Go Back   HeliFreak > R/C Electronics Support > JR and Spektrum Radios and Electronics > 2.4G JR Radios
2.4G JR Radios JR 2.4 Gigahertz Radios and Technology
Old 04-01-2016, 10:40 AM   #1 (permalink)
Question Stunt 1 and Stunt 2 switch not working
So I have had my JRXG14 Tx for awhile now and flying on 4 different helis. I don't do bank switching. I have a lower stunt mode 1 and higher HS stunt mode 2. I always fly in Stunt mode 2 so I never noticed this until now. On all my setups I only have 1 HS and not 2. I don't even know which one is actually on when Im flying. So 2 of my helis use Vbar/Ikon gov but the other 2 use throttle curves with Kontronik esc's. I have never been crazy about programming the JR. Does this have something to do with the STK position menu? I don't want to start just messing around with my settings. The helis fly fine I just don't have 2 different HS's available.
Logo 550SX, Modified Logo 400SE, Forza 450 3S
Lompma is offline        Reply With Quote Quick reply to this message
Old 04-01-2016, 01:42 PM   #2 (permalink)
Throttle curves is where you would adjust rpm's, even with governors
VControl
Old hand at Planks
Peter
Old 04-01-2016, 02:00 PM   #3 (permalink)
Yes I know that. When I go from stunt 1 to stunt 2 the HS stays exactly the same, no increase or decrease. Never had any problems with this on my DX8
Old 04-01-2016, 02:29 PM   #4 (permalink)
Check the throttle output in the monitoring screen and switch through your flightmodes. That way you can tell if your curves are being used correctly...
Gaui X3 HW 50A V3 OMG H1/H2 Servo's BL450MX Mini-V (M.I.A.)
Gaui X5 FES Polaris BEC BLS451/251 Silverline V-Bar Formula Swash/Head
JR Forza 700 Scorp 160A opto + 4525 520 JR NX8925/SLG01 Vbar Neo
JR XG14 PL8 v2
mverhorst is offline        Reply With Quote Quick reply to this message
Old 04-01-2016, 04:37 PM   #5 (permalink)
On Monitor Screen:
Thro: Stunt 1 and Stunt 2 switch move from 0 to about 65% and then 70% just like my throttle curves are setup
Aux 4: Goes from 100 to 50 and then 0 in stunt 2 (this is in conjunction with the thro) ?
Gyro; Works fine. I do not have the gain tied to different HS's
Old 04-01-2016, 07:04 PM   #6 (permalink)
I just spent the last 2 hours messing with and no luck.
Old 04-01-2016, 07:48 PM   #7 (permalink)
So I may have found the problem. The Kontronik ESC is not programming correctly. Yes it is 0-100 linear throttle curve. The ESC is full power at half throttle at so going from Stunt 1 at 50% to 70% is showing no increase because it is already maxed. I don't have this problem using Castle ESC and external gov. Do I need to power the FBL unit separately and then power the kontronik to program it? The YGE had this issue. I have never had this issue before with spektrum and all the same equipment and Kontronik ESC's. I have used these on many, many helis before I switched to Xbus and I never had these issues.
Old 04-01-2016, 11:47 PM   #8 (permalink)
Set one of your TC to a linear one 0-100%. Power up TX in this mode, plug in Kontronik ESC and pull programming jumper or push button for Koby and Kosmik, wait for programming tone 1 then move throttle to max, wait for acknowledgement tone 1. Power down ESC, replace jumper on ESC if it had one. Do the same again and wait for 4 tones (mode 4) then full throttle and wait for acknowledgement 4 tones again. Power down and NOW set any TC between 50-65% for Jives or 50-85% for Koby, Kosmik and Jive Pro ESC's, depending on the rpm you want.
Make sure you do not have the FBL governor activated at all as no Kontronik ESC cannot use FBL governor except the HeliJive.
VControl
Old hand at Planks
Peter
Old 04-02-2016, 02:01 PM   #9 (permalink)
Got a nasty pm from OP, wonder if he/she really wants help on the question
VControl
Old hand at Planks
Peter
Old 04-03-2016, 02:46 AM   #10 (permalink)
Where done here...
JR XG14 PL8 v2
Old 04-03-2016, 07:27 AM   #11 (permalink)
Yes you can close the thread
VControl
Old hand at Planks
Peter
