in you wont get the 2nd one in.
Old 02-01-2013, 03:07 PM   #633 (permalink)
Thanks for that info. I'll see how the 45's hold up but maybe the ds09's. The HS-45's are a decent servo by what I hear. They sure are much less expensive than the 65's or 09's.
Old 02-01-2013, 03:15 PM   #634 (permalink)
A 'LOT' less expensive BUT i have gone through a fair few as the motors seem to burn out quick & then they constantly jitter in flight making it fly like a bag of nails. I'm looking at alternatives like the 09's but they'll cost me £75 for 3 & i'm not willing to spend that amount.
Old 02-01-2013, 05:43 PM   #635 (permalink)
Originally Posted by craigr17 View Post
Thanks,
I think your high/low pitch is not even as your swash isn't centered in its throw range. Don't try to use the link length to limit your throws to avoid binding-- get everying centered-- ok if binding with full throws at this point. THEN use your "SWASH" menu and back off the pitch channel to reduce the collective range so you don't bind. Also check the Aerilon and Elevator swash channels with full positive collective plus cyclic input and do the same for full negative. Check that the servos don't bind either.
You can further reduce the swash pitch channel to reduce the total pitch in your head to mellow things out. Same for Aerilon and Elevator channels-- you can increase or decrease the range to speed up or slow down roll and flip rates.
Lemme know if that works,
Chief
PS, long flybar plus stabilzer weights will make it pretty stable for hovering, but not that great for flying. Note, be SURE to add the stabilizer weights-- if you don't the longer flybar will just speed up the cyclic response and it will actually be harder to fly. Once you get that down, you'll probably want to go back to the short flybars with standard weights to get crisp response for tossing it around.
RC Chief Hobbies
Old 02-01-2013, 08:17 PM   #636 (permalink)
Chief
Thanks I will definately give this a shot and see what happens.
Old 02-02-2013, 03:40 PM   #637 (permalink)
BHCheiftain,
It worked. Thanks again for the info. Now time to start flying and to see if I need to go with the longer flybar.
Old 02-03-2013, 10:59 AM   #638 (permalink)
moved post to different category. Sorry
Old 02-06-2013, 05:32 PM   #639 (permalink)
8^)
Chief
RC Chief Hobbies
