MSH Mini Protos MSH Mini Protos Helicopter Support Forum |
09-13-2011, 09:26 AM | #61 (permalink) |
yeah, but if you notice, in this video, he is using metal blade grip...i wonder if they are going to sell it on the market...
09-13-2011, 09:42 AM | #62 (permalink) | |
There's no need for metal grips on the Protos, it's perfect as it is.
Chris Boultinghouse |
09-13-2011, 11:16 AM | #63 (permalink) |
3000rpm is fine with 350 blades, my IU2 is set there but I don't really have the skill to use it. IU1 is at 2800rpm and I had one of the 3d experts fly and he didn't need any more headspeed for normal 3D flying. The IRCHA video is another level though. ;-)
//Dennis.
soXos: Strike 8.1 - Strike 7.1 Light - Strike 6.1 : Goosky: RS7 - RS4 - S2 - S1 soXos DB7 nightflyer : Jeti DS-16 & DS-12 I am www.soxosaustralia.com.au | soXos helis | 1st-RC Products | EGODRIFT motors | Goosky helis | Spinblades |
11-14-2011, 08:45 AM | #64 (permalink) |
Just about to pull the trigger on a mini and am doing some reading.Is the 15 pinion being used on the stock 3s motor and does that pinion come with the mini kit?.I'm no 3D flyer but looking for good stability.Thanks for a great thread
11-14-2011, 09:06 AM | #65 (permalink) |
The 16T pinion comes with the kit, which is good for sport and 3D (HS from 2600 to 3100+).
03-22-2012, 11:02 AM | #66 (permalink) |
My tail slider feels very notchy. Everything feels very smoothly until I put everything together. The 2 screws looks very straight and touches the spacer at the same time.
Protos 380 NEO x2 Oxy 2 Goblin Fireball |
03-22-2012, 04:37 PM | #67 (permalink) |
Could it be that the tail shaft is slightly bent?
03-22-2012, 06:09 PM | #68 (permalink) |
its a brand new kit but ill check
03-22-2012, 06:21 PM | #69 (permalink) |
My experience has been that it is normally the screws, I think I mentioned in the build that I found I had to twist the arms to match the slider, not just set the screws up straight against the spacer.
Try backing off the 2 screws a little and if that makes it better it probably means you just need to play with the angles a little to get it smooth. //Dennis.
03-23-2012, 12:27 AM | #70 (permalink) |
Great thread Dennis. I finally got one but I will be running the stock 3s setup for now and maybe go 6s down the track.
Synergy E7 ~ Logo600SX + 600SE + 550SX ~ Synergy N7 + N5C ~ Mini P ~ Trex 450L |
03-23-2012, 10:22 AM | #71 (permalink) |
Great Tim, you will enjoy it, Warney is still loving his.
//Dennis.
06-02-2012, 05:07 AM | #72 (permalink) |
Just thought I would bump my build thread with several people doing builds at the moment, might help them if they haven't see it. Go back to the first post to for plenty of pictures and tips on the build.
A quick pic of the mini in its new home. //Dennis.
08-01-2012, 10:23 PM | #73 (permalink) |
Thanks Thunder Fighter for fantastic advice on this thread! Maidened my Mini Protos couple of days ago and Your write up with pictures helped a great deal to make this bird fly at first try.
08-01-2012, 11:55 PM | #74 (permalink) | |
//Dennis.
soXos: Strike 8.1 - Strike 7.1 Light - Strike 6.1 : Goosky: RS7 - RS4 - S2 - S1 soXos DB7 nightflyer : Jeti DS-16 & DS-12 I am www.soxosaustralia.com.au | soXos helis | 1st-RC Products | EGODRIFT motors | Goosky helis | Spinblades Last edited by Thunder Fighter; 08-02-2012 at 04:59 AM.. |
08-02-2012, 01:27 AM | #75 (permalink) | |
Where did u stay? |
08-02-2012, 04:13 AM | #76 (permalink) | |
Now with MiniP with Mini V-BAR the flight amount should escalate futher. |
08-02-2012, 05:05 AM | #77 (permalink) | ||
//Dennis.
08-02-2012, 01:17 PM | #78 (permalink) | |
I'm near Helsinki, on the way to Turku. We fly at Nummela airfield (www.nlk.fi ) thruout the year. |
12-17-2012, 06:15 PM | #79 (permalink) |
Hi all you Mini's guys,
Im about 90% in completing my build on my very 1st FBL bird (I had a 450 pro and blade 450 3D...still at hovering and some FF stage). Im gonna slap it with a BeastX gyro. In its ALL STOCKs setup....what TT curve would you suggest for starters?...
All begins (Jun 2011)....... Next project: MSH Mini Protos, 450 Scale Airwolf, BAH Mini Quad |
12-17-2012, 06:58 PM | #80 (permalink) |
I would start with 60-70% on the governor for the first few shakout flights, then see where you want to go from there. If you have the programing card then setup Governor Store mode as it keeps the headspeed consistent from pack to pack.
//Dennis.
